How far an operator can reach into a machine before it becomes an ergonomic problem
prephil
Are there any standards that define how far an operator can reach into a machine before it becomes a problem ergonomically. I have looked at a lot of standards including the below but can't seem to come across anything definitive that gives an exact figure or range.
Involved in a project where an operator will be reaching into a machine approximately every 30s to remove waste. Distance from access point to waste pickup point is approx 533mm. We are proposing using a suction tool to aid in removing the waste which in turn should bring down this 533mm distance.
prephil
Thanks for that tip, might have been using an incorrect search term. What I was able to gather from EN 547-1 was grip reaches but they seem a bit excessive to me to be ergonomically comfortable, 820mm for the 95th percentile. Maybe this is just the max distance that one can reach in and disregards ergonomics altogether.
Also came across forearm reach info in EN 547-2 but again it doesn't specify if this is a defined figure for max reach into a machine or not.
mattador78
Minus the ergonomics bit what are the physical dangers from reaching into the machine itself? Could it be designed out or as you say a suction or grabber tool used replacing somebody reaching into the machinery. Speaking from my own HS experience its better to remove the option of any body part going into a machine if there is potential risk. Funny story related to this many years ago before I became HS qualified a bloke who I worked with stopped me reaching into some machinery to clear a blockage, in typical layman's terms he asked me if I would put my d**k in there I said no chance, so don't put your hands in was his reply. Its a strange rule of thumb but one I have lived by ever since :D
prephil
Ya, have heard that comparison used myself and it is a good rule of thumb (or d"*k) . In this case, we are purposely building a manual line and this is unavoidable.
Melissa Risk Management Process, How far do I need to go? ISO 14971 - Medical Device Risk Management 10
L Reduce risks as far as possible - Quartz Crystal ISO 14971 - Medical Device Risk Management 11
B FAR/Prime Contractor Flow-down Tool - AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
D Where does "as far as possible" stop? FMEA - EN 14971 ISO 14971 - Medical Device Risk Management 29
Crimpshrine13 PPAPs (How far down the tiers are we supposed to get PPAPs)? APQP and PPAP 19
K About ionizers - How far can we place a table top ionizer from the IC devices Manufacturing and Related Processes 1
Q Correction of records - FAR or DFAR? Various Other Specifications, Standards, and related Requirements 3
I First Time Implementing Document Control for ISO-9001 - how far back do you go? Document Control Systems, Procedures, Forms and Templates 15
R How far apart can you schedule separate areas or departments in your internal audit? Internal Auditing 4
I FAR Part 43 and Application to 17025 Accredited Cal Lab Federal Aviation Administration (FAA) Standards and Requirements 2
I Is risk acceptability really needed if all risks must be reduced as far as possible? ISO 14971 - Medical Device Risk Management 6
J Definition Outsourcing - How Far Does it Go? Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 6
F Necessary trainings for FAR 145 certification Federal Aviation Administration (FAA) Standards and Requirements 3
R FAR 145.205 - Maintenance Program Flow Down Requirements Federal Aviation Administration (FAA) Standards and Requirements 3
Z Comparison between AS9100 and FAA 145 Repair-Station (CFR's, FAR's) Federal Aviation Administration (FAA) Standards and Requirements 3
L Records Register is not maintained and is far from complete ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
H Active Parts with No FAI - How far back do you go? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
J Quality Escapes Procedure (requirement for FAR 21.137 (n)) needed Document Control Systems, Procedures, Forms and Templates 1
C Certification process for small consultancy practice far away from main cities ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
D FAA Drug Testing Requirements - FAR Part 145.211 (c)(1)(vi) Federal Aviation Administration (FAA) Standards and Requirements 8
Q Registrars and Consulting - How far can a registrar go in consulting for a company? IATF 16949 - Automotive Quality Systems Standard 2
I far away Brain Teasers and Puzzles 8
ScottK How "far up" Maslow's Hierarchy are you? Career and Occupation Discussions 7
ScottK How far is it practical to take a Process FMEA? FMEA and Control Plans 14
A FAR Part 21/145 vs. EASA Part 21/145 EASA and JAA Aviation Standards and Requirements 5
Marc How far do you commute to work? Career and Occupation Discussions 64
ScottK Lessons Learned so far from my current ISO9001 adventure ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 23
K How far should we go to control Non-Conforming Material? Nonconformance and Corrective Action 7
Q Auditor Access to Records - How far an Auditor can Probe ISO 13485:2016 - Medical Device Quality Management Systems 19
C FAR Part 145.161(a)(4) - Summary of Employment AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
Marc Small Business Set Asides - FAR (Federal Acquisition Regulations) Subpart 19.5 Consultants and Consulting 2
R Component traceability in an assembly - Government contract - How far does it go? Various Other Specifications, Standards, and related Requirements 18
E How far to go into Special Characteristics (SC) Identification on Machines/Equipment IATF 16949 - Automotive Quality Systems Standard 1
H Process correlation matrix - Just how far "into the weeds" do I go? ISO 13485:2016 - Medical Device Quality Management Systems 4
gard2372 FAR 145 AS9100 Gap Analysis - Any recommendations on where to start? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 18
D Human Factors and FAR Part 145.163 'Training Program' Human Factors and Ergonomics in Engineering 9
P RoHS Legislation - Who's doing what, and how far down the line are you RoHS, REACH, ELV, IMDS and Restricted Substances 11
F Human Factors & Ergonomics - FAR Part 145.163 'Training Program' - Aviation Industry Human Factors and Ergonomics in Engineering 20
S Any feelings on how far back the FDA looks into documentation? ISO 13485:2016 - Medical Device Quality Management Systems 1
M Identifying Internal Customer Requirements - This is my list so far ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
W Consultancy on the fly - Registrars located in the Far East Registrars and Notified Bodies 2
K Supplier Audits - How far do we have to go? How much detail? Supplier Quality Assurance and other Supplier Issues 12
J Measurement Resolution - How far to carry the decimal place out Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 13
M How far does one go to protect quality and other records from "loss" Records and Data - Quality, Legal and Other Evidence 1
E CEO Involvement - How far do I go with insisting that they attend meetings, etc? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 22
J How far do Training output and HR responsibilities need to be controlled Training - Internal, External, Online and Distance Learning 2
B How to test operator to see if they can catch the defective parts? Manufacturing and Related Processes 6
Melissa CAR is not good enough! Operator Error! ISO 13485:2016 - Medical Device Quality Management Systems 39
Nihls When the MSA results show no operator influence Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
M Nonconforming parts accepted by operator with intention Human Factors and Ergonomics in Engineering 33
