How many fail ALL ISO 9001 registration audits - How many never make it?
#31
We are on the same side of the argument Harry, but I think the perceieved value of the actual certification has been lost because the scrutinisation of the system doesn't seem to be there.
I will guarantee you we will pass the certification, but I knwo for a fact there isnt quality in some of our key processes.
Our customers will laugh about it "Department X has ISO certification...haha shows how easy it is to get certified" etc etc.
There's one vital and critically important point that is missing from this discussion. I too have heard the comments that were made about documentation and records and then audits, review etc. (You can tell your CB isn't giving much thought to 'value added audits' if it came from them).
That key point is 'effectiveness'! You mention that "there isn't quality in some of our processes" which I'm sure you have a completely objective view of, based on the performance data from those processes.......
So, since this data will be pretty obvious - it must be available for management review etc., - then only a completely incompetent auditor would miss it during the audit, especially since the org. is only meeting minimum requirements! CB's almost never recruit morons (but then I only work in Europe/USA).
You say that you think the perceived value of certification is lost............but do you have any data? If you have anything more than a bad feeling about it, then it should come to light - maybe not to the extent you would wish, since the audit is a sample, the auditor doesn't know your management culture etc. You may pass the audit in the next few days, but can it be sustained with (apparently) poor processes? I doubt it! If you are correct in your assertions, then there's another aphorism that comes to mind;
"Every dog has his day"........
#32
I worked in a company where document control in general and configuration control in particular had holes in it that you could drive the proverbial truck through. It wasn't unusual at all, for example, to have two significantly different drawings of the same part at the same revision level. In another company, I did a survey of the closed CAs and discovered that approximately 75% hadn't come close to identifying root causes, and were never shown to be effective. In yet another company, there were parts that were continually rejected at incoming inspection and "bought off" by engineering without anything being done to correct the problem (tolerances that were almost always too tight).
In each case, there were plenty of opportunities for CB auditors to find the problems, but somehow they never did. I understand the concept of an audit being a sample and that they shouldn't be expected to catch everything, but when serious (and reasonably obvious) issues get missed (or overlooked) repeatedly, something's wrong.
I think it's a fact that's simple to see--the community of registered companies has become so saturated that the luster of registration is nonexistent. When a commodity is scarce and a lot of people want it, it becomes valuable. When everybody has it, the value is diminished. Of course, ISO certification is what you make of it, but when the bar is set so low that even companies with no legs can jump over it with relative ease no one should be surprised that certification isn't the badge of honor everyone thought it would be.
#33
I hear what you say, Jim. I'm also interested to hear your comments about the fact that the management in those places you cite and that the internal auditors didn't make a bigger deal of the fact that the systems/process etc weren't effective.......they too were part of the certification, weren't they?
I'm not proposing that two wrongs make it all right, but I wonder what the selection criteria for the CB was..........lowest price? If the company had such glowing issues, why didn't they ask for a more effective auditor?
It takes two to tango and clearly a client has an equal role in implementing as the CB does in certifying. Happily, I believe most clients know that and can justify their certification to the world. A couple of bad apples are, happily, not indicative of the whole orchard...........
#34
I already cited (in one instance) numerous times when CAs were done (some for issues discovered in IAs) and root causes/effectiveness weren't properly addressed. Practically all of what goes wrong (and right) in any company can be traced back to management, but at least part of what "independent" auditing is supposed to accomplish is to provide checks and balances. There are way too many cases where that's not happening.
I've never worked in a certified company where the CB was of the "cheap" variety. All were major CBs. As for asking for more "effective" auditors, it depends on what your definition of "effective" is. In many cases, "effective" means keeping the certificate on the wall in spite of obvious problems.
Let's go back to the beginning. The first ISO 9001 registration project I worked on was in the early 1990s, and I was actually working from a copy of BS5750. The impetus for our registration effort was the widespread and false reports--promulgatged mostly by consultants--that American companies wouldn't be able to sell products in the EU without ISO certification. While I don't recall any of the nascent CBs pushing this view, they certainly did nothing to disabuse anyone of it. Much of the perceived benefit (at the time) was built on false premises.
