How do you identify the wrong orientation in complex wiring harness?
mechie
Can anyone help me how to detect wrong orientation in a complex harness.. I would appreciate if any one can help..:agree:
Marc
What do you mean by wrong orientation? The wrong wires in a portion of the cable? If you can give me a bit more information about what you want to check I may be able to help.
mechie
In a harness manufacturing company when complex harnesses are made there would be more than 50 connectors involved where wires of back & white are inserted some times balck instead of white is inserted in a connector.. Not only complex even in simple harness sometimes we tend to make this sort of mistake. How to get rid of this?
mechie
Freinds my another question is " Is anyone aware of terminal microsection?" could anyone help me on this subject...
Marc
So the real question is how to prevent assembly mistakes?
harry
Mistake (error) proofing?
Microsections
A microsection allows the connector and wire combination to be assessed. It also allows the tool setting to be confirmed for a wire/termination combination which may be outside the crimp terminals specification. It can easily show up under or over crimping as well as cracking of the crimp barrel, lifting of the plating or uneven crimping.
A microsection can be produced in less than an hour if all the materials are available in the company. It can be useful technique if problems are being seen during other tests, like pull off or voltage drop measurement. Basically the crimp is mounted in a mould and epoxy resin is used to encapsulate the terminal prior to grinding the sample to the point of interest. This is normally at the point of compression. Ideally the section is ground to the centre of the compressed area and then examined. Which provides the possibility of grinding the section further if there are any areas of concern during initial preparation of the sample.
The section should show complete compression with the wire taking up and filling the cavity in the crimp barrel. The tool compression should be even on each side of the crimp and there should be no damage to the plating on the crimp terminal or any evidence of cracking of the barrel.
bobdoering
Stop X-bar/R Madness!!
Yes! any solution or piece of idea which you could help me...
Most people that do harnesses use a board with clips to lay out all of the correct colors, lengths, locations, etc., prior to binding. Seems to be a common approach. Not sure if it error proofs. TO do that you might pass a small current through the holding clips, and if the correct ends are in the correct locations a green light would allow to proceed.
bobdoering
Friends my another question is " Is anyone aware of terminal microsection?" could any1 help me on this subject...
Yes, we do terminal microsectioning, also. Any specific question?
mechie
Yes, the current practice is the continuity test as the one you mentioned but, it is not a fool proof method.. this is not helping us to get rid of this...
R Identify Medical Device characterstics as Annex C of ISO 14971 Risk Management ISO 14971 - Medical Device Risk Management 5
T ISO 9001 8.5.2. - Identification and traceability to Identify Outputs - Services ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
U When do we identify Residual Risk? Risk Management Principles and Generic Guidelines 11
D How to Identify the Risks and Opportunities required for QMS Processes? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
D How to identify and confirm that the developed device fall under Israel electro medical device category Other Medical Device Regulations World-Wide 0
D How to identify and confirm that the developed device fall under Israel electro medical device category Other Medical Device Regulations World-Wide 1
E How do you identify what standards a country recognizes outside of FDA, EU, Health Canada Other Medical Device Related Standards 1
Marc Can you identify this moth? 19 January 2019 After Work and Weekend Discussion Topics 6
K Please help identify appropriate statistical treatment Statistical Analysis Tools, Techniques and SPC 13
D Help identify a Nationally Recognized Testing Laboratory (NRTL) (UL) certified lab General Measurement Device and Calibration Topics 3
T To Identify the Applicable MDD Directive - Prepared blood smear EU Medical Device Regulations 13
A Requirement to Identify Changes to record in ISO 13485 : 2016 ISO 13485:2016 - Medical Device Quality Management Systems 4
R AS9100D Cl. 8.4.2 - Identify Raw Material as a Significant Operational Risk AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
C How to Identify Counterfeit Medications (drugs)? US Food and Drug Administration (FDA) 5
P How to identify the Management Representative ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
T How to identify requirements for 'Incoming inspection' Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
M How to identify software configuration items in a BOM Quality Manager and Management Related Issues 3
S Resource Planning/How to identify IATF 16949 - Automotive Quality Systems Standard 1
V How to identify Customer Specific Requirement If is not provided by Customer Customer and Company Specific Requirements 5
B How to identify Six Sigma Yellow Belt Project Six Sigma 4
C Must we identify steps taken to identify the Root Cause of a failure Nonconformance and Corrective Action 15
G How to identify Key Characteristics (KC) in a Design FMEA (DFMEA) FMEA and Control Plans 2
X Existing Toolroom Process Validation - Need to identify clauses addressed. Manufacturing and Related Processes 7
C How Can I Identify 304 Stainless Steel? Manufacturing and Related Processes 6
Geoff Cotton How to identify Stakeholders in a Company Quality Tools, Improvement and Analysis 9
M How to identify CTQ / Critical Characteristics using the DFMEA approach. FMEA and Control Plans 3
R 3rd Party Audit Comment - Identify ISO Clauses/Sub Clauses to each Process Quality Management System (QMS) Manuals 45
J AS9100:C Risk Management - Identify the Risk for the Sales/Contract Processes AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
T How to Identify Taper Gages without potentially damaging them General Measurement Device and Calibration Topics 5
N How to Number (Identify) and Index Forms Document Control Systems, Procedures, Forms and Templates 1
A DoC for Software Product - How can I identify the specific units that are covered? EU Medical Device Regulations 6
T How to Identify "Observation" in Internal Audits? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 26
X Audit Findings - The Process/Clause Matrix does not identify all the processes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 30
S Identify Environment Aspect by Activities Approach ISO 14001:2015 Specific Discussions 4
T Can't identify my company's "Key Process" Process Maps, Process Mapping and Turtle Diagrams 27
B Effectiveness of 200% Visual Inspection to Identify Defects and Defectives Inspection, Prints (Drawings), Testing, Sampling and Related Topics 32
N Definition IDENTIFY and DETERMINE - What is the technical difference between the words Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 64
A Procedure to Identify Potential Emergency Situations and Accidents Miscellaneous Environmental Standards and EMS Related Discussions 4
D AS9102 - How to title the attached form and how to identify the characteristics AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
kedarg6500 How to Identify Critical to Quality Characteristics (CTQ) FMEA and Control Plans 2
Le Chiffre At what point do you need to identify a U.S. Agent - 510(k) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
M New to AS9100 - Clause 7.5.3 - Do you have to identify each part produced AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
S Form to identify status of product on the production floor. IATF 16949 - Automotive Quality Systems Standard 5
L Special Characteristics - What if the customer does not identify any SCs? FMEA and Control Plans 5
W How do you address clause 4.1 General requirements - Identify the processes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 21
S CE Mark using Registered Trademark to identify the legal manufacturer EU Medical Device Regulations 6
B Determine vs. identify (as in clause 4.1 a), any differences? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
B How to identify the processes needed for quality management system ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
I Skill Matrix Format as a Tool to Identify Training Needs Document Control Systems, Procedures, Forms and Templates 1
F How Can I Identify any Drawbacks of 8D Problem Solving Methodology Quality Tools, Improvement and Analysis 5
