How could this Hole Diameter and True Position problem have been Detected & Prevented
F
Frank T.
I have an issue I'm hoping fellow covers can give some guidance on how to correct this type of issue.
We manufactured a part, on a waterjet, that has a 0.281" diameter hole. The location of the hole should be at 3.7165" and 2.2441". The actual hole size is 0.2840" with a location of 3.7195" and 2.4435". As you can see the hole location of 2.2441" is out-of-spec. by approx. 0.1994". When I went back and checked the program used to manufacture this part the hole location was entered as 2.4410". The programmer acknowleged the numbers were accidentally entered incorrectly. When I checked the Inspection report for this part I discovered the same issue had occured, "dimension enter was 2.4410" instead of 2.2441". Both occurences resulted in the part being accepted.
I know the immediate correction would be to change the program and reverify that the dimensions meet the print (i.e. new FAI). The issue I have is how could this problem have been prevented/detected?
FYI, actual requirement is:
0.281" Diameter +/-.010"
True Position to be within 0.005" MMC relative to datum "C" MMC.
sjared
Re: How could this have been prevented/detected?
Would some type of assembly with mating parts prevented this situation? That is routinely part of our FAI process to act as an additional gut-check.
F
Frank T.
Assembly to the mating part is not an option we have.
Steve Prevette
Deming Disciple
A good trick on data entry is to specify a check sum, the addition of all of the digits of the data entry.
For example, the check sum on 2.2441 is 13
The check sum on 2.441 is 11
If the specification for the data entry said "2.2441 check sum 13" and if the data entry screen calculated the check sum and displayed it, it would be caught.
Of course, this doesn't help much for transposition errors (right digits in the wrong place), but there are fancier check sum algorithms that could deal with that.
For example, when you enter your credit card number, there is some form of check sum routine, because the data entry forms "know" whether or not you've entered a valid card number.
Q
Qualgal
In our process, we check the 1st piece to the print before proceeding.
sjared
That's an interesting idea, but does it work when there is a range of acceptable values like a dimension with a tolerance?
The check sum for 2.443 is also 13, but is almost .2" from 2.2441
Steve Prevette
Deming Disciple
Checksum isn't perfect. But you are basically trying to collapse a number down to a smaller value for an easy check. If there error is "random" it is likely to catch it.
I would assume with tolerances you enter the center value and the allowed error (two different data entries with two different check sums) or you enter the high and low values (again, two data entries, two different check sums).
Googling around, I found this artilce:
http://mcom.cit.ie/staff/computing/cmanning/pod/ISWD24.pdf
It shows some fairly sophisticated examples, such as one for credit card data entry.
Q
Qualgal
Measure it to the print. We always measure the 1st piece prior to proceeding. Depending on the hardness of the material or the variance of the stock, our programs may have to be adjusted.
F
Frank T.
The part was measured to print but the number 2.2441 was transposed as 2.441.
This is a niffty thought. The only dilemma is as sjared mentioned, what if the incorrect values added to the checksum value, or if numbers were transposed.
