How is documentation affected moving to an electronic system?
NikkiQSM
#11
Two poins:
The standard doesnt ask to keep the old version.
It needs control of changes.
Dont you think is it sufficient to show the description of the change described in the document? And also signatures of reviewers and approvers?
Other point, I worked in an engineering company that, avoided the manage of obsolet documents, because when engineers used by mistake obsolet documents, caused very costly errors, e.g. instead of using drawings rel 6, used rel 4.
I understand the standard doesn't tell me to keep the old revisions - but why would I be asked to show them so many times during audits? I have a log that shows that they have been updated and what has changed - but they still ask for them.
Al Rosen
#12
What standard are you referring to? ISO13485 requires retaining a copy of the obsolete documentation for the lifetime of the device, and at least two years for records.
Golfman25
#13
A report should be able to produce a copy of the previous revision(s). Once a document is committed a record is made in the database. It doesn't take much space in a database file. The revision should create a new record which is linked to the previous record (and so on).
If the database wasn't designed this way, well - Even cheap software does this. Like I say, even with vBulletin (and most forum software, if not all, which are based on a relational database) saves a copy unless an admin specifically tells the software to "permanently" delete a record. So, if a post in a thread here is edited 50 times there will be 50 corresponding complete records, all linked by date, and with information such as who did the edit, the time and date, the IP they were on when they edited, and some other info.
I can't speak to custom written software other than some experiences in years past, a few of which came off very good, and a couple which ended up as near disasters. The disasters were mainly due to the company not properly specifying their requirements.
Caution - Old Man Rant: I used to write relational databases some years ago with Foxbase, Filemaker, and a few in Microsoft's Access. Common practice, even back then, was you have a form. As soon as the form is "committed" (saved) a database record is created. When the form is brought up again, it is completed and when committed makes a new entry in the database. The original (and past records) are not deleted unless a special "query" is run (often called a "prune"), which can be specified, for example, delete everything prior to <date> (for example).
I think there is a difference between a running "what's new" log of changes and revisions and being able to recreate an old version. If my software creates a PO that I can print out and that report is revised to include additional information, I may not be able to reproduce that old PO from the system. I might have "old copies" of completed POs filed away somewhere.
Marc
#14
Different companies, different philosophies, different requirements. To me it's a "risk assessment" in that if there is ever a question I have a solid reference. But, you're right in that if you see no need and there is no requirement, no reason to keep copies of revised documents. I'm just a biologist who ended up in business and starting in DoD work it was drilled into me to always kept a copy of every successive document. The practice has saved my :ca: many times over the years.
Have you ever simply said "where does it say that I am required to keep copies of the previous document(s)?" This type of thing with auditors goes back years - there have long been discussions of auditors asking for things that aren't required. I can't say why auditors do this, but it's very common and is a common complaint. That is why "Show me the requirement" has been a common response to auditors for many years.
H MD Technical Documentation and SALES possibility EU Medical Device Regulations 0
A DMDIV-Variants : definition and technical documentation CE Marking (Conformité Européene) / CB Scheme 4
NDesouza COTS Items CoC for FAI Documentation AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
P MDR/IVDR Annex III - Technical documentation on PMS EU Medical Device Regulations 1
I IATF Lab Scope Testing Qualification and Competency Documentation IATF 16949 - Automotive Quality Systems Standard 3
C Documentation hold during submissions? ISO 13485:2016 - Medical Device Quality Management Systems 0
K SOUP (Software of Unknown Provenance) Anomaly Documentation IEC 62304 - Medical Device Software Life Cycle Processes 2
C Gobys for operations documentation plan Oil and Gas Industry Standards and Regulations 4
C Refreshing an old and boring topic - Job descriptions and Roles vs Process Documentation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 38
P Does anyone have a API Q1 Documentation Package? Quality Management System (QMS) Manuals 1
J Documentation structure - Do I need Work Instructions? Document Control Systems, Procedures, Forms and Templates 23
J Where to Place Process Maps in our Documentation? Process Maps, Process Mapping and Turtle Diagrams 4
C Manufacturing overages & nonconforming material documentation ISO 13485:2016 - Medical Device Quality Management Systems 3
Robert Stanley Required Documentation Templates ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
I Maintaining Technical Documentation under MDD and MDR EU Medical Device Regulations 1
M Basic UDI and technical documentation EU Medical Device Regulations 1
M What is the average time needed for process documentation? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
was named killer CLOUD BASED QUALITY DOCUMENTATION vs. SERVER BASED Document Control Systems, Procedures, Forms and Templates 5
S How to start with ISO process in project based team - Documentation Document Control Systems, Procedures, Forms and Templates 4
K ITAR Visitor Documentation of Citizenship AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
R Design Verification Documentation ISO 13485:2016 - Medical Device Quality Management Systems 19
A Process Documentation for ISO 9001:2015 Internal Auditing 2
F Process Review - What is the ISO requirement for reviewing SOPs and quality documentation? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
J Good Documentation Practices Self Test? ISO 13485:2016 - Medical Device Quality Management Systems 6
F ISO 17025:2017 mandatory documentation requirements ISO 17025 related Discussions 1
D Virtual Documentation via Master Flow Chart? Process Maps, Process Mapping and Turtle Diagrams 4
S Defining a Quality System from scratch - Preferred system and documentation names Document Control Systems, Procedures, Forms and Templates 4
C Maintenance of Product Technical Documentation EU Medical Device Regulations 3
F PPAP Documentation Control APQP and PPAP 8
V Every good documentation practice observation is an data integrity issue US Food and Drug Administration (FDA) 7
CPhelan Labeling template on QMS - Kitting and labeling documentation Manufacturing and Related Processes 9
DuncanGibbons Documentation aerospace OEMs require with purchase of parts from manufacturers/suppliers Manufacturing and Related Processes 0
V What is the criteria to cite an good documentation practices observation as an data integrity related issue US Food and Drug Administration (FDA) 6
L AS9100 D- Handling Nonconformance Documentation for an organization that outsources most of the work. AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
L ISO 9001:2015 standard documentation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
N Time source for paper-based documentation (research nurses) US Food and Drug Administration (FDA) 1
W Documentation - Use of Addendum vs Amendment Document Control Systems, Procedures, Forms and Templates 1
I What level of change in documentation requires re-training? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
C Access to Technical Documentation - MDR Chapter VI Article 61 EU Medical Device Regulations 4
D QMS Documentation Process - I want to put all the Process SOPs to a QMS system Document Control Systems, Procedures, Forms and Templates 3
T QMS - Documentation Cloud Storage EU Medical Device Regulations 0
C Updates on Documentation for outsourced OEM from ISO 13485:2003 to ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 4
N EU MDR Basic UDI-DI and Technical Documentation for Systems EU Medical Device Regulations 22
B Quality Management System documentation identification Document Control Systems, Procedures, Forms and Templates 11
J Training documentation - ISO 13485 audit and the auditor had questions General Auditing Discussions 7
D Documentation requirements for the new Medical Device Regulations (2019) CE Marking (Conformité Européene) / CB Scheme 5
Ashok sunder ISO 45001:2018 Documentation template Occupational Health & Safety Management Standards 4
M Informational BSI – MDR Documentation Submissions Best Practices Guidelines Medical Device and FDA Regulations and Standards News 0
