How do I make the Corporate QMS work in the manufacturing setting?
desireecharm
Hi everyone. Long time listener, first time caller. :)
I work for a large quasi-governmental organization (approximately 20k employees). I'm a process engineer in an overhaul facility, which is not the company's main line of work/service, but we directly support it. The corporate quality department did an internal audit recently and we failed, mainly because we don't have any type of quality system in place in our location.
The gentleman running the Corporate Quality show sounded incredibly surprised that we weren't all using the corporate QMS. I'd never seen it, to be honest. Now that I have, I see that it's a flight of fancy, especially the parts where it states that we're ISO 9001:2008 compliant, etc, etc.
In the past, I studied to be a CQA, and was one of the internal ISO auditors for my company. That was 9001:2000, which isn't a whole lot different, from what I can see.
Here's the question: I have a corporate QMS document that's fairly inadequate at describing what we do and how we ensure a quality product, how all the departments fit together, etc. It's pretty generic and fits the letter of ISO requirements, not really the spirit. We need something for our location that's relevant, describes our processes, identifies our document control methods, shows local management involvement, engineering support, materials support, etc. What would this document be? Is it a "Springfield, USA Overhaul Facility Quality Manual" (i.e. lower level QMS)? Is this an addendum to the corporate QMS? Is this a Quality Plan for performing captial projects and component repair (our two main business lines on site)? Something else entirely?
We are not pursuing ISO certification, but in order to be competitive, we need to be more efficient, and getting a handle on quality will help. Part of that is getting everyone here at the facility on the same page. Any advice you can offer would be very greatly appreciated.
Thanks in advance,
Marisol
Sidney Vianna
Post Responsibly
What I have seen used very effectively is the approach of having "supplemental" documents describing the processes at each site, location, etc... High level corporate QMS policies lack granularity and are too generic to be effective, especially for organizations with very diversified product and services portfolios.
Having a site specific QMS supplementation (supporting and not conflicting) with the corporate QMS has always been the most effective way to handle the challenge, in my experience.
And welcome to The Cove as a first time poster. Hope it is not your last one and many more follow.
P
PaulJSmith
Hi, Marisol.
Judging from this statement, you seem to already be on the right path to success. You're pursuing this for the "right" reasons.
Sidney's advice is solid ... as it usually is.
Good luck.
desireecharm
Thanks to you both for your insight.
Sidney, when you talk about a supplement, what would that look like? In the past, I've seen the local manual pick up at section 4.2.3 or 5.1-5.2 (saying to reference the corporate policy on everything before that), and as it goes forward, it skips the sections that don't require supplementing. Does that sound right, or am I leaving something out?
Also, would that be titled "<local facility> Quality Manual"?
Thanks,
Marisol
JaneB
I think the structure, title etc depends on you, or a negotiated outcome between what you want & whatever the corporate wants, as well as how their manual is structured.
Also sounds as though you have a reasonable handle on what is needed.
DRAMMAN
I would view the Corporate QMS Manual as the high level governing document. Then document what you do at your site through procedures, WI's, etc. It would not be required, but you could also write a facility specific quality manual. This would be the typical approach I have seen at multi-facility companies from large to massive.
RoxaneB
Change Agent and Data Storyteller
I've worked for a large multi-national corporation that was going down the road of having a large, all-encompassing QMS for all sites. Thankfully, it was generic enough to apply to all...and unfortunately, it was generic enough to apply to all. :bonk:
What we had to do was walk that fine line between ensuring we developed a system that was valued-added for us without violating what the company said was going.
This resulted in frequent reaching out to our other sites to see what they were up. You could try doing the same. No point in re-inventing the wheel if you don't need to. :D
desireecharm
for example corp's guidance states in very high level overarching words, 'we believe in the concepts of a quality program...blah...blah...blah'.
Sector's guidance states our technical teams follow 'AS or ISO or standards...blah blah blah' 'and as such will have QMS, metrics, customer, ad nausm'
the project level QMS is where the knife hits the steak...'our QMS does this by doing that, etc., etc.,
each entity assesses the next lower group to assure there is a quality within the system.
The corporate QMS manual is a combination of the first two you described, with a lot more of the 'we believe in the concepts of quality' than I am comfortable with at the facility level. That's why I'm leaning towards a site specific document, but only addressing those sections which are different, and for anything that can be said generically enough, just have it reference the Corporate QMS (since that's how we'll be operating).
One more thing (and this is almost a separate question): Has anyone run into the situation where the company QMS document had sections where the author basically regurgitated the ISO 9001 element? I want very much to follow this document, but in several places it paraphrases the elements in the affirmative.
For example:
Element 5.4.2 Quality Management System Planning states
Top management shall ensure that:
a) the planning of the quality management system is carried out in order to meet the requirements given in 4.1, as well as the quality objectives, and
b) the integrity of the quality management system is maintained when changes to the quality management system are planned and implemented
Corporate wrote:
This QMS has been carried out to meet requirements identified in 4.1 as well as the quality policy. Integrity of this system is maintained when changes arise through planning, implementation and review.
Is this sufficient for a company that is using ISO format but isn't pursuing certification? If not, what should it include, or is this something that needs clarifying at the facility level?
:thanks: for your patience, everyone. I know I'm throwing a lot of questions out here.
Marisol
JaneB
One more thing (and this is almost a separate question): Has anyone run into the situation where the company QMS document had sections where the author basically regurgitated the ISO 9001 element? I want very much to follow this document, but in several places it paraphrases the elements in the affirmative....
Unfortunately, yes. Many, many times. As have many other forum regulars.
