How do you do "Validation of Process" of production?
Howard Atkins
Forum Administrator
#12
H.Singer said:
I am very confused by 7.5.2 and 7.5.2.1
Do we have to apply it to all the processes in production or not?
For example, we have one process only where the product itself is not measurable (or we'd have to break it). I understand we have to validate that process. But what about other processes where we can measure and monitor the output?
If we validate one process, do all the others have to be validated too??
:confused:
In TS 7.5.2.1 gives no lea way.
In ISO 9001 you are free to choose what you want as long as you can justify it
Rajeeva
Quality Manager, CMQ/OE, CQA
#13
ALFINSA said:
please I need help
I am very confused
how do you do "Validation of process" of production?
I think what you are asking is how the requirements of clause 7.5.2 are to be addressed.
Mr. Jason has addressed your concerns very well. In the earlier version, it was addressed under "special processes".
In construction industry, we apply this requirement for concrete works, welding works and painting works. We validate these processes in two stages.
1 stage of validation - Prepare the procedure, identify the equipments/ skilled manpower required, carryout trials and test them to ensure the desired results.
2 stage of validation - comes after the completion of warranty period (after 6 months/ one year as agreed with the Customer)
Regards,
Rajeev
senthilkumar
#14
All the production process needs to be validated irrespective of whether it can be tested / verified or not.
Why because, Even processes where output can be measured, We may or maynot check all the parts (100%) during production. Also by the time you held up with a nonfoncormity the process is over. So it is only a detection control.
So, by process validation we can assure that our process will yield correct output and it is a prevention type of control.
How to validate a process:
Example : Welding Process
Define & Establish the following:
Criteria for review: Welding strength, Welding bead thickness etc.
Criteria for approval: Write the specification to be achieved, Ex: 30Nm
Approval of equipment: Calibration, Machine capability, OEE required for m/c
Qualification of personnel: Define the per.qualification required for the welding process
Specific method / Procedure: Establish SOP / Control plan for welding, DOE etc.
Records: Applicable records as an outcome of the above
Revalidation: Define the situations when we'll revalidate the process.
By this we are validating our process inputs in order to get consistent ouput irrespective of whether the output can be checked or not.
I hope this will add some more clarity.
Senthil:agree:
K
kalyhan
#15
Not to beat a dead horse, but I've read all the TS 7.5.2 stuff (at least, I caught several different postings here) and some parts of 7.5.2 are still a little fuzzy. Someone was kind enough to post a msg stating that this clause is the most interpreted clause of TS and I could not agree more.
We recently passed out TS 16949 Stage 2. Just as soon as our corporate office fixes their NCR's, we will receive our certificate (Yeah!).
My question is in regards to our external auditor. He mentioned during the stage 2 "You may want to take a look at 7.5.2.". How vague can you be? :frust:
We are an OEM supplier for the truck plants. We have our control plans, instructions, procedures, PPAPs, etc. They have existed for years and we continually update them. We have weld criteria and certified welders. We validate/test & inspect the 1st part, last part off and in-process inspections per an AQL chart (for every process but wash!). I've racked my brain all morning trying to think of anything that we do not test or inspect and I'm drawing a blank.
Any suggestions as to what our auditor may have been referring to? I've known our auditor for a couple of years. Anytime I hear the "You may want to look at..", usually means he sees something out of whack and he gives us the opportunity to fix it before he writes it up next time.
Suggestions? Ideas?
:thanx:
Karen
mirrorcrax
#16
I think it would be reasonable and straight to the point if you asked the auditor straight off what he meant, especially if he's been around for a while, than have us try to guess what he meant
mjoakin
#17
Senthil:agree:
I was looking for this ... but have a question ... do we need to make this validations at planned intervals? e.g: every two months, or is this something we need to verify on a daily basis? We sew seat covers for GM. We have a procedure where the operator is asked to verify the first, middle and last piece, the operator knows the specs to be verified and they have the the equipment to do the measurements. I thought this was a way to validate the process, because I'm making sure that the sewings are correct, no loose thread tension or wide seams ... because sometimes until the cover is built you can detect these kind of defects. So, what do I need to meet this requirement? or do I need to convince my Auditor that I'm already validating the sewing process???
