How many audits a year do your internal auditors perform?
  • 1
    Votes: 3 15.0%
  • 2-5
    Votes: 9 45.0%
  • 6-10
    Votes: 0 0.0%
  • >10
    Votes: 8 40.0%
  • Total voters
    20
Coury Ferguson
Moderator here to help
#11
For the life of me I can't see how doing two audits a year is meeting the requirements of a) the standard and b) the business!
Two audits, depending on the length of time spent per each day (s) should be sufficient. It is like doing surveillance audits at every six months from your Registrar (CB).
By the way this thread was created in 2003.
#13
Okay, let's say you are a small stamper (25 employees). You stamp blanks. Your dies are customer supplied, as is your steel. All of your process are pretty much straight forward and simple. What's there to audit? You've got a mature system (all of the bugs are worked out), you're following your processes, major changes are rare.
I have a difficult time understanding why you would have to audit monthly, unless you have a very complex system, or there are a lot of changes.
I was at a place last month that had a brand new QMS (didn't have one before). They had a whole bunch of different processes (stamping, bending, welding, painting, sewing, etc.). Despite the different processes, each process was being performed consistently within the rules they established. I found nothing that would make me want to audit them monthly (or even quarterly), if I were their internal auditor. Did I find things? Yes. But even with the stuff I found, there was nothing that would make me feel that the process "status" requires more frequent auditing.
#14
And their management all slept well at night.............? So what you're saying is nothing ever changes? No new requirements, new people, changed processes, new suppliers, new customers, new equipment etc. etc. No rejects off the process, no rework, no waste, nothing of any interest......
Well, yes I can see your point about not auditing...........!!
#15
Their management does sleep well at night. To they have changes? Yes, they do. Do they have occasional problems? Yep, they have those two. But they have processes in place to handle those. But, here is my point. Take the paint line, for example. It has run smoothly for years. Can it be improved? Undoubtedly. In fact, the manager is trying to find a better way to ensure water is not retained after the pre-painting wash. It has not created a problem, but right now it is a manual process using compressed air. He sees that as a waste and as a potential problem. But back to the audit. The initial audit found a handmade work instruction that was about 5 years old. It was not in document control. They decided they did not need it anymore, and removed it. They also went through the entire company to purge any remaining old, unapproved work instructions. So, if nothing changes from the January audit through the June audit, why audit in between? What is to be gained from auditing something more often? Now, should something happen (not just a customer complaint – it could be any change), then they would modify the audit plan to ensure the integrity of the QMS. Of course, the argument is that the audits should then be auditing for continual improvement instead of compliance, and that is a good argument (if not the only argument). But they have a suggestion program for that, and semi-annual audits help reinforce that.
I did not make a point about not auditing….. the point was not to audit too often. If I audit the quality policy (and find it good) and nothing changes, do I have to examine it every month?
#16
So, how do you know they followed those processes and that they're effective? Are you proposing to wait nearly a half year to check on that? Also, from your comments, I'm not sure I understand the paint line story, however, I'm not proposing you have to do a system audit every month, nor keep checking on 'quality policy' (I've never quite understood why auditors make such a big deal about asking folks that).
What I'm suggesting, especially for a company that has its act together (as you suggest Dave) is a) that a predefined schedule isn't worth having and b) the schedule should go after those changes to see if the system is in control of the changes or when problems occur to asure that the prescribed system is being utilized. Having a predefined schedule means having to change it when stuff happens. Furthermore, if you wait too long (and this may be anywhere from 6 to 12 months after the fact) to tell management, they won't take you seriously, will they!
#17
If your processes are working well, problems will surface and you will be able to react to them. I agree that you would not want to wait 6 months to find a problem. I do not like the idea of auditing just to audit. That is one reason I take issue to TS's requirement of scheduling to an annual plan. It kinda forces a more rigid audit schedule that might not be value added. If audits are only speed traps, looking for “gotchas”, then the system will eventually fail. Over auditing can do that. This also results in the types of thing that you mentioned. I have never liked a rigid schedule. And although auditing semi-annually sounds rigid, it really isn’t.
One of the things I recommend is the use of what I call supplemental audits. These are used to supplement the regularly scheduled audits. Supplemental audits occur when special events require an additional audit. This would include any changes that could have a effect (positive or negative) on the QMS (helps reinforce 5.4.2 b and 8.2.2). The regularly scheduled audits cover the continual improvement aspect, and supplemental and follow-up audits cover compliance.
#18
Agreed, Dave.
I'd suggest that you don't have to have worked everything out about the audits for a whole year hence, to still comply with TS. Having an annual plan, in my book, doesn't mean predicting every audit. In fact, I've worked with TS clients who got creative and now don't have a whole calendar of audits. They simply lay down a frequency (bi-monthly in this case) then use the issues of the time to give direction to the focus of the 'next' audit. This defines the 'scope' and 'criteria' of each successive audit. Indeed, this is pretty much as ISO 9004 guides us.
It's never made sense to me to try to run a whole calendar of audits. Who the heck knows what needs auditing in 6, 9 or 12 month's time? and to keep updating the schedule just feeds managements' (unspoken) perception that "audits are all a waste of time and the guy (or girl) running them doesn't know what to audit next.........."
