How do I continually Verify Compliance to my Processes?
JJ777
How do I continually verify compliance to my processes. If I take my technical support process as an example(attached example). How do I verify apart from audits and CAR's that this process is functioning? The question that was forwarded to me was "How do we know that the quality of this process has improved or declined during the past month"
The only thing I can think of is that we look at the feedback from the customers after completion of the request to verify if the customer was happy about the overall service.
Sorin
Re: Verify Compliance
I think I'll number the critical steps of your process (the ones that modify your product and/or that show risk of failure/nc) and follow-up on how many dicrepancies you had/have over time (for each step).
That could give you also a pretty good idea about your weak links in the process.
JaneB
Are you really trying to verify compliance with the documented process? Because it sounds as though you are either attempting to establish how effective the process is and/or are aiming to measure whether the process is meeting its metrics?
These are 3 different questions, but they seem to be all mixed up together. Which is it?
When 'someone' who forwarded the question to you is asking:
They are not asking 'are people complying with this process' - so what do they actually mean by 'the quality of this process'? Are there any metrics/KPIs established for it? If so, what are they, and what do the figures say? If not, I don't see how you can answer the question.
John Broomfield
JJ777,
Everyone involved in this process (or any other process) needs to understand the process objective. This is not stated on your flowcharted procedure. I see little other evidence of conformity to clause 4.1c.
Once you have specified these criteria you and your colleagues can then monitor/measure your process for its conformity and effectiveness (see 8.2.3).
They may see trends then initiate preventive action per 8.4c and 8.5.3.
Do not wait to learn if the customer is happy. Invest in the prevention of unhappiness instead.
John
somashekar Sampling Technical Files Continually throughout the Certification Cycle EU Medical Device Regulations 6
I "Continually Improve QMS" Requirement help IATF 16949 - Automotive Quality Systems Standard 10
S How many improvement/continual improvement/continually improvement in ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
M How to verify profile gages provided by customer General Measurement Device and Calibration Topics 5
E Layouts : Can you "verify" things that are not visible (such as loctite present, internal dimensions) in a layout ? APQP and PPAP 2
K How to verify the Storage and Transport environmental condition for Medical Device Miscellaneous Environmental Standards and EMS Related Discussions 3
J How to verify the actual capacity of suppliers Supplier Quality Assurance and other Supplier Issues 3
V Regrinding Material - Verify whether a product contains any regrinding material Manufacturing and Related Processes 13
Q Using Caliper A to verify Caliper B - Verification of Calibration ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
V Tie-wrap pull test to verify contact retention Manufacturing and Related Processes 6
D How to Calibrate and Verify a Heating Oven General Measurement Device and Calibration Topics 3
A How to Verify Supplier I-9 Forms for ITAR Requirements Other ISO and International Standards and European Regulations 2
O Creating a Tool to Track & Verify Mistake Proofing Devices Document Control Systems, Procedures, Forms and Templates 5
N What is the easiest way to verify we have the correct customer supplied materials? Misc. Quality Assurance and Business Systems Related Topics 5
R IEC 62304 - 5.2.9 Verify Software Requirement IEC 62304 - Medical Device Software Life Cycle Processes 5
B Verify GB/T 16886 is the same as ISO 10993 US Food and Drug Administration (FDA) 5
A How to verify and validate the effectiveness of CAPA with regards to employees ? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
R IEC 62304 Section 5.3.6 Verify Software Architecture IEC 62304 - Medical Device Software Life Cycle Processes 4
R LKV Value: Can not verify Reliasoft Case Study Reliability Analysis - Predictions, Testing and Standards 2
S Verify Software System Testing: Verify that results meet the Pass/Fail Criteria IEC 62304 - Medical Device Software Life Cycle Processes 1
L Gauge to test and verify a Set Square Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
D What to verify on Test Setup for Environmental Testing General Measurement Device and Calibration Topics 7
A When to verify and when to validate Design Changes 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
D Since NIST # can not be used to verify Traceability - What an Auditor should do AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 8
C I need to verify the surface profile of a part - Sine plates General Measurement Device and Calibration Topics 4
W How to verify/calibrate a Neptune Water Meter General Measurement Device and Calibration Topics 4
optomist1 CMM Shortcomings - GD&T - Inability of CMMs to verify the MMC situation Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
C How to Calibrate and Verify Torque Multiplier Gages General Measurement Device and Calibration Topics 6
R A way to verify 7075 T0 Aluminum has been successfully Heat Treated to T6 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
Ron Rompen Recommended Rockwell 30T Scale Hardness Tester to verify Incoming Product General Measurement Device and Calibration Topics 1
D How to verify a process that uses software to accomplish certain tasks? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
X Cannot Verify until Customer uses Product - Clause 7.5.2 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
C Surface Plate Calibration - How to verify the flatness of a granite surface plate General Measurement Device and Calibration Topics 1
E How Do You VERIFY Customer Property? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
R Verify Accuracy for Validation of CNC Starrett Vision System Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
L Verify, Inc. Source Inspection experience? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
H Definition Inspect, Review, Verify and Witness - What are the definitions and differences? Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 5
B How to inspect Mylars to verify dimensions, grid lines and grid points Inspection, Prints (Drawings), Testing, Sampling and Related Topics 17
D How do I verify the Cold Room temperature in Restaurant Kitchen Food Safety - ISO 22000, HACCP (21 CFR 120) 7
C Bridgeport Mill as a Gage - Verify gage dimensions using a Bridgeport Mill Measurement Uncertainty (MU) 4
A Test Method - DIN ISO 1133 for melt flow needed to verify supplier results Manufacturing and Related Processes 1
F How would you Verify Repeatability and Reproducibility of Measurement Systems? Quality Tools, Improvement and Analysis 5
S How to Calibrate or Verify Screw Pitch Gages General Measurement Device and Calibration Topics 16
J Work Instruction to Calibrate or Verify a Combination Square General Measurement Device and Calibration Topics 15
Howard Lee Hygrometer Calibration - Best way to verify accuracy of a 'reference' Hygrometer? General Measurement Device and Calibration Topics 11
C How to verify the SAL (sterilie acceptable level) is 10-6 for ETO Sterilization ISO 13485:2016 - Medical Device Quality Management Systems 6
K Could someone verify the levels of quality management system standards Misc. Quality Assurance and Business Systems Related Topics 2
K Prohibited metal verification - I am not sure of a PHYSICAL way to verify this Various Other Specifications, Standards, and related Requirements 9
P CMM Programming verification - How would you verify that a CMM program is correct? Quality Tools, Improvement and Analysis 5
Douglas E. Purdy To Verify Concentricity of Flats to a Centerline General Measurement Device and Calibration Topics 9
