How many processes for an FDA Quality System (QSR)?
ariannas
OK - let me start off by saying that:
1) this is a somewhat philosophical question, and;
2) I bet it has been asked before in the context of the FDA part 820 forum but I may not be asking the search engine in the right way.
I'm mapping out the number of processes needed for a brand new FDA-compliant quality system. Not only is this for a new company, its the first time I've led this sort of effort. Our plans are to produce only a single class III medical device to start with.
After spending (way too long) working through the regulations and guidance documents, and mapping out an initial path, I'm thinking that we will need to establish about 20 processes to get things going.
I thought I had done a pretty good job keeping the number of processes down. But Some of my colleagues think I have gone SOP-crazy.
So... knowing that the real answer to "how many processes are needed" is a) as many as it takes, and; b) as few as possible, would anyone on this forum be willing to share approximately how many medium-to-high level processes they have in the FDA-oriented quality systems they are involved with? I'd dearly love to get a reality check.
v9991
while waiting for some of the experts from device industry to chip in....
let me fill in the waiting time....
you are almost right, one of the way of arriving at is have a peek at quality manual for a device industry!!!...hope that gives pretty much insight into the few references to start with...
http: //www. fda. gov /medicaldevices/deviceregulationandguidance/postmarketrequirements/qualitysystemsregulations/medicaldevicequalitysystemsmanual/default.htm- DEAD 404 LINK UNLINKED
http ://www .aami. org/QSConnect/qsfda/mdqs.manual.pdf- DEAD 404 LINK UNLINKED
http: //www .unimedsurgical .com/QUALITY-MANUAL-ISO-13485-2003-REV02.pdf- DEAD 404 LINK UNLINKED
http ://www .adctoday. com/images/PDF/qual_man.pdf- DEAD 404 LINK UNLINKED
hope these are relevant and helpfull
just in case if you have not already seen them!!!
ariannas
Thank you v9991!
I have dug into the MDQS (the target of your first two links) pretty heavily.
http :// www. fda .gov/medicaldevices/de...al/default.htm- DEAD 404 LINK UNLINKED
http :// www. aami .org/QSConnect/qsfda/mdqs.manual.pdf- DEAD 404 LINK UNLINKED
To be honest, if I had to do it all over again, I would have started with the regulations and preambles, and used the MDQS as reference. I started off with the MDQS, and found it to be a harder read than the regulations themselves. Possibly other peoples mileage will vary...
However, I have NOT seen the two quality manuals in your second two links, and I definitely will be taking a very close look at them.
http ://www. unimedsurgical. com/QUALIT...2003-REV02.pdf- DEAD 404 LINK UNLINKED
http ://www .adctoday .com/ images/PDF/qual_man.pdf- DEAD 404 LINK UNLINKED
Thanks again!
Ronen E
Problem Solver
Moderator
I have done similar things in the past, though mostly for class I and II devices.
20 sounds reasonable, but as a stand-alone figure it doesn't mean much. The term "medium/high level process" is too vague to yield a meaningful figure. If you stick to part 820 and the FDA's QSR manual (first link) you should be fine. If you're the kind of person who likes lots and lots of references and angles, I'm sure that the web is full of them (Elsmar has some goodies, naturally - did you have a look at the attachment list?), but I don't think you'd hit any gold that you haven't already.
To address your colleagues concerns, just refer them to part 820. The original FR publication (1996) preamble provides some useful insights too, and is a "semi-official" text.
Cheers,
Ronen.
ariannas
Yep, I was being a little vague/lazy when I wrote that. It seems like different quality systems have different names for each "level" of documentation. I was trying to convey: "stuff that is lower level than the actual quality manual but higher level than detailed procedures and/or work instructions."
..which is probably what I should have said in the first place. :rolleyes:
ariannas
Thanks again v9991 for sharing these quality manuals with me; that made for interesting reading.
For those who are cursed with a mind that works the way mine does, I thought I would share the below:
The first quality manual above references roughly the same number of processes (stuff in the documentation tier immediately below the quality manual) that I mapped out -- 20 or so.
The second manual seems to reference 5-6 processes, with another 2 or 3 possibly implied by the numbering but not mentioned. My guess is that this ties into the "one can address ISO with only 5 processes if you really want to" stance that I have seen mentioned sometimes.
Another interesting item of note: both of these documents address FDA as well as ISO and other important regulations/standards. It makes me wonder how similar (or different) a quality manual that addresses only FDA regulations would be from manuals that cover multiple sets of regulations...
I
isoalchemist
In the beginning... The FDA Regulations and ISO13485 were basically the same document. Over the years they have drifted apart slightly more in format than substance, but if you are compliant to one you would not get in significant trouble with the other. I'm sure a number of maps exist to show the comparison between the standards on the Cove, but I don't have a reference handy however.
