How Can We Show Control Over Outsourced Processes?
JaneB
#21
I´ll pass on SGS´s definition of an outsourced process : An outsourced process is one that even if the organization has the condition/capacity to do internally, the organization decides to do it outside of the organization.
Really? I disagree and would dispute this - they're making up their own definition.
I'll stay with what's clearly stated in ISO 9001:2008 (cl 4.1):
NOTE 2 An “outsourced process” is a process that the organization needs for its quality management system and which the organization chooses to have performed by an external party.
Why, oh why, use something else ??? :nope:
Ted Schmitt
#22
The lead auditor put it in the stage 1 audit report. I did not dispute it or find anything wrong with it as all my outsourced processes are being monitored by many different ways...
JaneB
#23
Ah, that's a different thing. I assume the lead auditor wrote something like 'even though the organisation has the capacity to do this, it has chosen to outsource XYZ process' whereas I understood you to mean they were creating their own unique definition & using that. Sorry if I confused.
Ted Schmitt
#24
I think you understood it correctly the first time. The exact wording (after my translation) :
Outsourced processes in our understanding are those which even having the conditions/capacity to do it internally, the organization chooses to do it outside of the organization. Please check if this situation occurs.
Like I mentioned in a previous post, I did not think much of it since our outsourced processes are being sufficiently monitored and under control.
Roland Cooke
#25
Just recently transferring from TUV to SGS, I´ll pass on SGS´s definition of an outsourced process : An outsourced process is one that even if the organization has the condition/capacity to do internally, the organization decides to do it outside of the organization.
That's news to me, :D :rolleyes: certainly not how I would define outsourcing.
It's also simply wrong. For example, there aren't that many companies that decide (for whatever reason) to not use their own onsite irradiation facility and instead outsource that key manufacturing process step (gamma sterilization). They outsource because they can't do it themselves.
Certainly companies can also outsource processes for the reason you suggest.
Ted Schmitt
#26
Thanks for the input Roland.
Since you work for SGS could you maybe check what´s up here in Brazil with this "interpretation"?
I don´t wish to make this a big issue or anything, but now it´s making me curious...
Roland Cooke
#27
I wouldn't lose any sleep over it, but if you PM me all the info, I'd be interested, and may be able to find out more (no promises).
What I always say in these situations (I usually work with manufacturing organizations) is that it helps to create a moderately-detailed process flowmap.
Where one of the steps in the flow takes place at a different company, typically that's an outsourced process. You may well need more involvement in establishing the initial arrangements.
The reason that identifying outsourced processes early is important to CBs is that we might conclude that we need to audit there if the process is significant.
You need to establish why you are satisfied that the company is competent to provide you with the products/services you need (or at the very least explain what preventive measures you have put in if they can't be judged to be reliable).
red08
#28
My confusion lies more with regards to our current documented system procedures and work instructions that were developed for these, previously internal departments. I agree that yes they are still working under my roof however, I can not ignore that they are separate companies and will begin manage their resources in accordance with what makes since to their business. So, with that being said, do I develop a Supplier Quality Manual that provides our specifications and requirements for deliverable s? Will this allow me to remove the Design and Development system procedure, and relative instructions for my documented system? I do not develop and/or control the procedures that my other critical suppliers use. In accordance with the Purchasing element of the standard, we evaluate, audit, and place proper controls to ensure we receive conforming product. So, I'm asking our community to help me develop a plan for how I will treat and manage this situation in the future. Thank you
Helmut Jilling
Auditor / Consultant
#29
The standard does not require you to over control your outsourced supplier companies. It merely states you have to document whatever controls you have defined (if any are needed), and that has to be documented.
Remember, the cl 4.1 discusses identifying your processes, and inputs/outputs, criteria, metrics, planning it all out. Then it says if you have outsourced processes, you have to define those as well. You don't have to do all the 4.1 things,they can do it, but you do at a minimum have to define whatever controls you do have.
Examples can include requiring ISO certification, receiving inspection, adherence to specs, whatever is appropriate. Don't overdo it.
V
vanputten
#30
"An outsourced process is one that even if the organization has the condition/capacity to do internally, the organization decides to do it outside of the organization."
I get the impression that some of us are interpreting the SGS defiention of Outsource differently.
The SGS definition does not state that it is ONLY outsourcing if the organization has the capacity to do the process internally. It says that DESPITE having or not having the capability internally, if the organiztion chooses to have the process done externally, then it is outsourcing. The SGS definition says that independent of having the capability internally, when an organizaiton chooses to do the process externally, then it is outsourcing.
To me, Note 2 in section 4.1 of ISO 9001:2008 and the SGS definition mean the same thing to me. It is about choosing. If you choose to do it internally, then make sure you have the capacity or get the capcacity if you don't have it. If you choose to do it externally, even if you have the capacity inrternally (or not), then it is outsourcing.
