How does a gas turbine work on diesel fuel?
japayson
Authors at Wikipedia have written an article about the gas turbine. Search ""gas turbine" there. Understand that the gas involved is air. Various fuels are used, including natural gas but more often the fuel is a petroleum distillate similar to "kerosene". Gas turbines are used as aircraft engines, in military armored vehicles, and to power ground based generators, for a few examples. It is called a gas turbine in contrast to a steam turbine.
optomist1
A Sea of Statistics
depending on the power-plant and the grade of Diesel...if it does fire up...there will be high levels of hydrocarbons, pollutants...etc. Diesel is heavy, Jet A, Jet B, JP1, JP 4 etc are light end distillates. Diesel is in relative terms pretty viscous as well, might well affect the fuel pump/filtration systems...and below a good link for civil Jet fuels..
Civil Aviation Fuel | Jet Fuel Specifications | Shell Global
Randy
Most modern turbines (especially in military use which really are no different than civilian turbines for like equipment) run JP8 which is roughly the same as DS2 for ground equipment........No real problem other than temperature management.......... It all happens through atomization/vaporization......... I'm a aircraft turbine mechanic amongst other things and I've experienced aircraft operating on regular diesel
Military Jet Fuel
Thank u everyone, but my question basically is about power plant gas turbines and I want to actually know that what is the mechanism behind gas turbine if we use diesel instead of gas and how does a gas turbine work on diesel (working). For example if a power plant is in shortage of gas and it uses High Speed Diesel (HSD) as an alternate fuel, what makes the gas turbine work on diesel?
Gas turbines operate on a multitude of fuels, from liquid to gaseous states. Actually, many industrial gas turbines have dual-fuel capability built-in the equipment.
Can you please explain to me that what is the mechanism behind dual fuel capability or the working behind it in detail. Thank you.
Randy
There is virtually no difference what fuel is used and there are no changes in the "mechanism" for different fuels. Basically, if it'll burn you can run it in a turbine and the only major concern are temperatures of the combustion gasses and exhaust. You'll see references to TGT, EGT and other acronyms with "T" being the monitored temperatures. I've gone from running, Jet A, Jet B, JP4, JP8, DS2 and gasoline in the same turbine in a helicopter without damage or problem.
A turbine doesn't know what it's being used for nor does it care.
You're concern isn't the turbine but the fuel storage/feed process or getting the fuel to the turbine in your case changing from a gas to a liquid and back and that's just basic engineering with a couple lines, valves, regulators and switches.
Not advertising................. multifuel turbine engine - Bing video
Sidney Vianna
Post Responsibly
The OEM's spend hundreds of millions of dollars in combustion engineering to optimize combustion efficiency, reducing emissions, maintaining equipment reliability and safety. Nobody here will give you technical knowledge that is proprietary.
G Does anyone know about tobacco-free nicotine pouches? US Food and Drug Administration (FDA) 0
cgaro62 Does FDA apply to a non-medical 13485 certified custom manufacturing company? ISO 13485:2016 - Medical Device Quality Management Systems 11
R Does anyone use iQMS for their ISO based document control? Manufacturing and Related Processes 1
V How many hrs does it take to create a Technical File (TD)? EU Medical Device Regulations 4
M How does FDA determine OAI and VAI after inspection? ISO 13485:2016 - Medical Device Quality Management Systems 0
G Does TPI agencies comes under outsourced process as per Q1 Oil and Gas Industry Standards and Regulations 11
N FPY requested for an industry that does not have rework IATF 16949 - Automotive Quality Systems Standard 4
William55401 21 CFR 11 Password Aging - What does "periodically" revised mean in your org? Qualification and Validation (including 21 CFR Part 11) 3
I CQI-15 Welding System Assessment 2nd edition - Does not require Ultrasonic Welding anymore? Customer and Company Specific Requirements 0
Ajit Basrur Does "Refurbishment" fall under "Service"? ISO 13485:2016 - Medical Device Quality Management Systems 13
T Does marketing company require CE mark if manufacturer has CE mark on product? EU Medical Device Regulations 5
Watchcat REGULATORY WATCHCAT De Novo Post-Mortem 6 – How Does This Even Happen? Other US Medical Device Regulations 0
T What does VW mean by annual requalification? Customer and Company Specific Requirements 3
I Does BSI require suppliers to be ISO 9001 Certified? EU Medical Device Regulations 12
Watchcat Does Regulatory Affairs put the "no" in innovation? Other US Medical Device Regulations 14
Q Does anyone know what this call out means? Manufacturing and Related Processes 3
K COPLANARITY: Composite profile tolerance on multiple surfaces- what does" lower dimensional reference frame tolerance" control? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 11
P Does FDA require certification for quality system internal audit for auditor? Qualification and Validation (including 21 CFR Part 11) 1
H Does anyone has feedback on a notified body for small companies? EU Medical Device Regulations 3
M Does 4.5 - Alternative RISK CONTROL apply to the Particular Standards? IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
E Does IVD need to integrate with hospital IT infrastructure? Medical Information Technology, Medical Software and Health Informatics 2
D What does a level 1 (PSW) PPAP actually promise? APQP and PPAP 19
R GS1 DataMatrix code does not meet GS1 Specification EU Medical Device Regulations 0
M Does the scope of ISO 9001:2015 applies to tenders, pricing and sales department of a medical devices distributor? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
K Why does load cell supplier requires force verification General Measurement Device and Calibration Topics 3
M Does C=0 strictly mean 1 bad, all bad, all the time? ISO 13485:2016 - Medical Device Quality Management Systems 6
C Does a medical device active (zinc oxide) needs BPR registration in EU? Other ISO and International Standards and European Regulations 6
D Does Risk Management apply to re-labeler (MDR) EU Medical Device Regulations 1
Ed Panek Does this FDA Requirement Apply to international (not USA) distributors for USA based manufacturing companies? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
S Does anyone have a checklist to prepare for ISO 13485, Stage I audit? ISO 13485:2016 - Medical Device Quality Management Systems 3
S Does a refurbished product required a new UDI? US Food and Drug Administration (FDA) 3
D Change to labelling - does it require a new 510(k)? US Food and Drug Administration (FDA) 5
M What does "constantly" mean ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
N Does anyone use SGS for ISO 13485 / CE certification Registrars and Notified Bodies 0
G Does FDA allows remote approvals of quality documentation. Is there any specific guidance on signing any quality records remotely? Document Control Systems, Procedures, Forms and Templates 1
B Does FDA Registration QSR need to cover non-medical devices for contract repackager? US Food and Drug Administration (FDA) 1
0 To which part of 13485 does this refer? ISO 13485:2016 - Medical Device Quality Management Systems 3
lanley liao Does the customer`s trademark belong to customer-supplied property? Oil and Gas Industry Standards and Regulations 2
G What does performance specification include? US Food and Drug Administration (FDA) 1
W Where does a coatings and paint company fall in IATF? IATF 16949 - Automotive Quality Systems Standard 5
C Does an accessory need an IFU if it use is discussed in the Parent device IFU? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
S How long does it take to register a product with MHRA? UK Medical Device Regulations 14
M Quality Manual - Where does Revision History Section go? Document Control Systems, Procedures, Forms and Templates 8