I 3 legged 5 Why - Hole diameter Oversize caused by Gauging Problem Solving, Root Cause Fault and Failure Analysis 9
R Maximum allowed eccentricity for any shaft or hole diameter Misc. Quality Assurance and Business Systems Related Topics 7
E Measuring a .250 diameter hole +/.005 in Thin Laminates Inspection, Prints (Drawings), Testing, Sampling and Related Topics 23
M Cp, Cpk, Dpm, or other? Diameter of a Hole - Non-Normal Distribution Capability, Accuracy and Stability - Processes, Machines, etc. 20
M Combining Data - Measured sizes of hole diameter onto one chart? Statistical Analysis Tools, Techniques and SPC 2
G How to ensure dimension of tapping hole before plating is correct? Manufacturing and Related Processes 2
R Through-Hole Electronics - Checking Lead Length Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
CycleMike GD&T - Hole pattern - Print (attached) has a single Datum Reference Frame Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
G Capability Study for Tapped Hole Reliability Analysis - Predictions, Testing and Standards 3
B Design of fixture checking including Position of hole and slot General Measurement Device and Calibration Topics 5
was named killer AS9100 FAIR - True Position hole out by .0011" on 50 parts AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
B Counterbore - Hole or feature? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
R Location Interpretation on Drawing - Hole to Hole? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
T Optical Comparator measuring of Position of a Threaded Hole Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
J Slotted Hole Dimensional Inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
J Hole Form Dimension - Shaft dimension which is +-.015 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
E Composite Position Calculation on a 12 X 4 Hole Pattern Inspection, Prints (Drawings), Testing, Sampling and Related Topics 13
I Hole dimension out VS in tolerance Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
P Inspecting a difficult part - Measuring the centre of a hole to the edge of a rod Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
B Calibrate Hole Presence Detection Device? General Measurement Device and Calibration Topics 5
V Checking for Oversize Hole - Dimensioning question APQP and PPAP 7
C Measurement System to measure Hole Diameters, True Positions, Surface Profiles, etc General Measurement Device and Calibration Topics 4
D True Position with 1 hole (Datum B) at the Radius Part Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
W Gage R&R for gage pins used to inspect a hole ID called a Statistical Tolerance Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
L GD&T Bonus Tolerance - Checking True Position of a Pierced Hole Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
S Surface Profile of a Hole - The meaning of the tolerance in the provided drawing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
E SAE-AS8879 Threaded Hole Gaging - .4375UNF-3B and .4375-UNJF-3B Inspection, Prints (Drawings), Testing, Sampling and Related Topics 15
J Basic Dimension Chaining - Second hole has a basic dimension from the first hole Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
D Hole Limit Dimension Values Placement - Smaller Limit On Top? Manufacturing and Related Processes 3
L When and how to apply Bonus Tolerance MMC - Hole Dimension Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
K True Position Checking such as Bolt Hole Position w.r.t Center Bore on Wheels Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
S Weld Cell Repeatability Studies - Origin - The 'drilled hole panel' Methodology Manufacturing and Related Processes 3
O How to report Profile of a Sphere crossed by a Hole Inspection, Prints (Drawings), Testing, Sampling and Related Topics 31
S Cp Cpk of a hole filleted for control P/NP Statistical Analysis Tools, Techniques and SPC 4
J True Position with only 1 Datum - Referenced datum is the plane the hole is on Inspection, Prints (Drawings), Testing, Sampling and Related Topics 17
M True Position of a Hole Capabilty - Appropriate parameters to use Capability, Accuracy and Stability - Processes, Machines, etc. 5
V How to design a gauge (fixture) for measurement of distance between two hole Design and Development of Products and Processes 23
T GD&T: Boundary - Callout for an Oblong Hole (Slot) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 13
J Measuring Hole @ .00005" Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
A Criteria for taking Dimensional Measurements of a Painted Hole in a Part Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
P Liquid Nitrogen to shrink fit a new plug into a hole in a casting Manufacturing and Related Processes 7
Proud Liberal Using Three (3) Gage Pins to Check Hole Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
Pancho What's the weight of a solid steel sphere with a 6" long cylindrical hole through? Brain Teasers and Puzzles 8
Jen Kirley Hole in one! Coffee Break and Water Cooler Discussions 17
R Trying to decipher drawing - Hole Size Manufacturing and Related Processes 12
A AS9102 FAI for Circuit Card Assembly - Measure each hole and document it? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
M What would Cause hole size smaller during the punching process of plexiglass? Manufacturing and Related Processes 7
M Countersink Hole Inspection - Old School Technique. Inspection, Prints (Drawings), Testing, Sampling and Related Topics 11
H E Coat (Electrocoat) Pin Hole Paint Defects - Help needed Nonconformance and Corrective Action 3
D Hole Surface Profile Tolerance Discussion Inspection, Prints (Drawings), Testing, Sampling and Related Topics 12
