Andrews said:
100% inspection is for a diameter 15.87/ 15.83. The cause for defect in this characteristic is plating thickness variation on this component.
JSW05 and Mike S are both correct in that there is an slmost infinite range between the possible and what you get. Variables that influence outcomes include, among others:
1. How much time you are willing to devote to the inspection.
2. Inspecting each part once, in one place, to 50 times in 50 places--the detail you are willing to go to.
3. The tools, equipment and environment you use--their sensitivity and accuracy. Hot environments may induce a slight expansion coefficient effect in some materials.
4. The inspectors' training, experience, technique, visual acuity, state of mind, health, fatigue level, consistency.
5. Damage to the part created with this extra handling that may cause you to minimize the inspection process.
6. The parts' accuracy/size before plating.
7. Plating process: is there more material in some areas than others? Crud in the plating or on the parts while going through the process?
So you see why it is impossible to give a direct answer. Even on different days in the same place the results will likely vary.