P Rework Notification - Is it sufficient to show how we control rework process Manufacturing and Related Processes 1
Nihls When the MSA results show no operator influence Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
E Our company is planning to file MDD not MDR next month. Do we require to show chemical characterization report ? CE Marking (Conformité Européene) / CB Scheme 2
B IATF16949 audit requirement - Auditor request UCL and LCL must be show Xbar-R, IATF 16949 - Automotive Quality Systems Standard 7
F Hi friends, can anyone show me an example of a procedure for ISO 13485 6.4.1 Work Environment? ISO 13485:2016 - Medical Device Quality Management Systems 2
R How to SHOW the importance of checklists, through some team gaming or play? Training - Internal, External, Online and Distance Learning 37
Wes Bucey International Manufacturing Technology Show - 10 September 2018 - Chicago (meet up?) Coffee Break and Water Cooler Discussions 6
S What records are required to show compliance to ISO 13485:2016? ISO 13485:2016 - Medical Device Quality Management Systems 1
K Questions on Technical File to show it is current EU Medical Device Regulations 5
D How do I show compliance to RoHS, REACH and Conflict Minerals? REACH and RoHS Conversations 6
K Operator Checks - How to show that they were completed on a checklist as acceptable IATF 16949 - Automotive Quality Systems Standard 2
M Metric/Way to show how Internal DPPM and External DPPM relate to each other Nonconformance and Corrective Action 1
R Is it legal to attend a trade show while you have a 510(k) application pending? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
M Presentation displays for malls, etc. for exhibition to show products Coffee Break and Water Cooler Discussions 5
D Medica show in Dusseldorf - Has anyone else gone? Other Medical Device and Orthopedic Related Topics 3
W How to show compliance to multiple CE Directives ? CE Marking (Conformité Européene) / CB Scheme 4
T Is there a requirement in TS16949 that PO's show a revision level? IATF 16949 - Automotive Quality Systems Standard 3
S Which non Salmonella organisms show positive in Wellcolex? Test kit ? US Food and Drug Administration (FDA) 1
C Do I need to show fasteners in my BOM's/DMR etc? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
G What is needed to show competency Clause 6.2.2 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
W DIN ISO 1101 - Show me the General Dimensioning Tolerance Value Other ISO and International Standards and European Regulations 3
M Unapproved System Display at a Mexican Trade Show Other Medical Device Regulations World-Wide 2
L CE Auditor Using ISO audit reports to show compliance to the MDD?? EU Medical Device Regulations 4
P Is it necessary to show Model Number on the Labeling (meter box, label and manual)? Other US Medical Device Regulations 3
Hershal Reality TV show contest Coffee Break and Water Cooler Discussions 1
AnaMariaVR2 Design of Experiments in a Cooking Show Coffee Break and Water Cooler Discussions 0
T How to Show "Date/time" Data Graphically in Minitab Please? Using Minitab Software 2
S Suggested process to show compliance for this 820.120(a) for Label Integrity 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
R How do we show our Software Develoment Life Cycle is similar to IEC 62304 Other US Medical Device Regulations 3
L Old and New Primary Standards show a difference between them General Measurement Device and Calibration Topics 9
Marc Questions about the Internet circa 1994 on NBC's "The Today Show" After Work and Weekend Discussion Topics 1
V Can we show Photocopied Uncontrolled Copies of Documents to an FDA Auditor? US Food and Drug Administration (FDA) 15
H Can anyone show me a sample of a Cleaning Program for Food Manufacturing? Food Safety - ISO 22000, HACCP (21 CFR 120) 5
Ajit Basrur How to show percentage in an Excel graph? Excel .xls Spreadsheet Templates and Tools 13
Anerol C How I can show evidence that quality related activities are impacting the financials ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
L BSI Logo - Requirements when using the BSI logo to show certification ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
G Japan's PMDA Response to Question on Trade Show Display of Non-approved Device Japan Medical Device Regulations 9
P Must show Sub-Supplier details? Supplying a Tier 2 company IATF 16949 - Automotive Quality Systems Standard 7
JoCam How do I show the benefits of a QMS to the Design Team? ISO 13485:2016 - Medical Device Quality Management Systems 23
I In ISO 9001:2008 - Can we show an Internal Department as our Client/Customer ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
Marc Land a Million Show - Aviation Funny Stuff - Jokes and Humour 0
B Can somebody help me to show a 'delta-FMEA' example? FMEA and Control Plans 10
S How to show Approval for Documents and Training? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 21
V Competency - How I can show experienced operators are competent? Document Control Systems, Procedures, Forms and Templates 3
S How to show that policies are properly communicated & Training Effectiveness ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
Stijloor GM to take back 5 Delphi plants, contract details show World News 0
T Prison Break Fans ?? - TV Show Coffee Break and Water Cooler Discussions 10
8 SMED Classroom Exercise to show operators the importance of SMED Lean in Manufacturing and Service Industries 10
D A true example of CAPA - Accident that show its cause and the corrective action Nonconformance and Corrective Action 8
