Guidance Ref. No.
Question
Answer
Rationale
MAIN FLOWCHART
WHEN TO FILE A 510(K) AFTER CHANGE TO A LEGALLY MARKETED DEVICE
1
Change made with intent to significantly improve the safety or effectiveness of the device?
Yes -New
510K / No – See Question 2
No
Label updates Only
2
Labeling change?
Yes -See Chart A / No – See Question 3
Yes
See Below
3
Technology, engineering or performance change?
Yes -See Chart B / No – See Question 3
No
No Changes
4
Materials change?
Yes -See Chart C / No – Documentation
No
No Changes
FLOWCHART A – LABELING CHANGES?
A1
Does the change affect the indications for use statement?
Yes – See A1.1 / No – See Question A2
No
Not Changed
A2
Does the change add or delete a contraindication?
Yes -New 510K / No – See Question A3
No
Not Changed
A3
Is this a change in the warnings or precautions?
Yes – See A1.1 / No – See Question A4
No
Not Changed
A4
Could the change affect the directions for use?
Yes – See A1.1 / No – Documentation
No
Not Changed
A1.1
Is it a change from a device labeled for single use only to a device labeled as reusable?
Yes – New 510K / No – See Question A1.2
No
Not Changed
A1.2
Is it a change from Rx to over the counter OTC use?
Yes – New 510K / No – See Question A1.3
No
Not Changed
A1.3
Is it a change to the device name or to solely improve readability or clarity?
Yes – Documentation / No – See Question A1.4
No
Not Changed
A1.4
Does the change describe a new disease, condition, or pt pop that the device is intended in diagnosing, treating, preventing, curing or mitigating?
Yes – Documentation / No – See Question A1.5
No
Not Changed
A1.5
Does a risk-based assessment identify any new risks or significantly modified existing risks?
Yes – 510K see chart / No – Documentation
No
FLOWCHART B – TECHNOLOGY, ENGINEERING, PERFORMANCE CHANGES?
B1
Is the device an IVD?
Yes – See Chart D / No – See Question B2
N/A
B2
Is it a control mechanism, operating principle, or energy type change?
Yes – New 510K / No – See Question B3
N/A
B3
Is it a change in sterilization, cleaning, or disinfection?
Yes – See Question B3.1 / No – See Question B4
N/A
B3.1
Is it a change to a Cat. B or novel method, does it lower the SAL, or is it a change to how the device is provided?
Yes – New 510k / No – See Question B3.2
N/A
B3.2
Could the change significantly affect performance/ biocompatibility?
Yes – New 510k / No – Documentation
N/A
B4
Is there a change in packaging or expiration dating?
Yes – See Question B4.1 / No – See Question B5
N/A
B4.1
Is the same method or protocol, described in previous 510(k), used to support change?
Yes – Documentation / No – new 510k
N/A
B5
Is it any other change in design (e.g., dimensions, performance specifications, wireless communications, components or accessories, patient/user interface)?
Yes – See Question B5.1 / No – Documentation
N/A
B5.1
Does the change significantly affect the use of the device?
Yes – new 510k / No – See Question B5.2
N/A
B5.2
Does a risk assessment identify any new or significantly modified risks?
Yes – new 510k / No – See Question B5.3
N/A
B5.3
Is clinical data necessary?
Yes – new 510k / No – See Question B5.4
N/A
B5.4
Any unexpected issues from V&V activities?
Yes – new 510k / No – Documentation
N/A
FLOWCHART C – MATERIAL CHANGES?
C1
Yes – See Chart D / No – See Question C2
N/A
C2
Change in material type, formulation, chemical composition, or the material’s processing?
Yes – See Question C3 / No – Documentation
N/A
C3
Will the changed material directly or indirectly contact body tissues or fluids?
Yes – See Question C4 / No – See Question C5
N/A
C4
Does a risk assessment identify any new or increased biocompatibility concerns?
Yes – See Question C4.1 / No – See Question C5
N/A
C4.1
Has the manufacturer used the same material in a similar legally marketed device (including formulation, processing, type and duration of contact, etc.)?
Yes – See Question C5 / No – New 510k
N/A
C5
Could the change affect performance specifications?
Yes – See Question B5 / No – Documentation
N/A
SOFTWARE CHANGES?
1
Is the change made solely to strengthen cybersecurity and does not have any other impact on the software of the device?
Yes – Documentation / No – See Question 2
No
No changes to Software
2
Is the change made solely to return the system into specification of the most recently cleared device?
Yes – Documentation / No – See Question 3a
No
3a
Does the change introduce a new risk or modify an existing risk that could result in significant harm and that is not effectively mitigated in the most recently cleared device?
Yes – new 510k / No – See Question 3b
No
3b
Does the change create or necessitate a new risk control measure or a modification of an existing risk control measure for a hazardous situation that could result in significant harm?
Yes – new 510k / No – See Question 4
No
4
Could the change significantly affect clinical functionality or performance specifications that are directly associated with the intended use of the device?
Yes – new 510k / No – Evaluate Section VI
No
Section VI
Infrastructure - Does this introduce modifications made to the software support system?
(examples of insignificant/significant changes in guidance)
No
Section VI
Architecture - Does this introduce modifications to the overall structure of the software?
No
Section VI
Core algorithm - Does this introduce modifications made to an algorithm that directly impact or contribute to the device’s intended use?
No
Section VI
Clarification of Requirements – No Change to Functionality - Does the change clarify software requirements after a product has received premarket clearance?
No
Section VI
Cosmetic Changes – No Change to Functionality – Is this a change to the appearance of the device that does not impact the clinical use of the device?
No
Section VI
Reengineering and refactoring - Does this change:
Examine and alter software to reconstitute it in a new form, and includes the subsequent implementation of the new form?
Restructure the software program’s internal structure without changing its clinical performance specification.
No
Section VI
Additional Software Changes not addressed in Guidance Section VI shall be documented below:
No
END OF DEVICE SOFTWARE CHANGE DECISION MATRIX