However you set up your system I would have independent procedures for MDR and Recall. Officially not really part of 820, but listed as their own sections in 21CFR. Hopefully you never need them, but it's better to have them planned rather than trying to figure them out on the fly IMHO.
ariannas
Amen to that! :agree1:
BeaBea How Many Processes should be created for each Department? Process Maps, Process Mapping and Turtle Diagrams 5
D IATF 16949: Do we have too many processes? Are they all the same? Registrars and Notified Bodies 7
S How many QMS processes and procedures? ISO 13485:2016 - Medical Device Quality Management Systems 2
J How can I manage Occurence Rates in FMEA efficiently when I have many processes? FMEA and Control Plans 9
A How many processes and measurables have you identified ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
D Reducing the Number of SPC Charts used: We have many highly capable processes Statistical Analysis Tools, Techniques and SPC 6
B How many nonconformances have you received on average during IATF audits? General Auditing Discussions 24
G Too many customer complaints Customer Complaints 16
I How many gauges in a Go/No Go Gauge? General Measurement Device and Calibration Topics 7
Watchcat How Many Notified Bodies are "Enough" Already? EU Medical Device Regulations 23
S How many mandays required for the below mentioned standards IEC 27001 - Information Security Management Systems (ISMS) 3
N MDR review process by notified body - How many steps exist in the review process EU Medical Device Regulations 0
F How many signatures do we need on calibration certificates? ISO 17025 related Discussions 8
M Informational From RAPS – Operating System Vulnerabilities in Many Medical Devices, Germany’s BfArM and Device Firms Warn Medical Device and FDA Regulations and Standards News 0
R Validation of Medical Device Hardware containing Software - How many to Validate ISO 13485:2016 - Medical Device Quality Management Systems 1
K How Many Samples to send for Chemistry Testing Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 3
N MDSAP Participants 2019 - How many companies are participating YTD? ISO 13485:2016 - Medical Device Quality Management Systems 20
S How many of you are using Robotic process automation for calibration lab management? ISO 17025 related Discussions 0
G Measuring customer parts on a CMM - How many decimals to report to the customer? ISO 17025 related Discussions 28
J Supplier choice limitation - Many of them dont have PSCR, VDA or even ISO 9001 VDA Standards - Germany's Automotive Standards 0
O Clean room performance qualification (pq) - How many times can I do each test? Manufacturing and Related Processes 8
G How many samples you require to test during PQ for validation of a equipment? ISO 13485:2016 - Medical Device Quality Management Systems 1
D QMS Performance Based on how many NCRs were generated month to month Nonconformance and Corrective Action 8
L How many of you are Certified to IATF 16949 IATF 16949 - Automotive Quality Systems Standard 12
G How many Uncertainty Measurements for Micrometers and Calipers? Measurement Uncertainty (MU) 3
R How many Corrective Action Request can be Issued by DCMA for a single issue? Nonconformance and Corrective Action 2
A Training Program Help - Old docs, new docs, so many docs... ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
M How many Pieces to Test - Sterility Testing USP EU Medical Device Regulations 2
P Are we an outlier for so many variations of Change Management? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
M SPC with many data points from one dimension Statistical Analysis Tools, Techniques and SPC 16
S How many times do you have the term 'Requirements' in your Quality Manual? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
L How many working hours to required to implement ISO 14001 ? ISO 14001:2015 Specific Discussions 6
B ISO/TS16949 Internal Auditing - How many auditors? Internal Auditing 4
R Training Production Employees When We Have SOOO Many SOPs Training - Internal, External, Online and Distance Learning 9
P Scope Extension Audit - How many days? Do I audit all AS9100 requirements? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
V How many times the quality agreement has been invoked? ISO 13485:2016 - Medical Device Quality Management Systems 3
C How to document many document control systems with one Document Control Procedure? Document Control Systems, Procedures, Forms and Templates 6
A How many laboratories are accredited to ISO 17025 in the USA? ISO 17025 related Discussions 5
R Is it possible to randomly select samples from 1 column to many column Using Minitab Software 2
L How many ISO Standards are there and time allowed for Closing NCs? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
S How many mandays are required for QMS audit? Internal Auditing 5
Ajit Basrur FDA - "We Moved Forward on Many Fronts This Year" - Margaret A. Hamburg, M.D. US Food and Drug Administration (FDA) 1
F AS9100 - How many times can the same auditor audit your system AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
J APQP Project Management in Excel - Many projects APQP and PPAP 8
S How many production runs will it take for SPC monitoring to stop? Statistical Analysis Tools, Techniques and SPC 10
M How many documents total do you currently have? Document Control Systems, Procedures, Forms and Templates 6
N How to Fix this Problem that is caused by so many different issues... Quality Tools, Improvement and Analysis 20
Ajit Basrur GHTF Releases many documents on Nov 5, 2012 ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 8
T How many complaints, defects and non-conformances are typical? Customer Complaints 5
B How many days after an interview should I follow up on the status of the interview? Career and Occupation Discussions 10
