How does a Business use the 4 pillars of Quality Management
terryNg
I just wondering how does a business use the 4 pillars of quality management which is quality control, quality assurance, quality improvment and quality planning ?
Jen Kirley
Quality and Auditing Expert
Re: 4 pillars of Quality management
Welcome to The Cove, terryNg! :bigwave:
That is a big question. Let me see if I can give you an answer in less than 20 minutes, heh.
Quality planning is a business planning its activities so as not to make mistakes. Plan.
Quality assurance is the set of activities that make up the planning; Wikipedia says "All those planned or systematic actions necessary to provide enough confidence that a product or service will satisfy the given requirements for quality." Do.
Quality Control is a business looking at its process outputs to make sure they are good. Testing, inspections, and checks are developed so a business can know if what it's doing is accurate. Check.
Quality improvement is looking at the results of all these things working together and putting in place changes that will help the business make fewer errors than before. Act.
Thus these four pillars--Plan, Do, Check and Act are repeated in cycles, with the intended benefit of fewer problems each time.
I hope this helps!
terryNg
thanks jeniffer..ur answer do help me a lot. Beside that do u have any idea how's the ISO 9001 address customer satisfaction in general ?
Jen Kirley
At a minimum, customer satisfaction is called out in 5.2, which says Top management shall ensure that customer requirements are determined and are met with the aim of enhancing customer satisfaction
5.6.2 calls out a requirement for customer feedback. What sort of feedback you use is your choice, so long as it is effective.
5.6.3, 6.1, 7.2.1 and 7.2.2 require the business to know what its customers require.
7.2.3 involves communications with customers, and 7.5.4 deals with safeguarding any customer's property used in your business's processes.
8.2.1 and 8.4 talk about monitoring and analyzing customer satisfaction. 8.5.2 deals with handling customer complaints.
8.3 deals with nonconforming material, including the customer's role in its release (if any).
In short, ISO gives some requirements for understanding what the customer wants, designing the processes to make sure it happens, knowing if you've done it well, dealing with the results, asking for and responding to feedback, and controlling the product and anything they've lent you (such as special inspection equipment) to do all this.
bchang
How do the 8 principles of Quality assist in ISO-9001? In what way are they addressed in ISO 9001?
The 8 principles will be:
1. All business processes have an outward customer focus wanting to understand and deliver their customer’s current and future needs.
2. Leadership at all levels toward achieving the organisations objectives – role model; shared values; shared vision.
3. Fully involve people in accomplishing the organisation’s aims.
4. Use well defined processes to meet the needs of interested parties by applying resources to perform activities that produce the required outputs.
5. Systematise to coordinate and manage interrelationships and interactions amongst the processes to maximise efficiency and effectiveness.
6. Adopt continual improvement as a regularly repeating requirement in order to seek improved performance, new targets, reduced variation, and new products.
7. Make decisions based on facts using analysed data collected by method and equipment whose integrity can be relied upon.
8. Establish mutually beneficial supplier relationships that reflect the interdependence of suppliers and supply chains to the organisation.
Thanks for the answering.
Randy
May we ask why this is necessary for a student? Your post as well as others from Perth look a bit suspicious and we really wouldn't be guilty of doing your assignments for you.
bchang
Oh, it has nothing to do with assignment. It is just part of the lecture notes that we do not really understand. We need some idea on which clause of the ISO9001 to look for, regarding those 8 principles [as future reading before the class].
Randy
You'll find pieces and parts of those 8 Principles addressed throughout ISO 9001.
There is no "Classics Illustrated" version. The entire document is about achieving customer satisfaction and the things necessary to do so within a QMS.
