How do we prove that we are improving the continual improvement process?
Jen Kirley
Quality and Auditing Expert
#12
M Greenaway said:
Jennifer
You are talking about corrective and preventive action processes - these are processes which you can rightly improve on, the measure of which is improvement, or more improvement, or indeed no improvement.
The point is that continuous improvement is not a process, it is the output of a process.
Is it true that the results of the improvement process are its output, or am I confused about this?
Is a process to improve processes a concept? Or is it an effort to notice how one can do better, sooner, with fewer defects than before the corrective/preventive action occurred?
Can one call the shift away from corrective action and into preventive action a process into continuous improvement? PDCA, PDCA...
skumar
#13
The way I look at this is that if we improved a process by say 10% last year than it is a improvement.
If we keep on improving the same process 10% every year than it is continuous improvement.
But if we not only improve every year but the rate of improvement also keeps on increasing than we can say that we are improving our continuous improvement process itself.
How much is it possible in practice is another question.
Sandeep
Jen Kirley
#14
Sandeep
You said it as I understand it. As to how much is possible in practice depends on the organization's culture. If you can show a slope of improvement, mathematically I would expect it to turn into a curve over time.
But since new things always arise in whatever aspect: man, material and/or machine there are bound to be opportunities to improve all the time. Show that you are going about it better, and you are improving upon the improving process.
I don't expect most auditors would hit on more than the results of the improvement itself; as comments have gone in general, do that and I feel sure the element will be met. No one expects you to nuke this process!
#15
My original point was that the nesting of this idea is infinite, which is evidence of unclear thinking or belaboring the obvious. It's axiomatic that improvement means that something is demonstrably better than it was at some previous point. If continual improvement is to be indoctrinated (the term is used advisedly) into the culture of a company, it means that people must be given permission to innovate, and then be expected to do so. It must be a part of daily life, like eating and breathing. If that sort of culture exists, the only way it can be improved upon is by getting rid of people who, after having been given ample opportunity and encouragement to do so, refuse to think for themselves.
RoxaneB
#16
Here's how I look at your example...
How did you know what you wanted to improve and by how much and who would be involved and what resources were required? If your improvement of 10% was sheer luck and coincidence, then while you have an improvement, you have not applied the concepts of continual improvement. As Jennifer said...PDCA, PDCA.
The practice of continual improvement is quite easy, actually. You plan. You do. You check. You act. The difficulties arise when you start to deviate from the plan due to unforseen issues and taking proper action when the desired results are not achieved.
Ah, there's the kicker...allowing people to innovate. Easy to say, but not every culture is willing to share the tools of continual improvement amongst the ranks. But those that do...well...we're starting to see some impressive numbers, great team work (in and outside of team meetings) and an overall boost in morale and a willingness to learn (and question).
To teach the tools and skills involved in the continual improvement process to personnel at levels has been a bit of resource drain, but as the old saying goes "Short term losses. Long term gains."
Craig H.
#17
I think maybe we are missing something here. If we improve a process 10% this year, and a completely different process 10% next year, is that not continuous improvement? I think what the standard and common sense dictate is that we look at all of our processes and make a business decision concerning the risks of allowing each one to remain in its present state, or to decline, without any extra effort expended on behalf of that process. Then we decide which one(s) we should concentrate on first considering the risks involved and the objectives of the organization. The decisions made will change over time.
My point is that the need for continuous improvement does not exist in a vacuum, but should be interpreted within the context in which it appears within the standard. This addresses one of the (IMO valid) arguments against the previous versions of ISO 9000, that you can be certified and still ship junk. Having to show improvement over time, having to show that our business management system is EFFECTIVE, should pretty much lay that argument to rest.
Of course that assumes the effective application and enforcement of the tenants of ISO 9001, but that is another thread.
RoxaneB
#18
Very good points! :agree1: :applause: :yes:
My company looks at what we need to improve, where we can, the risks and benefits involved and develops a 1, 3 and 5 year improvement plan. This is done annually and the plans may change as our organization does.
Thanks for the reminder! :)
Sajjad Chaudhry
#19
I think, the act(s) of Improvement is a process. It has inputs in form of methods, procedures etc. resulting in issues, problems or simply opportunities for improvement. It has outputs in form of better procedures, operations, processes etc. The methods, techniques, approaches we use for converting inputs into outputs is the process of 'improvement'.
Now, the degree of success in converting inputs to outputs can be assessed for the efectiveness of the methods we used. Examples are reduced customer complaints, shorter cycle time etc.
The other measure is the effeiciency i.e. using less resources and achieving better results. The improved efficiency may be due to better methods, for example, for measuring customer perception and associated QFD, team approach towards improvement indicated or measured through employee suggestions program, better auditing (process) approach and follow up methods etc.
The above explanation can be supported with several practical examples that I have not got into for keeping my note short.
