How important is a Quality Manual - ISO 9001:2008 to 9001:2015
matti
Hi.
ISO 2015 version do not require a quality manual but our company insist to have one in place as this is a good reference point to what is required of a System the ensure the product meet he customer requirements.
The higher structure of the current manual is not inline with the new High Level Structure.
1. How important or essential is to ensure that the the quality manual if still to be kept represent the higher Structure of the 9001:2015?
(It is a quite difficult task and it is a puzzles of throwing this up in the air and trying to put the pieces together.)
We have a three years grace to adapt to the new standards . I am currently reviewing the entire document and need to know if there is a template manual that I can follow.. Quality Gurus has some tool to aid you but this is breaking my brain cells to update the table than the content accordingly.
I am not in a hurry but would like to get it right first time.
Cheers for any aid that I can get. :cfingers:
Jen Kirley
Quality and Auditing Expert
Re: ISO 9001:2008 to 9001:2015 Quality Manual
Hi Matti,
While the language between the two standards differs quite a lot, if we look at our operations closely we might find there is relatively little that we are not already doing.
That means your manual might not need to change much, indeed if you will still have one because customers want it or because you decide you want it.
I would not lose any sleep about this right now. There is plenty of time and I have no doubt there will soon enough be examples to find on the web.
The key difference would be in identifying stakeholders and their needs, then drawing connections between that and the products and services you already provide. Then, using that list to decide what is relevant, maybe something so simple as a SWOT analysis - or maybe different SWOTs for different processes, products/services - can help you decide on what to point to for operational controls (risk based thinking). You will probably find your own existing procedures are adequate but there will be some additional considerations like involving employees.
I hope this helps!
matti
Thank you.
I will take all of this into consideration.
dsheaffe
Hi Matti,
I agree with Jennifer, don't stress about it yet - and yes there are likely to be plenty of template/example "quality manuals" posted on line in due course - probably most of which will be a re-write of the standard - and personally, none I would ever use.
As to your question - no if you retain a quality manual it does not need to aligned to the structure of the standard (and never did - but it was an easy approach for many organisations).
My suggestion would be, this is a perfect opportunity to take a long hard look at your quality manual and decide what actually needs to be included. eg, your manual could just include your quality policy, a high level process flow of your business, information about stakeholders, scope of your QMS, etc
Good luck.
Big Jim
Perhaps I can add to the already great comments.
When the transition between ISO 9001:1994 and ISO 9001:2000 was underway, a few companies retained their old manual. As time went on, trying to juggle between a manual that was oriented to the numbering system of the 1994 version with the new standard generally proved to be confusing. If past is prolog that is what will happen again.
Although a manual is not required by the new standard, those who wrote the standard, according to their chairman, anticipate that most companies will still want one.
As a consultant who has written many of them, I don't see the demand for them dropping off. Every client that I have told that a manual will no longer be required was dumbstruck, asking how could a company's quality management system survive without one.
Sit down with the new standard, the correlation matrices, and your existing manual and figure out what changes you need to make.
RLGALLAGHER
Does anyone have a spreadsheet/matrix which might outline the new element along with intent....aligned with the revised 2008 standard.....sort of a gap analysis (or even a cross-reference/index:
Jen Kirley
There's a correlation matrix here, but intent is too soon to look for among the ISO 9001 Auditing Practices Group list of guidance documents. I will be paying attention to this web page for updates to these linked documents for insights the standard may lack.
Hi.
Not at all. In fact, having a manual which emulates the standard isn't much use to the user, in actual fact. Ditch the idea that you have to show a clause by clause alignment. Find a model of a manual which people actually understand, use, can read etc and when the changes come, adopt that. Unless you have an anal retentive customer who wants the old fashioned manual - but then do you want your customer telling you how to run your QMS?
Big Jim
There is no reason that a quality manual can't do both. The ones I write do. If they do, it would be less confusing if they are aligned to the most current standard.
There is no reason that a quality manual can't do both. The ones I wright do. If they do, it would be less confusing if they are aligned to the most current standard.
For whom? It's not a case of "less confusing". There should be NO confusion. That's why I said, ditch the conventional wisdom of a clause by clause manual. Don't forget when you "wright" a manual, your clients don't know any better - they accept you are giving them something which is required (when many know it isn't) and will smile and pay you...
