How Many Control Plans Are Required? We make over 100 products!
N
Nadeem A.
Control Plan
Hi All,
I am new to this forum and I have a question regarding control plan. If a company has more than 100 products then do we need to make a plan for each and every product?
Is there any option of avoiding this huge documentation? Or any easier way to document all products?
D.Scott
Welcome to the Cove Nadeem.
Your control plans can be generic across a family of parts/product as long as the parts/process have been reviewed for commonality.
The generic control plan can then be easily made part specific a PPAP submission if required.
I have seen some companies who state in their procedure that their job spec/work instruction is their control plan. When a "formal" control plan is required by the customer, one is prepared following the format outlined in the PPAP Reference Manual. I don't see a problem with this approach as long as the required information is in the job spec/work instruction.
I would look at what you make and see if you can group the products into families. Once you do that you may decide you don't have such a big job. If you still see a problem, ask again here.
Hope this helps
Dave
Bill Ryan - 2007
Welcome Nadeem!!
Dave is absolutely correct. If it makes sense to group "families" of parts into one Control Plan, by all means that is the way to go. That approach may still require a part by part review to insure all controls are covered in the CP.
One of the issues I ran into a few years back was differing part print revision levels (which belong in the header). What I came up with was a CP "cover sheet" listing each part and rev. level covered in that specific CP. Not a problem with our auditor(s).
Bill
N
Nadeem
Thanks Scott and Ryan,
That will help me in reducing the amount of work. I will try to build families of products but one more option which I would like to share at this forum. Can we build one generic company-wide Control Plan which begins from receiving and ends at delivery? This plan will talk about control parameters at different stages, Sampling Frequency, EvaluationTechnique, Control Method, Responsible Function and Reaction Plan. But it is department-wise rather than product specific.
For product controls, we can mention on the work instrcutions as Scott pointed out the approach.
Will there be any problem in this approach from audit view point?
Bill Ryan - 2007
This is just a quick, "knee-jerk" response. Perhaps more later.
Keep in mind that a well done PFMEA "writes" the Control Plan. If all your Failure Modes, Causes, and Controls are pretty much generic across ALL parts in your facility, you might be able to get by with a "company wide" CP (as well as PFMEA). If, however, you have differing Failure Modes/Causes/Controls for different part numbers, I think you may run into creating a monster document that could/would be "unfriendly" for use and upkeep.
Bill
N
Nadeem
but Bill PFMEA is not a mandatory requirement of ISO 9000. For QS 9000 it is must. Are you arguing that whether 'PFMEA' is mandatory or not, we should develop PFMEA for effectivness in any case?
Bill Ryan - 2007
Nadeem,
Sorry, I gave that response while in my automotive mindset.
YES , the PFMEA will enhance the effectiveness/thoroughness of the Control Plan. As I mentioned in another thread, we may or may not go through the PFMEA process for a nonautomotive part. When the company decides not to perform a PFMEA there seem to be continual updates to the "Control Plan" (we use Inspection Instructions, as opposed to the formal Control Plan, for most, if not all, nonautomotive parts) which would probably have been addressed "up front" had we decided to use the PFMEA discipline.
Bill
N
Nadeem A.
Bill,
We hadn't decided PFMEA to use in the company and thanks for clarifying the points regarding the issue of piling huge documentation.