#20
All good observations, Sajjad, but this type of discussion reminds me of the two men who encounter a large carnivorous reptile and get eaten by it while arguing about whether it's a crocodile or and alligator. The spirit of and impetus for continuous improvement can't be quantified or codified or come into existence through spontaneous generation or by merit of festooning the walls with banners. If, by dint of leadership, the spirit and impetus exist, the rest will follow.
qualprod How to prove improvements? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
Q Do we have to prove a link between the mill and our raw material supplier? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
P How to Scientifically Prove the Importance of a Process - CMMI Process Areas Software Quality Assurance 7
B How to prove that an organization implements anti bribery policy IATF 16949 - Automotive Quality Systems Standard 8
C UDI Label Verification - How do we ensure the barcode is correct and prove it? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
S How to Statistically Prove 2 Dimensions are Related Using Minitab Software 18
U Sample size to prove parts are good with 99.73% confidence Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
L What needs to be done to prove compliance with RoHS and WEEE EU Medical Device Regulations 5
A Is MSA useful to prove a Measurement System after Relocation? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
P How to prove that Cr oxide makes a stent biocompatible (e-polished 316LVM) Manufacturing and Related Processes 9
P Testing a US device in Europe to prove Equivalence in a ?head-to-head? Study EU Medical Device Regulations 6
J Reliability Prove-out, Pass-Fail Testing Reliability Analysis - Predictions, Testing and Standards 2
K What would you give up to prove conformity and honesty? Internal Auditing 21
S ISO 17025 requirements not enough to prove NIST Traceability? ISO 17025 related Discussions 10
I Prove or disprove that a cube can be cut in 27 smaller cubes in less than 6 cuts Brain Teasers and Puzzles 14
M How do I prove I don't receive a controlled product? Ractopamine Hydrochloride Misc. Quality Assurance and Business Systems Related Topics 4
C Clinical Data to Prove Equivalence Other US Medical Device Regulations 4
U Can anyone prove that: 2x2=5 ? Coffee Break and Water Cooler Discussions 63
D Testing an Inspector to Prove Competency in Visual Inspection Records and Data - Quality, Legal and Other Evidence 2
S Lean System Developer - How should I work to prove myself? Lean in Manufacturing and Service Industries 19
D How to Prove and Explain to Consultant (Internal Auditor) and Manager? Internal Auditing 7
M Planning requirement 5.4: How should the management prove compliance ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
J How to prove that we conform to legal requirements Miscellaneous Environmental Standards and EMS Related Discussions 11
L Is there any way to prove a process is in control other than with a control chart? Statistical Analysis Tools, Techniques and SPC 6
L How do you prove you need resources? Misc. Quality Assurance and Business Systems Related Topics 5
J Finished Goods Testing - Using historical test data to prove finished goods OK Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
A Contract Review - How do you prove it? Contract Review Process 16
K Statistical Hypothesis Testing to prove signficant quality improvement or decline Statistical Analysis Tools, Techniques and SPC 6
Proud Liberal Improving low p-value Statistical Analysis Tools, Techniques and SPC 13
S Improving Quality inspection gate in one piece flow manufacturing process Manufacturing and Related Processes 0
Sidney Vianna ISO 9001 News Tirelessly Improving the Brand Integrity of ISO 9001 - Working Group under ISO TC 176 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 42
B Improving Behaviour Safety through Fun games Occupational Health & Safety Management Standards 2
T Training courses for improving 'Coaching and Mentoring skills' within Europe Training - Internal, External, Online and Distance Learning 1
N Improving my Quality Qualifications - What certifications, seminars, classes, etc. Career and Occupation Discussions 2
B Improving Safety Culture within an Organisation Occupational Health & Safety Management Standards 8
M Improving Quality in an Extrusion Blow Molding Company Quality Manager and Management Related Issues 2
T Best Career Improving Actions? Career and Occupation Discussions 3
L Improving the Quality of Work ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 20
S Excuses for Not Improving Quality Philosophy, Gurus, Innovation and Evolution 12
G Logo or design that would represent Spirit - Improving our Culture Quality Manager and Management Related Issues 1
N Improving Poor Communication with Customers Customer Complaints 6
B Customer Queue Problem - Improving Distribution of Service Misc. Quality Assurance and Business Systems Related Topics 12
M Improving Purchases and Sales Sheets Manufacturing and Related Processes 1
Marc Customer Service - Three Stories About Improving Customer Service Funny Stuff - Jokes and Humour 3
M Improving Employee Involvement in Company Sustainability Sustainability, Green Initiatives and Ecology 14
A Conducting a DOE in Minitab - Improving Surface Finish of an Impeller Using Minitab Software 10
A Benefits of Improving Lead Time on Closing Supplier Corrective Action Requests Preventive Action and Continuous Improvement 3
L Improving Internal Training Systems Training - Internal, External, Online and Distance Learning 4
Q Improving Technical Writing skills for CAPA Nonconformance and Corrective Action 7
M Interested in improving the FDA 510(k) system? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