Another touted benefit was that customers would be able to eliminate or drastically reduce their own supplier audit activities. Another false premise, as it turned out. Yet another benefit was the "one size fits all" nature of the standard--it was supposed to be suitable for any type of manufacturing company. But it was only a few years before ISO 9000 started having babies--QS 9000 being the primary offspring.
Now, some twenty years after the first certifications, practically everyone has a lovely certificate, and American manufacturing has gone down the tubes. The automotive industry in particular has shown no signs of actually understanding what got it into the situation it's in now, and probably will never acknowledge that the huge amounts of money spent on a demonstrably ineffective supplier management effort is a large part of the cause.
Lest I be excoriated for "bashing," I acknowledge that many companies have gotten better by concentrating on control of their processes, and that in many cases that might not have happened had it not been for the requirement for them to get certified. Nonetheless, there are far too many companies that are certified that shouldn't be, and the numbers of them are too great to not think that the CBs--all of them--aren't part of the cause.
#35
Jim, your normally cogent argument has truly amazed and somewhat concerned me!
You appear to be blaming the demise of NA manufacturing and, in particular, the auto industry - on ISO certification! Were they pinning their hopes of survival on being ISO 9000 certified? Because of the extra cost, perhaps of maintaining a certified qms?
Unfortunately, I don't have time to point out all of the places I believe you've mixed your message - I'm headed to the airport - but I will say this;
I see no connection between the previous version of ISO 9000 (in particular BS), its benefits (perceived, false or otherwise) or a rush to trade in Europe compared to what happens today. Blaming the kids for the sins of the parents isn't appropriate, is it?
In my experience only a handful of companies traded in Europe - in fact, 20 years ago, I remember very few USA made products ever being for sale in Europe! Plus, you'll remember that the pre 2000 version of the standard had almost nothing which indicated an objectively effective system was a requirement! You can't reasonably lay the blame for the content of the previous versions of the ISO standard, which wasn't written with certification in mind, at the door of any CB.
Sorry, Jim, I think you've got it wrong this time........
#36
Why not try responding to what I actually wrote, and not a strawman version of it?
Sidney Vianna
Post Responsibly
#37
I agree with this assessment. There are many culprits for substandard systems, around the World, attaining and maintaining certification. CB's would be foolish if they tried to deflect the part of the blame we must bear.
Still, I contend, if 30 years and 1 million certified systems later, the process did not deliver some level of noticeable improvement, this should be deemed the pyramid scheme of the ages.
That is what I refer to the "trivialization" of the certification process. Until we solve the lack of association between system performance and certification, it will be hard to reconcile all stakeholders expectations of what a certificate should mean.
O
Obstacle3
#38
Okay heres the deal.
I have the audit end of this week.
1 of our outputs OUR PRIMARY OUTPUT is not actually tracked and measured by management. They have no idea what % go out on time, what % are error free etc.
