How do you identify your heat treat capability study samples?
ASchmidt
Registered Visitor
I need to do a cap study on 300 consecutive pieces to evaluate growth. Normally I would engrave the numbers on them, because most of our heat treated parts get ground. However this one doesn't, and I don't want to have to scrap 300 parts because they are engraved. Our heat treater can segregate the 300, but can't guarantee that we will get them back in sequential order. Does anyone have another method of identifying parts in an instance like this?
If the samples are being taken by an outside source, you have no guarantees as to sequence in any event, but without at least a rough description of the parts, including size, it's hard to offer any advice.
Wes Bucey
I always worked closely with my heat treater, often making arrangements to be on site when my batch was scheduled to run to watch the process like a hawk.
(Sometimes, that meant sleeping on a cot in my office until 2:00 am, then driving over two blocks to go in the treater's employee entrance.)
As Jim Wynne writes, much depends on product shape. Depending on various circumstances, parts may be racked or just left flat on a tray.
When we had parts to study that would not be undergoing further processing after heat treating, we used wire collars with numbered tags (our heat treater supplied these, but they are readily obtainable from a variety of sources.)
I don't recall "growth" being an issue as much as problems arising from location within the furnace, style of rack, or warping caused by internal stresses created during machining, relieved during heat treating. We created a "map" of the tray or rack, showing where the numbered pieces were located.
Wesley Richardson
Wes R
Hi ASchmidt,
You did not state what type of heat treating, what material, the temperatures, or the atmosphere/environment.
In addition to the tags attached by wires or the rack position as stated by Wes Bucey, you can also use heat sticks. These are like crayons, but have specific melting temperatures. If you use a stick with a melting temperature above the highest temperature that you use, the markings will still be on the part. You would need to remove the marking by some post-heat treatment process, such as light sanding or sand blasting. Note this method will not work if you use molten salt baths or are doing nitriding or carburizing. In the case of salt, the salt will remove the marking. In the case (get it?) of surface hardening, it will affect the process.
There are many types of heat treating processes. If you have a quench, that may also remove the markings. You may also be able to mark an interior or end surface, depending on your part.
Growth in size is due to either a change in shape due to stress-relieving (Wes Bucey) or oxidizing, carburizing or nitriding. In all of these latter cases, the growth is because of diffusion of atoms into the base material, causing an increase in size. The amount of increase is usually thousandths of an inch or less, and predominantly near the surface. A similar effect can come from physical vapor deposition (PVD) or chemical vapor deposition (CVD).
Wes R.
R Identify Medical Device characterstics as Annex C of ISO 14971 Risk Management ISO 14971 - Medical Device Risk Management 5
T ISO 9001 8.5.2. - Identification and traceability to Identify Outputs - Services ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
U When do we identify Residual Risk? Risk Management Principles and Generic Guidelines 11
D How to Identify the Risks and Opportunities required for QMS Processes? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
D How to identify and confirm that the developed device fall under Israel electro medical device category Other Medical Device Regulations World-Wide 0
D How to identify and confirm that the developed device fall under Israel electro medical device category Other Medical Device Regulations World-Wide 1
E How do you identify what standards a country recognizes outside of FDA, EU, Health Canada Other Medical Device Related Standards 1
Marc Can you identify this moth? 19 January 2019 After Work and Weekend Discussion Topics 6
K Please help identify appropriate statistical treatment Statistical Analysis Tools, Techniques and SPC 13
D Help identify a Nationally Recognized Testing Laboratory (NRTL) (UL) certified lab General Measurement Device and Calibration Topics 3
T To Identify the Applicable MDD Directive - Prepared blood smear EU Medical Device Regulations 13
A Requirement to Identify Changes to record in ISO 13485 : 2016 ISO 13485:2016 - Medical Device Quality Management Systems 4
R AS9100D Cl. 8.4.2 - Identify Raw Material as a Significant Operational Risk AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
C How to Identify Counterfeit Medications (drugs)? US Food and Drug Administration (FDA) 5
P How to identify the Management Representative ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
T How to identify requirements for 'Incoming inspection' Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
M How to identify software configuration items in a BOM Quality Manager and Management Related Issues 3
S Resource Planning/How to identify IATF 16949 - Automotive Quality Systems Standard 1
V How to identify Customer Specific Requirement If is not provided by Customer Customer and Company Specific Requirements 5
B How to identify Six Sigma Yellow Belt Project Six Sigma 4
C Must we identify steps taken to identify the Root Cause of a failure Nonconformance and Corrective Action 15
G How to identify Key Characteristics (KC) in a Design FMEA (DFMEA) FMEA and Control Plans 2
X Existing Toolroom Process Validation - Need to identify clauses addressed. Manufacturing and Related Processes 7
C How Can I Identify 304 Stainless Steel? Manufacturing and Related Processes 6
Geoff Cotton How to identify Stakeholders in a Company Quality Tools, Improvement and Analysis 9
M How to identify CTQ / Critical Characteristics using the DFMEA approach. FMEA and Control Plans 3
R 3rd Party Audit Comment - Identify ISO Clauses/Sub Clauses to each Process Quality Management System (QMS) Manuals 45
J AS9100:C Risk Management - Identify the Risk for the Sales/Contract Processes AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
T How to Identify Taper Gages without potentially damaging them General Measurement Device and Calibration Topics 5
N How to Number (Identify) and Index Forms Document Control Systems, Procedures, Forms and Templates 1
A DoC for Software Product - How can I identify the specific units that are covered? EU Medical Device Regulations 6
T How to Identify "Observation" in Internal Audits? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 26
X Audit Findings - The Process/Clause Matrix does not identify all the processes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 30
S Identify Environment Aspect by Activities Approach ISO 14001:2015 Specific Discussions 4
T Can't identify my company's "Key Process" Process Maps, Process Mapping and Turtle Diagrams 27
B Effectiveness of 200% Visual Inspection to Identify Defects and Defectives Inspection, Prints (Drawings), Testing, Sampling and Related Topics 32
N Definition IDENTIFY and DETERMINE - What is the technical difference between the words Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 64
A Procedure to Identify Potential Emergency Situations and Accidents Miscellaneous Environmental Standards and EMS Related Discussions 4
D AS9102 - How to title the attached form and how to identify the characteristics AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
kedarg6500 How to Identify Critical to Quality Characteristics (CTQ) FMEA and Control Plans 2
Le Chiffre At what point do you need to identify a U.S. Agent - 510(k) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
M New to AS9100 - Clause 7.5.3 - Do you have to identify each part produced AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
S Form to identify status of product on the production floor. IATF 16949 - Automotive Quality Systems Standard 5
L Special Characteristics - What if the customer does not identify any SCs? FMEA and Control Plans 5
M How do you identify the wrong orientation in complex wiring harness? Manufacturing and Related Processes 21
W How do you address clause 4.1 General requirements - Identify the processes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 21
S CE Mark using Registered Trademark to identify the legal manufacturer EU Medical Device Regulations 6
Bilijaf Determine vs. identify (as in clause 4.1 a), any differences? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
B How to identify the processes needed for quality management system ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
I Skill Matrix Format as a Tool to Identify Training Needs Document Control Systems, Procedures, Forms and Templates 1