The fact is, a manual isn't going to be required, so why continue to keep one foot in the 20th century?
A Most Important Knowledge in the Quality Assurance field - What to Learn Career and Occupation Discussions 11
Marc Which is more important to a Quality Professional - MBA or Six Sigma Black Belt? Professional Certifications and Degrees 44
G Quality Culture - Teaching Quality is as Important as Safety Other ISO and International Standards and European Regulations 7
S Quality Objectives. What? How? And How important to the organization? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
M Quality not Important for British Companies Misc. Quality Assurance and Business Systems Related Topics 6
L Which one is more important for FMEA CC or SC, FMEA and Control Plans 6
D What are the important things to keep track of in product audit checklist? Software Quality Assurance 3
JoshuaFroud How important is using the "correct" GMDN? Other Medical Device Regulations World-Wide 14
B The most important criteria of IEC 60601-1 medical devices safety IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
R Which of the following indicators is important for Operations - Ppk, Cpk, or Cpm? Statistical Analysis Tools, Techniques and SPC 15
B How important it is to select Parts that represent the Process Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
T Is a Job Title important? Career and Occupation Discussions 28
M Important procedures and clauses for company which provides equipment rental Service Industry Specific Topics 1
somashekar Link to important websites within the Cove Book, Video, Blog and Web Site Reviews and Recommendations 1
M Accountability for all product - Why it is important? Intent of 7.5.1 g) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
E How important is External Verification of Corruption Prevention Programs? Sustainability, Green Initiatives and Ecology 2
J Late CA (Corrective Action) excuse or I'm too important or no response Nonconformance and Corrective Action 19
A Important Regulatory changes in Australia Other Medical Device Regulations World-Wide 0
G How important is using the current QCI study primer revision for preparation Professional Certifications and Degrees 1
A What is more important - Head office OR Factory? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
A Can a project have multiple Ys that are interrelated and important to the process? Six Sigma 5
H Beautiful, Graphic, Process Map examples wanted - Graphic design is important Process Maps, Process Mapping and Turtle Diagrams 7
G Short TQM training - Choosing of most important points Training - Internal, External, Online and Distance Learning 3
D An important travel tip Imported Legacy Blogs 4
O I need a process map for ISO 9001 important processes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
M The 3 Most Important Tips to Starters Implementing a QMS ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 25
Q What are the most important documents to maintain with your audit package Internal Auditing 15
Jim Wynne Why it's important to have clear specifications Funny Stuff - Jokes and Humour 2
M What are the most Important Areas that Concern the External Auditors ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
A Is Accreditation of Auditor Training Important? Training - Internal, External, Online and Distance Learning 29
S Are Teeth Important in Making Good First Impressions? Coffee Break and Water Cooler Discussions 31
S Why historical data & benchmark data is important in APQP planning phase APQP and PPAP 6
Statistical Steven Accuracy vs. Precision - What is more important for Process Capability Statistical Analysis Tools, Techniques and SPC 55
R TQM Project - Books on important TQM books The Reading Room 5
N Is safety in chemical industry an important requirement to be ISO certified? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 20
W How important the QMS could be in our work - Seeking presentation for colleagues ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
D "Shop-Floor Work Instruction" ? How important they are? Manufacturing and Related Processes 11
C IATF Guidance for TS 16949:2002 - Course Instructor says it's important ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 5
Y Why are the principles of controlled documentation important to a QMS? Document Control Systems, Procedures, Forms and Templates 2
A Decreasing our Ppm! Important and effective point to decrease ppm level Statistical Analysis Tools, Techniques and SPC 10
W Is Training Important to Your Organization? Training - Internal, External, Online and Distance Learning 22
J Industry codes: how important? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
S What is the life cycle costing? Why so important? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
C Is calibration of digital panel important in any semicon company? General Measurement Device and Calibration Topics 3
Z Linearity of Bias in MSA - Why is it important? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
N Guidance - Cost of Good Quality Misc. Quality Assurance and Business Systems Related Topics 2
D Quality plan for moving locations ISO 13485:2016 - Medical Device Quality Management Systems 3
was named killer Job Opportunity-Quality Engineer-Tampa Florida Job Openings, Consulting and Employment Opportunities 0
Marc Job Opportunity – Quality Assurance Specialist - Suspense 7 April 2021 Job Openings, Consulting and Employment Opportunities 0