I will be willing to bet 50,000,0000,000,000 Zimbawbean "dollars" that the auditor doesn't identify this
#39
That's "Zimbabwean," but I do like the sound of your spelling, especially if it's pronounced Zim-baw-bean. :tg:
Sidney Vianna Why do so many ISO 9001 Implementation Programs Fail? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 171
B How many nonconformances have you received on average during IATF audits? General Auditing Discussions 24
G Too many customer complaints Customer Complaints 16
I How many gauges in a Go/No Go Gauge? General Measurement Device and Calibration Topics 7
BeaBea How Many Processes should be created for each Department? Process Maps, Process Mapping and Turtle Diagrams 5
Watchcat How Many Notified Bodies are "Enough" Already? EU Medical Device Regulations 23
S How many mandays required for the below mentioned standards IEC 27001 - Information Security Management Systems (ISMS) 3
N MDR review process by notified body - How many steps exist in the review process EU Medical Device Regulations 0
F How many signatures do we need on calibration certificates? ISO 17025 related Discussions 8
M Informational From RAPS – Operating System Vulnerabilities in Many Medical Devices, Germany’s BfArM and Device Firms Warn Medical Device and FDA Regulations and Standards News 0
R Validation of Medical Device Hardware containing Software - How many to Validate ISO 13485:2016 - Medical Device Quality Management Systems 1
K How Many Samples to send for Chemistry Testing Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 3
N MDSAP Participants 2019 - How many companies are participating YTD? ISO 13485:2016 - Medical Device Quality Management Systems 20
S How many of you are using Robotic process automation for calibration lab management? ISO 17025 related Discussions 0
G Measuring customer parts on a CMM - How many decimals to report to the customer? ISO 17025 related Discussions 28
J Supplier choice limitation - Many of them dont have PSCR, VDA or even ISO 9001 VDA Standards - Germany's Automotive Standards 0
O Clean room performance qualification (pq) - How many times can I do each test? Manufacturing and Related Processes 8
G How many samples you require to test during PQ for validation of a equipment? ISO 13485:2016 - Medical Device Quality Management Systems 1
D IATF 16949: Do we have too many processes? Are they all the same? Registrars and Notified Bodies 7
D QMS Performance Based on how many NCRs were generated month to month Nonconformance and Corrective Action 8
S How many QMS processes and procedures? ISO 13485:2016 - Medical Device Quality Management Systems 2
L How many of you are Certified to IATF 16949 IATF 16949 - Automotive Quality Systems Standard 12
G How many Uncertainty Measurements for Micrometers and Calipers? Measurement Uncertainty (MU) 3
R How many Corrective Action Request can be Issued by DCMA for a single issue? Nonconformance and Corrective Action 2
A Training Program Help - Old docs, new docs, so many docs... ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
M How many Pieces to Test - Sterility Testing USP EU Medical Device Regulations 2
P Are we an outlier for so many variations of Change Management? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
M SPC with many data points from one dimension Statistical Analysis Tools, Techniques and SPC 16
S How many times do you have the term 'Requirements' in your Quality Manual? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
L How many working hours to required to implement ISO 14001 ? ISO 14001:2015 Specific Discussions 6
B ISO/TS16949 Internal Auditing - How many auditors? Internal Auditing 4
R Training Production Employees When We Have SOOO Many SOPs Training - Internal, External, Online and Distance Learning 9
P Scope Extension Audit - How many days? Do I audit all AS9100 requirements? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
J How can I manage Occurence Rates in FMEA efficiently when I have many processes? FMEA and Control Plans 9
V How many times the quality agreement has been invoked? ISO 13485:2016 - Medical Device Quality Management Systems 3
C How to document many document control systems with one Document Control Procedure? Document Control Systems, Procedures, Forms and Templates 6
A How many laboratories are accredited to ISO 17025 in the USA? ISO 17025 related Discussions 5
R Is it possible to randomly select samples from 1 column to many column Using Minitab Software 2
L How many ISO Standards are there and time allowed for Closing NCs? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
S How many mandays are required for QMS audit? Internal Auditing 5
Ajit Basrur FDA - "We Moved Forward on Many Fronts This Year" - Margaret A. Hamburg, M.D. US Food and Drug Administration (FDA) 1
F AS9100 - How many times can the same auditor audit your system AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
J APQP Project Management in Excel - Many projects APQP and PPAP 8
S How many production runs will it take for SPC monitoring to stop? Statistical Analysis Tools, Techniques and SPC 10
M How many documents total do you currently have? Document Control Systems, Procedures, Forms and Templates 6
N How to Fix this Problem that is caused by so many different issues... Quality Tools, Improvement and Analysis 20
Ajit Basrur GHTF Releases many documents on Nov 5, 2012 ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 8
T How many complaints, defects and non-conformances are typical? Customer Complaints 5
A How many processes for an FDA Quality System (QSR)? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
B How many days after an interview should I follow up on the status of the interview? Career and Occupation Discussions 10