A What does a good business practice Process Audit look like for AS9100D? Process Audits and Layered Process Audits 9
D Does Record Control apply to the company business processes as well? Records and Data - Quality, Legal and Other Evidence 6
J Does my company's Business Plan Contents comply with requirements of TS 16949? IATF 16949 - Automotive Quality Systems Standard 2
G Does ISO 9001 require a procedure for every part of the business? Document Control Systems, Procedures, Forms and Templates 8
C Does auditing improve a Quality or Business System? Internal Auditing 7
D What does "Customer Business Plan" in the AIAG APQP manual mean? APQP and PPAP 0
B Does accreditation add value to business? ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 20
Paul Simpson Does your External Audit reflect your business systems? General Auditing Discussions 40
Q Definition BOS - Business Operating System - Does BOS have any relation to Ford's QOS? Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 1
E Does QS9000 really improve the business results? QS-9000 - American Automotive Manufacturers Standard 4
D Does Manufacture can submit CE mark application under MDD with NB for his New product after May 2020? EU Medical Device Regulations 3
A What does this sentence "this symbol shall be used in the orientation shown" mean in ISO 780:2015? Other Medical Device Related Standards 4
L Turkish Requirements - Does the Software need to be translated? CE Marking (Conformité Européene) / CB Scheme 2
J Does Pakistan Medical Device Import License allows parallel import? Other Medical Device Regulations World-Wide 0
BeaBea Interesting Discussion Where Does Marketing/ Advertisement of Products fit in to ISO 9001? Process Maps, Process Mapping and Turtle Diagrams 35
P Does anyone have a API Q1 Documentation Package? Quality Management System (QMS) Manuals 1
N What is our product classification? (Does Unclassified classification still exists) Other US Medical Device Regulations 14
C Does a CE mark infer meeting all applicable standards? CE Marking (Conformité Européene) / CB Scheme 4
N Small Company - Internal audit process - Who does the audit? Internal Auditing 16
J Does anyone have an excel IATF 16949 Internal Audit checklist I could use? IATF 16949 - Automotive Quality Systems Standard 7
A Does AS9100 require traceability to operators performing the work? AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 4
I Does anybody use Detection in medical device Design FMEA? ISO 14971 - Medical Device Risk Management 18
A EN ISO 14971:2019 does not include the Annex Zs ISO 14971 - Medical Device Risk Management 4
Watchcat Does "Similar Device" = "Predicate"? EU Medical Device Regulations 7
C Document Control Stamps - Does anyone still stamp their documents? Document Control Systems, Procedures, Forms and Templates 21
Y Does Solidworks (2D/3D drafting modules) need validation? Other Medical Device and Orthopedic Related Topics 5
M Definition Open Audit - What does an Open Audit mean? Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 3
I Does training have to be written? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
P What does UPH/m² mean? Quality Tools, Improvement and Analysis 3
L "IATF-Compliant" IATF 16949:2016 certification? What does this mean? IATF 16949 - Automotive Quality Systems Standard 13
D Why does Official Journal list superseded standards? EU Medical Device Regulations 6
B Record Management - Does the QMS need to control templates of records? Records and Data - Quality, Legal and Other Evidence 17
MDD_QNA QR Code Standard ISO/IEC 15417:2007 - Does anyone use it? Other Medical Device Related Standards 3
R Does any here use an internal auditing tool that works on different platforms? Internal Auditing 3
Sidney Vianna IAQG SCMH explains "positive risk"..........but does it? AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 3
D Where does "as far as possible" stop? FMEA - EN 14971 ISO 14971 - Medical Device Risk Management 29
W Does anyone have an API Q2 checklist for internal auditing? Oil and Gas Industry Standards and Regulations 1
L External power supplies: How close does the safety report have to match the end-use application? IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
Watchcat Does 820.30 include the manufacturing process? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
Watchcat Does ISO 13485 7.3 include the manufacturing process? ISO 13485:2016 - Medical Device Quality Management Systems 14
R When does the FDA consider a component a medical device? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 17
B Does EN ISO 15223-1:2016 include the graphic symbols to be added to software and IFU? Other Medical Device Related Standards 9
DitchDigger Boston Fire Code: Who Does What? (CAL TB 117-2013; CAL TB 133) Occupational Health & Safety Management Standards 2
GreatNate Metrotom - Does anyone have any exposure to the Zeiss Metrotom 800 or 1500? Manufacturing and Related Processes 0
G Is ISO 9001:2015 certification worth it for a company that does only contract manufacturing? Quality Management System (QMS) Manuals 14
K EU MDR Rule 11 - Does the 'Risk logic' used in Rule 11 conflict with that used in the other rules? EU Medical Device Regulations 2
C Does ISO 9001-2015 have a requirement for manufacturing equipment to be numbered? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
William55401 How Often Does FDA State Consultant Recommended in a Pharma WL? US Food and Drug Administration (FDA) 1