Q How Many Control Plans Needed? Prototype, Pre-launch and Production? FMEA and Control Plans 3
P Mixed Model Assembly Line Control Plans - Many different options that are available FMEA and Control Plans 2
R Control Plans - How Many are Needed? A control plan for every part number? FMEA and Control Plans 6
C How to document many document control systems with one Document Control Procedure? Document Control Systems, Procedures, Forms and Templates 6
A How many words can be made out of "QUALITY CONTROL"? Coffee Break and Water Cooler Discussions 8
B How many nonconformances have you received on average during IATF audits? General Auditing Discussions 24
G Too many customer complaints Customer Complaints 16
I How many gauges in a Go/No Go Gauge? General Measurement Device and Calibration Topics 7
BeaBea How Many Processes should be created for each Department? Process Maps, Process Mapping and Turtle Diagrams 5
Watchcat How Many Notified Bodies are "Enough" Already? EU Medical Device Regulations 23
S How many mandays required for the below mentioned standards IEC 27001 - Information Security Management Systems (ISMS) 3
N MDR review process by notified body - How many steps exist in the review process EU Medical Device Regulations 0
F How many signatures do we need on calibration certificates? ISO 17025 related Discussions 8
M Informational From RAPS – Operating System Vulnerabilities in Many Medical Devices, Germany’s BfArM and Device Firms Warn Medical Device and FDA Regulations and Standards News 0
R Validation of Medical Device Hardware containing Software - How many to Validate ISO 13485:2016 - Medical Device Quality Management Systems 1
K How Many Samples to send for Chemistry Testing Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 3
N MDSAP Participants 2019 - How many companies are participating YTD? ISO 13485:2016 - Medical Device Quality Management Systems 20
S How many of you are using Robotic process automation for calibration lab management? ISO 17025 related Discussions 0
G Measuring customer parts on a CMM - How many decimals to report to the customer? ISO 17025 related Discussions 28
J Supplier choice limitation - Many of them dont have PSCR, VDA or even ISO 9001 VDA Standards - Germany's Automotive Standards 0
O Clean room performance qualification (pq) - How many times can I do each test? Manufacturing and Related Processes 8
G How many samples you require to test during PQ for validation of a equipment? ISO 13485:2016 - Medical Device Quality Management Systems 1
D IATF 16949: Do we have too many processes? Are they all the same? Registrars and Notified Bodies 7
D QMS Performance Based on how many NCRs were generated month to month Nonconformance and Corrective Action 8
S How many QMS processes and procedures? ISO 13485:2016 - Medical Device Quality Management Systems 2
L How many of you are Certified to IATF 16949 IATF 16949 - Automotive Quality Systems Standard 12
G How many Uncertainty Measurements for Micrometers and Calipers? Measurement Uncertainty (MU) 3
R How many Corrective Action Request can be Issued by DCMA for a single issue? Nonconformance and Corrective Action 2
A Training Program Help - Old docs, new docs, so many docs... ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
M How many Pieces to Test - Sterility Testing USP EU Medical Device Regulations 2
P Are we an outlier for so many variations of Change Management? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
M SPC with many data points from one dimension Statistical Analysis Tools, Techniques and SPC 16
S How many times do you have the term 'Requirements' in your Quality Manual? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
L How many working hours to required to implement ISO 14001 ? ISO 14001:2015 Specific Discussions 6
B ISO/TS16949 Internal Auditing - How many auditors? Internal Auditing 4
R Training Production Employees When We Have SOOO Many SOPs Training - Internal, External, Online and Distance Learning 9
P Scope Extension Audit - How many days? Do I audit all AS9100 requirements? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
J How can I manage Occurence Rates in FMEA efficiently when I have many processes? FMEA and Control Plans 9
V How many times the quality agreement has been invoked? ISO 13485:2016 - Medical Device Quality Management Systems 3
A How many laboratories are accredited to ISO 17025 in the USA? ISO 17025 related Discussions 5
R Is it possible to randomly select samples from 1 column to many column Using Minitab Software 2
L How many ISO Standards are there and time allowed for Closing NCs? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
S How many mandays are required for QMS audit? Internal Auditing 5
Ajit Basrur FDA - "We Moved Forward on Many Fronts This Year" - Margaret A. Hamburg, M.D. US Food and Drug Administration (FDA) 1
F AS9100 - How many times can the same auditor audit your system AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
J APQP Project Management in Excel - Many projects APQP and PPAP 8
S How many production runs will it take for SPC monitoring to stop? Statistical Analysis Tools, Techniques and SPC 10
M How many documents total do you currently have? Document Control Systems, Procedures, Forms and Templates 6
N How to Fix this Problem that is caused by so many different issues... Quality Tools, Improvement and Analysis 20
Ajit Basrur GHTF Releases many documents on Nov 5, 2012 ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 8
