How do you approach the "Safe Launch" Process
bkirch
Could anyone share how they approach what i have heard called a Safe Launch process? In our company, the safe launch process happens when we are in the pre-PPAP phase on new work. So, each time we sample the new work for development, we have data that we gather or test that we conduct which we call a safe launch phase. For us we have three safe launch phases, the third phase happens at PPAP. The first two occur before PPAP. Is this a approach common, or does more of this type of activity happen after PPAP? Also, does anyone have an example of a record or questions that is used for the safe launch activity?
L
lk2012
the Safe Launch is usually triggered by a certain number of problems occurring during the pre-production (prototype) phase.
There's a really good material on this published by the German OEM's, have a look online for QMS training on Safe Launch / APQP from the likes of Continental or BOSCH.
hope this helps a bit
Lil
reunalla
I have a similar question.
Based on my previous experience all of my previous workplaces called "safe launch" an offline extra check. Everything online was "in process check" or "end of line check". The content difference was that safe launch had selected points in the product which needed to be rechecked with somebody out of the line with the same method or completely different method. (e.g SPC online - 100% measurement offline)
Now one of the responsible managers in my current workplace says that "safe launch" can be an online check with extra experienced workers, doing the same check which is already sold to the customer that we will do until the end of the production (in Control Plan without mentioning that it is safe launch for 90 days after SOP)
I found no reference in any standards and requirement yet what is the real approach on safe launch.
Also other debate I have: what is the meaning of a "safe launch plan"? My opinion is that SLP is a document which clarifies who, how, and how long will do the safe launch and what is the exit criteria. I as a internal auditor do not want to accept a CP as SLP with no wording in it which says something is "safe launch", no exit criteria.
Any opinion/advice?
Ron Rompen
When I read 'safe launch' I immediately think of the GM GP12 requirement - basically it is increased inspection (either frequency OR sample size, usually both) for a period of time after PPAP submission and approval, to ensure that the process is as stable as everyone presumed it is. Characteristics should be selected to reflect as broad a scope of the manufacturing process as possible; however this doesn't mean you have to reinspect EVERYTHING. Work with your SQA/SQE and find out what they expect for this.
optomist1
A Sea of Statistics
Well said......depending on the circumstances leading up to invoking "safe launch" measures, the requirements can be pretty onerous, i.e. a third party selected by the OEM (usually supplier pays), can be deployed at the point of manufacture to effectively "watch every step" of assembly, test, final checks, use of witness marks on parts to confirm step completion, leak check etc., at least for the first 90 days post launch date....as stated your SQE and Release Engineer usually discuss and prescribe what is required....some OEMs document these measures via a Quality Inspection Standard or similar documents....
optomist1
A Sea of Statistics
Folks, brain cramp a few days ago, pls see below corrected term below bolded Blue
Well said......depending on the circumstances leading up to invoking "safe launch" measures, the requirements can be pretty onerous, i.e. a third party selected by the OEM (usually supplier pays), can be deployed at the point of manufacture to effectively "watch every step" of assembly, test, final checks, use of witness marks on parts to confirm step completion, leak check etc., at least for the first 90 days post launch date....as stated your SQE and Release Engineer usually discuss and prescribe what is required....some OEMs document these measures via a Part Inspection Standard (PIS) or similar documents....
bobdoering
Stop X-bar/R Madness!!
Best thing to do is list your critical characteristics and any characteristics you have ever had a customer complaint on. Set up a reasonable time period, such as 6 weeks. Do a final inspection gaging of those characteristics (even if it is go/no go because you are looking for good/bad not control). As you reach 6 weeks of no occurrences of each characteristic, use that data to stop that check. Do it by line item, not wait until all checks are clean. Once you have shown no occurrences on the last check, safe launch is complete.
Not too hard. Protects the customer, and therefore protects you.
