How is the Cmk and Cpk calculated?
maghsoodi
Hi
In the machining process, after the 20 pieces have been manufactured, due to the increasing process characteristic, the grinding must be done to bring the characteristic closer to the target. In such cases, how is the cmk of the machine to be processed and cpk to be calculated?
Q Machine Capability Study - Cpk (Cmk) of an R/F testing machine Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
S A question about Cpk and Cmk - Can we use Cpk to replace Cmk? Capability, Accuracy and Stability - Processes, Machines, etc. 1
H Some questions about Cmk and Cpk Capability, Accuracy and Stability - Processes, Machines, etc. 2
C Evaluating software that measures Ppk, Cmk, Cpk, PPI, etc. Capability, Accuracy and Stability - Processes, Machines, etc. 4
S Cmk and Cpk - When will we need to calculate Cmk? Machine Capability Capability, Accuracy and Stability - Processes, Machines, etc. 4
A Cpk, Cmk in Electronic Assembly (Process Capabiity) Capability, Accuracy and Stability - Processes, Machines, etc. 4
B Any ideas on setting up Capability Study spreadsheet in Excel? (CPK/CMK formulae) Excel .xls Spreadsheet Templates and Tools 4
T Calibration or Verification -> Cm and Cmk, etc. Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 3
G Function in french called "numbre de posage(s)" - CMK Question Quality Tools, Improvement and Analysis 3
K Excel Spreadsheet Template to calculate Cmk (Machine Capability) wanted Capability, Accuracy and Stability - Processes, Machines, etc. 2
L Fastening Process Cmk study - Bolt Torque Statistical Analysis Tools, Techniques and SPC 1
L Multi-fixtures in one CNC lathe - How to do Cmk study? Statistical Analysis Tools, Techniques and SPC 6
F MCA calculation - problem with Cm Cmk and boundaries Capability, Accuracy and Stability - Processes, Machines, etc. 1
M Cmk (Machine Capability) - Case study Capability, Accuracy and Stability - Processes, Machines, etc. 5
C Gauge R&R Studies Bad, but Process has a Cmk of over 7 IATF 16949 - Automotive Quality Systems Standard 8
V Machine short term capability study with Cmk index in automotive industry Capability, Accuracy and Stability - Processes, Machines, etc. 3
Q Confused about the machine capability index Cmk Capability, Accuracy and Stability - Processes, Machines, etc. 1
D Tool Approval Process - Should we be using Cmk for tool validation Statistical Analysis Tools, Techniques and SPC 2
A Acceptance criteria for Cmk (machine capability index) Statistical Analysis Tools, Techniques and SPC 3
B I am confused, which Cmk value should I take and use? Statistical Analysis Tools, Techniques and SPC 6
M How to Conduct a Machine Capability (Cmk) Study Statistical Analysis Tools, Techniques and SPC 27
S Cmk is defined as a Capability Index for a Stable Machine Capability, Accuracy and Stability - Processes, Machines, etc. 8
K Cmk - What is the difference between an R&R study and Cmk? Statistical Analysis Tools, Techniques and SPC 4
D Can anyone enlighten me as to what exactly Cm / Cmk are? Statistical Analysis Tools, Techniques and SPC 1
M Cmk calculation - Small plastic parts using injection-moulding machine Statistical Analysis Tools, Techniques and SPC 2
R Cpk demands from automotive customer Capability, Accuracy and Stability - Processes, Machines, etc. 5
Q Can I use Cpk to compare if one part is usable in another part? Capability, Accuracy and Stability - Processes, Machines, etc. 5
C Capability in sewing processes CP,CPk,PP,PPk Capability, Accuracy and Stability - Processes, Machines, etc. 4
G What's the difference between 1.32 and 1.33 Cpk? Capability, Accuracy and Stability - Processes, Machines, etc. 18
M Cp and Cpk for straightness and parallelism Capability, Accuracy and Stability - Processes, Machines, etc. 8
Q Capability - CPk comparison values Capability, Accuracy and Stability - Processes, Machines, etc. 12
D Tolerance definition based on expected Cp/cpk Reliability Analysis - Predictions, Testing and Standards 14
K Analysis variation among the lots during cpk calculation. Design and Development of Products and Processes 1
S Recommendation for user friendly Gaga R&R and Cpk software Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
A How to set up Continuous CpK monitoring of an injection mold process Reliability Analysis - Predictions, Testing and Standards 7
A Interpretation with regards to Ppk > Cpk Capability, Accuracy and Stability - Processes, Machines, etc. 14
U Cpk Calculation - I analyse a double seam cans Manufacturing and Related Processes 15
Proud Liberal Cp / Cpk on position using multiple MMC bonuses Capability, Accuracy and Stability - Processes, Machines, etc. 2
I Can we use pin gauges to measure an accurate Cpk ? Capability, Accuracy and Stability - Processes, Machines, etc. 9
T Final process capability results - What I am supposed to present? Cp and CpK? APQP and PPAP 11
F CpK on a manufactured assembly? Reliability Analysis - Predictions, Testing and Standards 7
O Cpk for Unilateral Tolerance Capability, Accuracy and Stability - Processes, Machines, etc. 9
B How to calculate CPK with n = 1 Manufacturing and Related Processes 2
O CPK with a P value less than 0.005 Manufacturing and Related Processes 8
A Cpk Formula seems off, need help!? Capability, Accuracy and Stability - Processes, Machines, etc. 11
D Cp/Cpk on Gages for MSA (vs. Cg/Cgk) Capability, Accuracy and Stability - Processes, Machines, etc. 21
E Questions regarding Cpk Calculation - Should we be using LSL/USL or LCL/UCL? Capability, Accuracy and Stability - Processes, Machines, etc. 5
B Maximum Material Condition with Bonus - Determine Cpk for this one kpc Measurement Uncertainty (MU) 2
