How do I show the Interaction of Processes in the Quality Manual referring to 4.1(b)?
Marc
#11
Re: How do I show the interaction of processes in the quality manual refering to 4.1(
The preferred method is to ask others to contact you by PM or email accessible by clicking on your user name.
If anyone can help within this thread (yes, I know it's an 'oldie'), that would be good.
howste
Thaumaturge
#12
I am varadarajan.
Hello to all.
This attachment which I made for ISO could be helpful
:):agree:
Hi Varadarajan,
What are the interactions between the processes in your diagram? Also, does your organization buy or produce any product? I don't see where that is shown anywhere. :confused:
V
Varadarajan
#13
Re: How do I show the Interaction of Processes in the Quality Manual referring to 4.1
My Company is Design services provider(With CAD,catia ETC.)for various engineering sectors.
The Interactions are only limited with Design,Quality check,& Marketing.
The purchases are limited to PC hard ware & SOFT WARE like CATIA & CAD.
Regards,
Varadarajan
Patricia Ravanello
#14
Re: Sample process model map
The attached ppt file depicts the 13 principal processes that we have identified for our business. Suggestions & comments solicited.
While I laud your efforts and success at reducing your principal processes to just 13, it amazes me that among them, you don't include two of the most important management processes for monitoring and controlling your operating system, those being:
1) The Internal Audit Process
2) Corrective and Preventive Action​
Also, you have continual improvement twice, and make no mention of the Control of Non-conforming Product, and there's a noted absence of a process to control changes in product or process.
One last thing...while some of your processes certainly appear to be sequential (represented by the arrows), a lot of your arrows make no sense to me at all...and how is "interaction of processes" represented in your diagram?
I would caution any neophytes with regard to the use of this model as a reference.
I don't mean to beat up on you...I hope this helps.
Patricia
Bob the QE
#15
I am not sure if I hit the right thread, but a lot of examples in here show process interaction to the standard, be it ISO or QS. I am working in the AS world so I am looking at the interaction between processes of the QMS (4.2.2 c). In this regard would it be correct for me to show how let's say NCM procedure (8.3) related to Management Review, Quality Objectives or what ever else processes it impacts. I am looking for real value added tool so that the input's and output's of each process can be determined to it's effect(s)
Right, Wrong, or I Aint got a clue ......wrong thread you aint got a clue:eek::lmao:
Rinascimento
#16
While being aware of the point that Patricia Ravanello makes, I wonder if people could comment on our existing diagrams that were produced without the specifics of ISO 9000 in mind.
What would you think a certifying auditor would say?
Hmm. These gifs don't show properly on behind my company's firewall. I might have to work out a better way of showing them. I am away until after the week after Easter, so might not reslve this problem for a while.
JaneB
#17
Different auditors might say different things.
They appear to me to be more focussed on marketing - viz "look at all this stuff we do". Taken in isolation, I'm not sure what they're supposed to do or illustrate. Colourful, pretty, but to what purpose?
(Not meant as a beat up, just an opinion).
Patricia Ravanello
#18
If the attached Models were not created with ISO 9000 in mind, what was their purpose? It's hard to evaluate their efficacy if we don't know what the objective of the exercise was.
I can see that you've adapted the second document from the ISO 9000 model that is so widely bastardized...and serves no meaningful purpose.
To answer your question, your auditor would probably ask what I did...What's this for...what does it represent...Does everyone in the organization who needs to, understand it's meaning and significance?
I'm all for using local terminology, but sometimes it doesn't make sense or add value to make up a new nomenclature for standardized terms...after all, that's the whole point of standardization.
Patricia
Bob the QE
#19
To Patricia's and Jane's points, when I posted my question my mind set was if I needed to create, write or revise a new or existing procedure how would I really know who's life I was affecting and what implications this document would have. So I set out to do an in-put/out-put type of matrix in relationship to the AS Requirement. I think by doing this my next step is to make a matrix showing relationships between inter company procedure. So with this in mind I would appreciate any input on the attached first matrix. Again I am trying to develop a value added tool, as the examples I have seen and developed in the past really do not offer any value only meet a requirement.
Thanks in advance.
Patricia Ravanello
#20
Thanks in advance.
Hi Bob the QE,
I think you're on the right road. I created a similar matrix (see attachment) to help me sort out all the requirements of the respective standards and aligned them with our Key Processes. (Mine is a bit more detailed, because I found by including the actual text of the standard, the document champion could read exactly what the requirement was, and then verify that the intent was met in his/her document)
Anywhere the requirement interfaced on some level with the process, I added a check mark.
Each column of check marks then became the "To Do List" for the person who was Champion of that Procedure. The just go down each column and make sure that their respective procedure captures the identified requirement.
Obviously this document is primarily of use to the System owner and Process Champions.
As you said, next you start checking to define where each Key process interfaces with other Key processes. In my system, this is identified in the flow charts, where other Key processes (or supporting Work Instructions) are highlighted in Red (you could map this out in a Matrix if it serves your purposes). This method lets you know how each Key Process is linked to other Key processes (see second attachment - sample of Internal Audit interface with other Key Processes). In reality, your System Process "Sequence and Interface" Map should capture this requirement. If you send me a message with your e-mail, I'll send you a file to demonstrate how mine does that. The file, unfortunately is too large to upload here.