B ISO 9001 Clause 7.5.2 - Validation of Process for Production and Service Provision ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 29
S Validation of Production Process - Practical Example ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
K Process Validation of Low Volume Production of Medical Devices ISO 13485:2016 - Medical Device Quality Management Systems 9
D "Special Production Process" Validation and TS16949 Clause 7.5.2.1 IATF 16949 - Automotive Quality Systems Standard 5
K Process Validation - Production Line Transferring to a Different Facility Qualification and Validation (including 21 CFR Part 11) 16
H TS 16949 - 7.5.2.1 - Why does TS ask for process validation for all the production? IATF 16949 - Automotive Quality Systems Standard 5
mustomutlu Process Validation Final Report Other Medical Device and Orthopedic Related Topics 2
N Sterilization Protocol Change in Validation Process and further impacts ISO 13485:2016 - Medical Device Quality Management Systems 1
R PCBA process validation Qualification and Validation (including 21 CFR Part 11) 2
S Sterilization validation after changing sterilization process provider Qualification and Validation (including 21 CFR Part 11) 3
D Questions regarding process validation ISO 13485:2016 - Medical Device Quality Management Systems 6
A Validation of Forced Aeration Process ISO 13485:2016 - Medical Device Quality Management Systems 3
T ISO 13485 - Process validation at critical suppliers ISO 13485:2016 - Medical Device Quality Management Systems 7
K Software Validation for Measurement Tools used in Process Validation ISO 13485:2016 - Medical Device Quality Management Systems 2
P Design verification driven by new equipment. How is this different than process validation? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
Stoic Are any medical device companies using the 2011 FDA process validation guidance instead of GHTF/SG3/N99-10:2004? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
G Devices from IQ, OQ or PQ process to be used for verification, validation and summative? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
N Design Verification & Process Validation - Statistical sample sizes Design and Development of Products and Processes 2
E Equipment Qualification - IQ/OQ per ISO 13485:2016 section 7.5.6 Process validation ISO 13485:2016 - Medical Device Quality Management Systems 7
B API Q1 5.7.1.5 Process Validation - Machining, heat treating, Manganese Phosphate and Zinc Plating Manufacturing and Related Processes 2
N Validation procedure, Major NC CAP - Equipment Validation process is not effective ISO 13485:2016 - Medical Device Quality Management Systems 5
D ISO13485:2016 7.5.6 Process Validation Responsibilities ISO 13485:2016 - Medical Device Quality Management Systems 1
Z Who is responsible for writing the validation of a new process? Manufacturing and Related Processes 7
M Requirement for manufacturing process validation in IATF 16949 IATF 16949 - Automotive Quality Systems Standard 8
E Sampling plan for orthopedic implant - Process Validation Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
Z Class 2 medical device - Process Validation - Test sterile or non-sterile units? Qualification and Validation (including 21 CFR Part 11) 4
T ISO 13485:2016 - Processes exempt from process validation ISO 13485:2016 - Medical Device Quality Management Systems 12
L Injection Moulding Process (Special Process) Validation Food Safety - ISO 22000, HACCP (21 CFR 120) 2
K Is Mold qualification / process validation always required? Manufacturing and Related Processes 7
R Process Validation on CNC Lathe and Milling machining process Design and Development of Products and Processes 1
Q Release of the first batch of a cleared product before process validation 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
R Process Validation sample size selection Statistical Analysis Tools, Techniques and SPC 0
P Auditing "process validation" process 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
E Cleaning Validation Process of Non-Sterile Implants and Instruments Other Medical Device Related Standards 2
W Design and Process Validation - Different? ISO 13485:2016 - Medical Device Quality Management Systems 6
A Supplier - Process Validation Manufacturing and Related Processes 3
M Medical Device Process validation, Validation of excel spreadsheets used for process Other Medical Device and Orthopedic Related Topics 4
V Tyvek packaging for Medical device process validation Qualification and Validation (including 21 CFR Part 11) 2
L Process Definition and Process Validation 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
S Can we sell units that were chosen for process validation? ISO 13485:2016 - Medical Device Quality Management Systems 6
S How do I do a Process Validation for soldering process Manufacturing and Related Processes 5
S Process validation when changing location ISO 13485:2016 - Medical Device Quality Management Systems 10
A Process Validation of QMS Software ISO 13485: 2016 Cl. 4.1.6 ISO 13485:2016 - Medical Device Quality Management Systems 26
P Root Cause for a Process Validation Batch Failure 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
GoSpeedRacer Validation of Processes 7.5.6 - Do cosmetic welds need process validation? ISO 13485:2016 - Medical Device Quality Management Systems 3
A Is Aeration Process in ETO Sterilization Validation Required? Manufacturing and Related Processes 7
C Does Japan accept the Bracketing Approach for Process Validation Japan Medical Device Regulations 1
A Robotic Sanding and Painting Process Validation Manufacturing and Related Processes 5
alonFAI Gamma Irradiation Process Validation Help Other Medical Device Related Standards 2
J Where does process validation fit within design & development? Design and Development of Products and Processes 7
