How Do I Remove Gages From Archive?
Chans
I need to remove the archive status from a gage but I can't find information in the help section about how to do it. I thought changing the status from retired to available would accomplish this but it's still archived. I could delete the gage and add a new one with the same name but then I would lose the gage history. Can anyone explain the best way to do this?
Hi Chans. From the General tab on the Gage Card you will need to select the Active checkbox on the right hand side as well as changing the status. This should bring the gage back into active status for you.
I see what the problem is now. I'm unable to check the Active box and I'm unable to access Choice Lists under Global Collections within the GAGEpack settings in order to do so. I'm guessing this is a licensing issue. Do you happen to know the best way to gain those permissions?
I figured it out. I just needed to login as the administrator to be able to do this. Thank you for your advice! Have a great weekend!
