How effective is 100% inspection
Andrews
#11
Thanks everyone for your response.
Is there no way at all to improve effectiveness (i.e no defective pieces escape) of 100% inspection? how about changing the inspectors once in an hour ?
P
Phil P
#12
Hi Andrews,
Changing the inspectors on an hourly basis will reduce the effects of fatigue, but that's about all. The effectiveness of 100% inspection will be dictated by the accuracy and repeatability of the inspection process.
E
e006823
#13
How are you currently inspecting for this defect?
#14
Andrews,
Everyone here wants to help, but it seems that you haven't gotten the message so far. Every inspection process is different. Not only is every inspection process different, but each process might be different each time it's run due to the nature and interactions of the variables involved. If you think that operator fatigue might be a factor that needs control, then by all means act accordingly. Perhaps, in some instances, fixed gages might help, or better lighting or better training...
Sometimes inspection processes can be improved, and sometimes they are what they are and nothing can be done about it. You have to evaluate each instance individually and make the best decision you can, then check to see if your decision was correct or not, and make adjustments if necessary. Plan, do, check, act.
Rob Nix
#15
You might also consider what the biggest bang for your buck will be. At some point, the cost to control (i.e. inspect) the products will end up higher than the costs associated with the risk of missing a few bad parts (look up information on alpha and beta risk). In other words, you may be expending a lot of costly effort beating a dead horse. On the other hand, if even a few defects cause a serious risk to the business, you must look into preventive controls - not more inspection.
Craig H.
#16
If this is a visual inspection, changing inspectors will likely INCREASE variability, unless there has been very specific training covering what is and is not a defect.
Q
qualitygoddess - 2010
#17
Andrews said:
100% inspection is for a diameter 15.87/ 15.83. The cause for defect in this characteristic is plating thickness variation on this component.
About the only thing I can add to the posts that have already been written -- I still don't think we know how you are inspecting, but I suspect by hand gauge. This looks like a pretty tight spec, so should you be investigating an inspection method that is more automatic? I think that was mentioned in one post for a special fixture, etc. Programmable CMM's might be able to improve the inspection repeatability. However, there are a whole list of potential issues with these devices.........and it might be too expensive. You'll never get to 100%. You have to construct a process that produces to a certain sigma for the process steps.
It's time to go back to the process and be very thorough in reviewing the process and its capability to produce to spec. Dust off that FMEA and get going!
--QG
David Hartman
#18
You could consider a articulated arm/portable CMM (Romer, FARO, etc.). I just purchased a 4ft. Romer Infinite arm for less than $50k and that includes an off-site 2 day training course for 2 people.
--QG
This is so true! Much more needs to happen besides the "inspection" efforts. Poka-Yoking the process to minimize/eliminate the process variations should be of greater priority than the inspection efforts (greater bang for your buck).
Randy Stewart
#19
What kind of plating is being applied, is that an OD or an ID dimension, and what spec is the part being plated to?. Most zinc plating call outs are only 12 - 20 microns and most paints are somewhere around 25 microns max, so I can't see that as being a big factor in your failure rate. However, if you are talking tube nut dimensions this is a different set of circumstances. Not only must you be concerned about the OD & ID but you must calculate the affects of the threads, you may be looking at an engineering change request.
Most plating thicknesses are measured by using the eddy current method. The reported thickness is an average of 10 readings. The easiest way to ensure accurate measurments is to use a raw/unplated part to zero your scope with. Let me know if I can help.