optomist1
A Sea of Statistics
to put a little finer point on this discussion, based upon my experience very similar scenarios:
SLP, often contains customer specific requirements, based upon each OEM, triggered by the previously described events, or if in the opinion of the OEM/SQE, the supplier's process although "PPAP'd", still possess an unacceptable degree of risk, such as a "new" process/operation, one that is relatively new to the point of manufacture....one of the SLP goals is to prevent, what some OEMs call Product Related Issues (PRIs) during manufacture, these usually lead to vehicles being temporarily being quarantined pending resolution of the PRI. PRIs are undesirable, as they usually have supplier charges/damages associated with the event
K "Supplier's multi-disciplinary approach to decision making" IATF 16949 - Automotive Quality Systems Standard 4
A Question regarding new VDA_AIAG fmea approach for process FMEA FMEA and Control Plans 0
M Risk-based approach to Test Method Validation for Design Verification? US Medical Device Regulations 5
Sidney Vianna IATF 16949 News AIAG/VDA harmonized approach to FMEA IATF 16949 - Automotive Quality Systems Standard 0
C. Tejeda Computer system validation approach for Minitab Statistical software Software Quality Assurance 11
A CAPA approach feedback 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
S NC and Deviation approach - please help Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 12
W Bracketing approach Problem Solving, Root Cause Fault and Failure Analysis 0
W Equipment Bracketing Approach US Food and Drug Administration (FDA) 0
I PFD (Process Flow Diagram) approach. Setup details as part of PFD? APQP and PPAP 5
T How should I approach REACH, CM, etc. as a job shop? RoHS, REACH, ELV, IMDS and Restricted Substances 18
A Migrating from whole product CE marking to modular approach CE Marking (Conformité Européene) / CB Scheme 5
D CE SaMD modular approach CE Marking (Conformité Européene) / CB Scheme 5
K MDSAP Audit Approach 2020 for Brazil Other Medical Device Regulations World-Wide 1
K MDSAP Audit Approach 2020 ISO 13485:2016 - Medical Device Quality Management Systems 4
DuncanGibbons Understanding the applicability of Design of Experiments to the IQ OQ PQ qualification approach Qualification and Validation (including 21 CFR Part 11) 5
G Any good examples of CAPA forms that include a risk based approach? ISO 13485:2016 - Medical Device Quality Management Systems 8
qualprod Best approach to get a real value as average? Statistical Analysis Tools, Techniques and SPC 6
DuncanGibbons FAA's Building Block approach to certification Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
G New CAPA Work Flow with Revised 8D Approach Process Maps, Process Mapping and Turtle Diagrams 35
R Bottom up approach versus system level ISO 14971 - Medical Device Risk Management 2
D Validation of existing equipment - Risk based approach example ISO 13485:2016 - Medical Device Quality Management Systems 3
qualprod Shortening processes complying with process approach ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
O Validation approach for a Photostability Chamber (used for fluid therapy and injectable drug products) Qualification and Validation (including 21 CFR Part 11) 1
Sidney Vianna NASA to Develop a Novel Approach for All-Electric Aircraft Using Cryogenic Liquid Hydrogen as Energy Storage World News 2
tony s What is the automotive process approach for auditing? IATF 16949 - Automotive Quality Systems Standard 2
C Usability IEC 62366-1:2015 and MDR 2017/745 - Risk based approach IEC 62366 - Medical Device Usability Engineering 1
M Informational EU – Medicinal products and medical devices: Coordinated approach in case of a withdrawal of the United Kingdom from the Union without a deal Medical Device and FDA Regulations and Standards News 0
M Informational USFDA draft guidance – A Risk-Based Approach to Monitoring of Clinical Investigations Questions and Answers Guidance for Industry Medical Device and FDA Regulations and Standards News 0
M APQC PCF (Process Classification Framework) and ISO 9001 - Processes Based Approach ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
S Risk Approach doesn't address External Issues (Auditor's Comment) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 30
Pmarszal ISO 19011:2018 - Risk Based Approach for planning, conducting and reporting of internal audits Internal Auditing 8
Q Questions about the Risk-based approach to QMS processes ISO 13485:2016 - Medical Device Quality Management Systems 17
N Do I need to approach galvanized steel sheet flatness issue with DOE? Problem Solving, Root Cause Fault and Failure Analysis 9
S ISO 13485:2016 - Risk-based Approach ISO 13485:2016 - Medical Device Quality Management Systems 3
S Risk based approach - Procedures already take a risk-based approach to QMS processes ISO 13485:2016 - Medical Device Quality Management Systems 3
S IATF 16949 - Manufacturing and Product Audit Approach IATF 16949 - Automotive Quality Systems Standard 19
S ISO 13485:2016 - How I can integrate a risk management approach in our SOPs ISO 13485:2016 - Medical Device Quality Management Systems 1
S Risk Based Approach for ISO 13485:2016 Form/Procedure ISO 13485:2016 - Medical Device Quality Management Systems 23
P Best approach to tackle difficult certifications Career and Occupation Discussions 2
C Does Japan accept the Bracketing Approach for Process Validation Japan Medical Device Regulations 1
armani How to approach ISO 9001:2015 Clause 7.1.6 when 3rd Party Auditing ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
alonFAI How to define a Risk Based Approach for Supplier Management per ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 1
B Risk Requirements to meet the explicit Risk Based Approach of ISO 13485:2016 Examples ISO 13485:2016 - Medical Device Quality Management Systems 21
A How do we implement a Process Approach ISO 13485:2016 - Existing GMP QMS Other ISO and International Standards and European Regulations 2
V When and How to apply the Bayes Success Run approach for Sample Size Determination Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
armani Quality Policy approach of ISO 9001:2015 Clause 5.2.1a ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
Ajit Basrur Could a bracketing approach be used for Gage R & R ? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
P CMM Equipment Validation and Qualification Approach ISO 13485:2016 - Medical Device Quality Management Systems 11
W ISO 9001, ISO 14001 and 18001 Integrated Approach ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