Indeed, many people still mistakenly believe that this is what a 'quality manual' should be. And others still sell copies of the things as a 'canned' quality manual template - indeed, your corporate chappie may well have bought one of those horrible things. Sigh. Complete waste of time and words.
DRAMMAN
Yes. If you are ever in a position where you audit many companies you see this frequently. In my case it was auditing supplier quality systems. This was especially prevalent when standards such as ISO, QS, TS etc first started appearhing and large companies started requiring certification from smaller suppleirs. The companies that simply got certified to meet the customer requirements did this frequently.
G Setting up a corporate umbrella QMS ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
S Internal Audits of QMS Corporate Basics at the Local Plant Level ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
D ISO TS 16949 Corporate QMS IATF 16949 - Automotive Quality Systems Standard 1
S Advantages and disadvantages on IATF corporate scheme IATF 16949 - Automotive Quality Systems Standard 2
L Have been purchased by a corporate company ISO 13485:2016 - Medical Device Quality Management Systems 7
Ajit Basrur Corporate management standards ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
B Advantages of a corporate certification scheme IATF 16949 - Automotive Quality Systems Standard 8
U IT Process is Taken From company and Added to Corporate Structure ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
N IATF 16949 - Mandatory Corporate Documents IATF 16949 - Automotive Quality Systems Standard 10
julsbear Corporate Services as Externally Provided Service IATF 16949 - Automotive Quality Systems Standard 1
J What does "Corporate stewardship" mean? IATF 16949 - Automotive Quality Systems Standard 6
S Corporate Quality Manager keeping me out of the Management Review Meeting Management Review Meetings and related Processes 28
sutie What is Ethics Escalation (“Whistle-Blowing”) Policy - Corporate Responsibility IATF 16949 - Automotive Quality Systems Standard 7
L Corporate Manual - Global Multi-Site ISO9001:2015 Certification ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
J Supplier is dictated to us by corporate Supplier Quality Assurance and other Supplier Issues 5
K Gage Calibration - Corporate Scheme IATF 16949 - Automotive Quality Systems Standard 3
RoxaneB Fighting Corporate Memory Loss Training - Internal, External, Online and Distance Learning 7
C ISO9001: Moving from site certification to corporate certification Quality Manager and Management Related Issues 9
R Steps to Preserve ISO 9001 Certification during Corporate Acquisition? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
R Question on Corporate Audit Scheme IATF 16949 - Automotive Quality Systems Standard 1
N Corporate direction - External Auditor Influenced by Corporate Management ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
J How to calculate Surveillance Audit Days in Corporate Audit Scheme IATF 16949 - Automotive Quality Systems Standard 4
C Audit of the Corporate Audit Program 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
Q TS 16949 Manufacturing Site uses ISO 9001 Corporate Laboratory IATF 16949 - Automotive Quality Systems Standard 2
Y Can't meet PEAR goals because of Corporate MGMT... Quality Manager and Management Related Issues 10
U Customer Audit Nonconformity on Internal Audit Program done by Corporate QA General Auditing Discussions 19
D Whither Corporate Social Responsibility Imported Legacy Blogs 2
Sidney Vianna Cleaning up the Global Compact: Dealing with Corporate Free Riders Sustainability, Green Initiatives and Ecology 2
Q Management Review Inputs - Production Site under a Corporate Certification Scheme Management Review Meetings and related Processes 9
M Corporate Procedures and their effects on Companies they Own Quality Manager and Management Related Issues 6
B Corporate Goal about ISO 9001 Registrar Audits ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
G Corporate Documents cover local facility - How many departments can I exempt? Document Control Systems, Procedures, Forms and Templates 3
C 9001 Corporate Quality Audit - Yearly Audit on the Individual Business Units General Auditing Discussions 4
V Corporate Quality Management System - Structure, Pros and Cons? Quality Manager and Management Related Issues 3
J What are the Processes under Strategic Corporate Planning ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
P What is the status of, and requirements of Corporate Social Responsibility Other ISO and International Standards and European Regulations 2
C Control and Revision of a Corporate QA Manual ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
M ISO 13485 Multiple Site Registration - Corporate HQ is listed as a subsidiary ISO 13485:2016 - Medical Device Quality Management Systems 4
somashekar Driving CSR (Corporate Social Responsibility) Performance down the Supply Chain Supplier Quality Assurance and other Supplier Issues 8
Q Spin Off and Divestment from Corporate - What to expect Quality Manager and Management Related Issues 10
M Mixed Use of Corporate and Site Level Procedures and Forms in the Quality System ISO 13485:2016 - Medical Device Quality Management Systems 1
Stijloor The Road to Corporate Responsibility: An Automotive Conference World News 0
Marc WikiLeaks Julian Assange Wants To Spill Your Corporate Secrets World News 6
T What is difference between a Corporate Quality Manual and TQM? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
D Tobacco and CSR (Corporate Social Responsibility) Imported Legacy Blogs 2
J ISO9001 and Corporate Governance - ISO 37000 being developed to guide standardized Corporate Governance (updated thread March 2019) Other ISO and International Standards and European Regulations 12
K Corporate Volunteer Policy examples wanted Misc. Quality Assurance and Business Systems Related Topics 9
N New Seven Management Tools - Corporate Objective - Achieve 20% sales increase Misc. Quality Assurance and Business Systems Related Topics 3
P Corporate Social Responsibility as an essential element to sustain a business Other ISO and International Standards and European Regulations 19
D Quality Manual for Corporate umbrella certification Quality Management System (QMS) Manuals 4