M 100% Inspection - 85% Effective Inspection, Prints (Drawings), Testing, Sampling and Related Topics 10
J Visual Inspection Not 100% Effective - How to Improve Visual Inspection Quality Tools, Improvement and Analysis 51
A PRRC effective role and activities EU Medical Device Regulations 1
T How you ensure that QMS is effective and efficient? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
S Effective nonconforming process for AS9100 8.7 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
M Informational TGA presentation: How to submit an effective good manufacturing practice clearance application Medical Device and FDA Regulations and Standards News 0
N Validation procedure, Major NC CAP - Equipment Validation process is not effective ISO 13485:2016 - Medical Device Quality Management Systems 5
A Cost effective thread gaging with ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
S Root cause analysis - The system of developing a work instruction is not effective Problem Solving, Root Cause Fault and Failure Analysis 1
T Effective Date on Documents 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 12
qualprod Effective Auditing advice needed ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
Q Simple and effective way to maintain Training Matrix ISO 13485:2016 - Medical Device Quality Management Systems 16
J If Corrective and Preventive Action were truly Effective IATF 16949 - Automotive Quality Systems Standard 3
qualprod Risk closeout , mitigation was not effective, next? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
J Specific Actions where Timely and/or Effective Actions are not Achieved Nonconformance and Corrective Action 6
Q Predating Document Effective Date Other Medical Device and Orthopedic Related Topics 18
P Thai FDA postpone AMDD to be effective in 2020 Other Medical Device Regulations World-Wide 1
S Sell a Non-RoHS device, manufactured before RoHs regulations became effective? EU Medical Device Regulations 2
J What does "effective implementation of quality management system" mean? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
N What does an effective design process look like? (shoots flare in the air) Design and Development of Products and Processes 2
M Corrective Action - For a corrective action to be effective, a change is required? Nonconformance and Corrective Action 5
R 5.4.1 Quality Objectives - Nonconformity: The process was not fully effective ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 36
R Training to Effective Documents - Transitioning to Agile Document Control Systems, Procedures, Forms and Templates 5
R Good Supply Practices that will be effective on March 1 2015 in China China Medical Device Regulations 2
K IATF has posted new GM Customer Specifics, effective January 2015 Customer and Company Specific Requirements 5
B Medical Device Labeling - Order No. 6 Effective Oct 01, 2014 China Medical Device Regulations 7
R CFDA updated five regulations to be effective from October 1, 2014 China Medical Device Regulations 16
T Qualification System of Internal Auditors is not Effective General Auditing Discussions 5
A A Guide to Effective Internal Management System Audits Book, Video, Blog and Web Site Reviews and Recommendations 2
D Effective Date of updated SOP Document Control Systems, Procedures, Forms and Templates 3
A Effective Date (of Documents) issue outlined in 21 CFR Part 820.4 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 11
P Effective way for DC/DC conversion for 2 MOPP @ 250VAC IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
J Want best and effective solution for mouth infection Coffee Break and Water Cooler Discussions 11
S New FAA Form 8130-3 Effective 2/1/14 - Unlocked version attached Federal Aviation Administration (FAA) Standards and Requirements 3
P Effective Road Usage Coffee Break and Water Cooler Discussions 9
H How to make the Design Review Process Effective Design and Development of Products and Processes 1
Q Effective 1st Piece Inspection Sign Off Procedure Quality Manager and Management Related Issues 8
QMMike What is the most cost effective SPC software Statistical Analysis Tools, Techniques and SPC 5
Y Delivering an effective and all inclusive EHS program in a Food company Food Safety - ISO 22000, HACCP (21 CFR 120) 2
F Suggestions for quick & effective solution for Continuous Improvement Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
T Very effective movie about clean-up - Tool for 5S Training Lean in Manufacturing and Service Industries 4
M AS 9100 4.2.4 Process for making changes to records is not fully effective Quality Manager and Management Related Issues 4
Q Process Approach & Continual Improvement Clauses and Evidence of its Effective Use ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
M 8.2.2 Internal Audit - Determination of Effective Implementation IATF 16949 - Automotive Quality Systems Standard 4
L Audit NC - Lack of Effective Corrective Action Process ISO 13485:2016 - Medical Device Quality Management Systems 4
P Which Root Cause Analysis Method is the most Effective? Quality Tools, Improvement and Analysis 16
J Cost Effective Solution for Isolating USB 5V 500mA Power IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
Q Are ECO's closed after they are shown to be Effective? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
V What are the Steps in Ensuring a Definition/Implementation of an Effective Procedure Document Control Systems, Procedures, Forms and Templates 3
P What is Effective Maintenance? Auditing a Maintenance Department Manufacturing and Related Processes 5
