How do I inform FDA on discontinuation of 510(K) device ?
AJayC
The company I work for has discontinued manufacturer of a device with a 510K clearance.
What are therequirements for notifiying the FDA?
We will be importing the device - instead of manufacturing it.
The device will be sold shrink wrapped or boxed with a "Manufactured for" label;
the intended use will not change.
ascherp
Hello April,
Is the device you are now importing being manufactured for you according to your specifications, i.e. is it identical to your cleared device?
MIREGMGR
The company I work for has discontinued manufacturer of a device with a 510K clearance. What are the requirements for notifiying the FDA?
There are none for the 510(k) per se. If you were discontinuing being the responsible party for the device, you no longer would List it as its Manufacturer, and if it was your only marketed product you would no longer Register as a Manufacturer...but the former change is unclear from your comment, and the latter change will need to be considered in light of the new Registration requirements for 2013. You might still have to Register as a Specification Provider, and/or as the Initial Importer.
We will be importing the device - instead of manufacturing it. The device will be sold shrink wrapped or boxed with a "Manufactured for" label;
"Manufactured For" is (most often) FDA-label-code for you being a Distributor, and the maker being the Manufacturer. In order for that to be the case, they must be Registered as the Manufacturer, they must List the product, and they must have a 510(k) for the product. You of course could transfer your 510(k) to them via letter-of-agreement or contract. FDA has no role in such transfers.
If the offshore maker will not be Registered as the Manufacturer, you might remain responsible for the product as its Specification Provider. Then the offshore maker would have to be Registered as the Contract Manufacturer, and would have to List the product on that basis. You would remain the holder of the 510(k).
It also would be possible for the offshore maker to be a non-medical-device company and provide you with a product that is incomplete in some respect as a Component per 21CFR807.65(a). You then would remain the responsible Manufacturer for the device that you would legally create and perhaps physically finish, and you would hold the 510(k). You also would be responsible for all aspects of your supplier's operations.
Whatever other arrangements are in place, it sounds as if you will be the Initial Importer, so you will have to Register on that basis--possibly in addition to being the responsible Manufacturer or the Specification Provider.
Note BTW in regard to your 510(k) that if it included declaration of particular and/or validated material sources/grades and manufacturing processes, a Special 510(k) might be required to clear the materials and processes to be used by the new maker.
AJayC
The off-shore device manufacturer is registered with the FDA.
We do not specify how the product is manufactured, however, we did validated that the product is identical to the what we were manufacturing.
MIREGMGR
If the maker is Registered and the product is Listed by them as a Manufacturer, and they are not acting as a Contract Manufacturer for you, then you will no longer List the product as a Manufacturer or Specification Provider and they will have to be the 510(k) holder. Under the upcoming 2013 rules, you however will have to Register as the Initial Importer.
Your validation that the product is identical is irrelevant.
P Is a registrar obligated to inform the FDA of NCRs that could be considered 483s? US Food and Drug Administration (FDA) 8
D ISO 14971:2019 vs MDR Annex 1, Requirement #4 - "Manufacturers shall inform users of any residual risks" ISO 14971 - Medical Device Risk Management 5
A Inform NB of change to Indications of Use, but change is not a medical feature CE Marking (Conformité Européene) / CB Scheme 1
L Open letter to inform our Vendors we are setting up an Integrated (QHSE) System Miscellaneous Environmental Standards and EMS Related Discussions 5
D Letter to inform customers about software bug ISO 13485:2016 - Medical Device Quality Management Systems 4
M My site is closing When should I inform my Registrar ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
S Food Recall procedure - Should we inform consumers? ISO 22000 Conformance Food Safety - ISO 22000, HACCP (21 CFR 120) 14
G Requirement to inform a Notifying Body about changes in Top Management? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
D Inform Customer of Changes to QMS (Quality Management System)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
M QS-9000 level 3 PPAP - Can anyone inform me on the process? APQP and PPAP 7
S Transitional Adolescent A and B - "CDRH PREMARKET REVIEW SUBMISSION COVER SHEET FORM FDA 3514" Medical Device and FDA Regulations and Standards News 1
P MSDS for MVQ FDA White, Vinyl Methyl Silicone Rubber EU Medical Device Regulations 4
C RA (Regulatory Assurance) Training (FDA) looking for resources Training - Internal, External, Online and Distance Learning 5
E FDA 513(g) Cover Letter US Food and Drug Administration (FDA) 5
S Records - Do's and don't' of record entries (FDA - 21 CFR 820) Records and Data - Quality, Legal and Other Evidence 13
B New Facility register with FDA Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 4
J FDA regulation on decorative contact lenses Medical Device and FDA Regulations and Standards News 5
P Anyone have an Idea on UAE Medical device registeration- Class B with FDA only Other Medical Device Regulations World-Wide 0
F FDA classification for a mobile app Medical Information Technology, Medical Software and Health Informatics 3
Ed Panek IFU Contact Requirements - FDA and MDD/MDR US Food and Drug Administration (FDA) 1
O Any info on release date of FDA “Computer Software Assurance for Manufacturing and Quality System Software” document? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
P Writing a presubmission to the FDA prior to the De novo submission US Food and Drug Administration (FDA) 4
K FDA - Can we have more than 1 Initial Importer Medical Device and FDA Regulations and Standards News 4
K Two FDA questions regarding UDI (and potentially 803.52 MDR) Other US Medical Device Regulations 0
R Importers - For the FDA Registration/ Listing, is the CMO the importer? Medical Device and FDA Regulations and Standards News 6
Z Iterative development and FDA change requests IEC 62304 - Medical Device Software Life Cycle Processes 12
P FDA Approved Product Contact Parts ISO 13485:2016 - Medical Device Quality Management Systems 6
O Clarifying FDA definition of "finished device" and “capable of functioning” 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
A FDA guidance on non-sterile Medical Device Packaging Medical Device and FDA Regulations and Standards News 7
JoCam FDA Registration for Sub-contract manufacturers Medical Device and FDA Regulations and Standards News 2
M FDA News FDA Releases Draft Guidance Clarifying Application of ISO 10993-1 Biocompatibility Standard Medical Device and FDA Regulations and Standards News 0
E Contract manufacturer FDA requirements foreign company US Food and Drug Administration (FDA) 6
P Choice of FDA reviewer US Food and Drug Administration (FDA) 6
J Is Device Tracking Card an actual requirement under FDA regulation? Other US Medical Device Regulations 0
T Definition Human Use (FDA) Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 7
K FDA 510k electrosurgery 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
J Leveraging FDA 510k Clearance for International Registrations Other Medical Device Regulations World-Wide 2
shimonv FDA News FDA guidance on Multiple Function Device Products (8/2020) Other US Medical Device Regulations 1
N FDA UDI - Label vs. Labeling - Does the insert need to include UDI? Other US Medical Device Regulations 1
J FDA notification of address change US Food and Drug Administration (FDA) 2