Sounds like you're on the right path...and doing it so it makes sense, and adds value.
Hope this helps.
Patricia
Nihls When the MSA results show no operator influence Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
E Our company is planning to file MDD not MDR next month. Do we require to show chemical characterization report ? CE Marking (Conformité Européene) / CB Scheme 2
B IATF16949 audit requirement - Auditor request UCL and LCL must be show Xbar-R, IATF 16949 - Automotive Quality Systems Standard 7
F Hi friends, can anyone show me an example of a procedure for ISO 13485 6.4.1 Work Environment? ISO 13485:2016 - Medical Device Quality Management Systems 2
R How to SHOW the importance of checklists, through some team gaming or play? Training - Internal, External, Online and Distance Learning 37
Wes Bucey International Manufacturing Technology Show - 10 September 2018 - Chicago (meet up?) Coffee Break and Water Cooler Discussions 6
S What records are required to show compliance to ISO 13485:2016? ISO 13485:2016 - Medical Device Quality Management Systems 1
K Questions on Technical File to show it is current EU Medical Device Regulations 5
D How do I show compliance to RoHS, REACH and Conflict Minerals? REACH and RoHS Conversations 6
K Operator Checks - How to show that they were completed on a checklist as acceptable IATF 16949 - Automotive Quality Systems Standard 2
M Metric/Way to show how Internal DPPM and External DPPM relate to each other Nonconformance and Corrective Action 1
R Is it legal to attend a trade show while you have a 510(k) application pending? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
M Presentation displays for malls, etc. for exhibition to show products Coffee Break and Water Cooler Discussions 5
D Medica show in Dusseldorf - Has anyone else gone? Other Medical Device and Orthopedic Related Topics 3
W How to show compliance to multiple CE Directives ? CE Marking (Conformité Européene) / CB Scheme 4
T Is there a requirement in TS16949 that PO's show a revision level? IATF 16949 - Automotive Quality Systems Standard 3
S Which non Salmonella organisms show positive in Wellcolex? Test kit ? US Food and Drug Administration (FDA) 1
C Do I need to show fasteners in my BOM's/DMR etc? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
G What is needed to show competency Clause 6.2.2 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
W DIN ISO 1101 - Show me the General Dimensioning Tolerance Value Other ISO and International Standards and European Regulations 3
M Unapproved System Display at a Mexican Trade Show Other Medical Device Regulations World-Wide 2
L CE Auditor Using ISO audit reports to show compliance to the MDD?? EU Medical Device Regulations 4
P Is it necessary to show Model Number on the Labeling (meter box, label and manual)? Other US Medical Device Regulations 3
Hershal Reality TV show contest Coffee Break and Water Cooler Discussions 1
AnaMariaVR2 Design of Experiments in a Cooking Show Coffee Break and Water Cooler Discussions 0
T How to Show "Date/time" Data Graphically in Minitab Please? Using Minitab Software 2
S Suggested process to show compliance for this 820.120(a) for Label Integrity 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
R How do we show our Software Develoment Life Cycle is similar to IEC 62304 Other US Medical Device Regulations 3
L Old and New Primary Standards show a difference between them General Measurement Device and Calibration Topics 9
Marc Questions about the Internet circa 1994 on NBC's "The Today Show" After Work and Weekend Discussion Topics 1
V Can we show Photocopied Uncontrolled Copies of Documents to an FDA Auditor? US Food and Drug Administration (FDA) 15
H Can anyone show me a sample of a Cleaning Program for Food Manufacturing? Food Safety - ISO 22000, HACCP (21 CFR 120) 5
Ajit Basrur How to show percentage in an Excel graph? Excel .xls Spreadsheet Templates and Tools 13
P Rework Notification - Is it sufficient to show how we control rework process Manufacturing and Related Processes 1
Anerol C How I can show evidence that quality related activities are impacting the financials ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
L BSI Logo - Requirements when using the BSI logo to show certification ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
G Japan's PMDA Response to Question on Trade Show Display of Non-approved Device Japan Medical Device Regulations 9
P Must show Sub-Supplier details? Supplying a Tier 2 company IATF 16949 - Automotive Quality Systems Standard 7
JoCam How do I show the benefits of a QMS to the Design Team? ISO 13485:2016 - Medical Device Quality Management Systems 23
I In ISO 9001:2008 - Can we show an Internal Department as our Client/Customer ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
Marc Land a Million Show - Aviation Funny Stuff - Jokes and Humour 0
B Can somebody help me to show a 'delta-FMEA' example? FMEA and Control Plans 10
S How to show Approval for Documents and Training? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 21
V Competency - How I can show experienced operators are competent? Document Control Systems, Procedures, Forms and Templates 3
S How to show that policies are properly communicated & Training Effectiveness ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
Stijloor GM to take back 5 Delphi plants, contract details show World News 0
T Prison Break Fans ?? - TV Show Coffee Break and Water Cooler Discussions 10
8 SMED Classroom Exercise to show operators the importance of SMED Lean in Manufacturing and Service Industries 10
D A true example of CAPA - Accident that show its cause and the corrective action Nonconformance and Corrective Action 8