Also, there's no need for those different categories of 'supplemental' audts. K.I.S.S is the best policy, I believe. Audits aren't rocket science, but treating the earth as flat isn't winning us friends with the people who count!
#19
Nothing creates more excitement and participation as the topic: "Audits."
Old threads, new threads, future threads; it does not matter, anything containing the magic word gets Fellow Covers going. :biglaugh:
Stijloor.
Yeah - give me audits!! I love them!!:lmao:
So many people have been trained and we're still not getting much value out of audits...........and they're far more interesting than G D & T don't you think??:agree1:
C ARGH Too Many Internal Audits Internal Auditing 22
B How many nonconformances have you received on average during IATF audits? General Auditing Discussions 24
I How many fail ALL ISO 9001 registration audits - How many never make it? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 46
G Too many customer complaints Customer Complaints 16
I How many gauges in a Go/No Go Gauge? General Measurement Device and Calibration Topics 7
BeaBea How Many Processes should be created for each Department? Process Maps, Process Mapping and Turtle Diagrams 5
Watchcat How Many Notified Bodies are "Enough" Already? EU Medical Device Regulations 23
S How many mandays required for the below mentioned standards IEC 27001 - Information Security Management Systems (ISMS) 3
N MDR review process by notified body - How many steps exist in the review process EU Medical Device Regulations 0
F How many signatures do we need on calibration certificates? ISO 17025 related Discussions 8
M Informational From RAPS – Operating System Vulnerabilities in Many Medical Devices, Germany’s BfArM and Device Firms Warn Medical Device and FDA Regulations and Standards News 0
R Validation of Medical Device Hardware containing Software - How many to Validate ISO 13485:2016 - Medical Device Quality Management Systems 1
K How Many Samples to send for Chemistry Testing Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 3
N MDSAP Participants 2019 - How many companies are participating YTD? ISO 13485:2016 - Medical Device Quality Management Systems 20
S How many of you are using Robotic process automation for calibration lab management? ISO 17025 related Discussions 0
G Measuring customer parts on a CMM - How many decimals to report to the customer? ISO 17025 related Discussions 28
J Supplier choice limitation - Many of them dont have PSCR, VDA or even ISO 9001 VDA Standards - Germany's Automotive Standards 0
O Clean room performance qualification (pq) - How many times can I do each test? Manufacturing and Related Processes 8
G How many samples you require to test during PQ for validation of a equipment? ISO 13485:2016 - Medical Device Quality Management Systems 1
D IATF 16949: Do we have too many processes? Are they all the same? Registrars and Notified Bodies 7
D QMS Performance Based on how many NCRs were generated month to month Nonconformance and Corrective Action 8
S How many QMS processes and procedures? ISO 13485:2016 - Medical Device Quality Management Systems 2
L How many of you are Certified to IATF 16949 IATF 16949 - Automotive Quality Systems Standard 12
G How many Uncertainty Measurements for Micrometers and Calipers? Measurement Uncertainty (MU) 3
R How many Corrective Action Request can be Issued by DCMA for a single issue? Nonconformance and Corrective Action 2
A Training Program Help - Old docs, new docs, so many docs... ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
M How many Pieces to Test - Sterility Testing USP EU Medical Device Regulations 2
P Are we an outlier for so many variations of Change Management? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
M SPC with many data points from one dimension Statistical Analysis Tools, Techniques and SPC 16
S How many times do you have the term 'Requirements' in your Quality Manual? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
L How many working hours to required to implement ISO 14001 ? ISO 14001:2015 Specific Discussions 6
B ISO/TS16949 Internal Auditing - How many auditors? Internal Auditing 4
R Training Production Employees When We Have SOOO Many SOPs Training - Internal, External, Online and Distance Learning 9
P Scope Extension Audit - How many days? Do I audit all AS9100 requirements? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
J How can I manage Occurence Rates in FMEA efficiently when I have many processes? FMEA and Control Plans 9
V How many times the quality agreement has been invoked? ISO 13485:2016 - Medical Device Quality Management Systems 3
C How to document many document control systems with one Document Control Procedure? Document Control Systems, Procedures, Forms and Templates 6
A How many laboratories are accredited to ISO 17025 in the USA? ISO 17025 related Discussions 5
R Is it possible to randomly select samples from 1 column to many column Using Minitab Software 2
L How many ISO Standards are there and time allowed for Closing NCs? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
S How many mandays are required for QMS audit? Internal Auditing 5
Ajit Basrur FDA - "We Moved Forward on Many Fronts This Year" - Margaret A. Hamburg, M.D. US Food and Drug Administration (FDA) 1
F AS9100 - How many times can the same auditor audit your system AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
J APQP Project Management in Excel - Many projects APQP and PPAP 8
S How many production runs will it take for SPC monitoring to stop? Statistical Analysis Tools, Techniques and SPC 10
M How many documents total do you currently have? Document Control Systems, Procedures, Forms and Templates 6
N How to Fix this Problem that is caused by so many different issues... Quality Tools, Improvement and Analysis 20
Ajit Basrur GHTF Releases many documents on Nov 5, 2012 ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 8
T How many complaints, defects and non-conformances are typical? Customer Complaints 5
A How many processes for an FDA Quality System (QSR)? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
