P
How do you calibrate a VNA cal kit?
I'm talking about kits such as the Agilent/Keysight 85057B 2.4mm kit, or even a waveguide cal kit like the W11644A W-band kit. It's my understanding Agilent/Keysight just uses a common VNA which is in turn calibrated with a cal kit of exceptional uncertainty. I accept this, but I was considering a poor mans method...
If i use a non-calibrated kit to calibrate my VNA, then I use a calibrated verification kit to verify the VNA, doesn't that imply that the cal kit is good? The VNA wouldn't be able to correctly measure the verification kit without calibration from a good cal kit. The reason calibration exists is to answer the question, "how do i know it's good?" and it seems to me this method answers that.
Realistically, i would first calibrate/verify the VNA using a properly calibrated cal kit and verification kit. Then i would start over except use the non-calibrated cal kit. That way I know the VNA itself is not to blame should the verification fail.
I would say that is evidence enough, but, in addition to this, i could use a calibrated cal kit (same model as UUT) to cal the VNA, then proceed to measure the components from my non-calibrated kit. Is that 1:1? No? Then all I have to do is relax the test limits and make it at least 1:1. Label it as Limited/Special calibration, right? You might say the increased uncertainty could result in false pass components, but what does any of that matter as long as it can properly measure the verification kit components?
Any thoughts on this?
