How much actual documentation is required on Shop Traveler and Documentation
tasinquefield
Hello all,
I have a question concerning shop travelers and documentation of procedures. I work for a tool & die welding and heat treating company, and we are implementing an ISO 9001 quality system.
How much actual documentation is required for what actually happens with each job in our shop? I noticed that some companies use a shop traveler, which then documents what work was done, materials used, process used, time into job, etc. Are these necessary for ISO 9001 certification? I didn't see anything about it being required, but i noticed they are used frequently.
While I like the idea of shop travelers, since each job has its own record and everything is on one piece of paper, it may be too difficult to implement in our shop since many jobs are in and out in 15 minutes. Some larger jobs may be here for weeks. Is it ok to use them for larger jobs only? Or does it have to be for all jobs? Right now, we don't really have any paperwork on what we did, except for the customer's paperwork and our shipper. For furnace jobs, we do provide to our customer and keep on file the chart recorder from the furnace, but for weld jobs we don't write down the welding process, wire used, etc. Time sheets are kept by each welder showing which jobs they worked on, however.
I'd like to have more accountability and records for what we do, but is it really necessary and worth the time?
Thanks,
Travis
CarolX
Re: Question on Shop Traveler and Documentation
Hi Travis and Welcome to the Cove -
What do you use as work instruction? Many job shops use travelers as work instructions for production personell. How the part is routed thru the shop, what operations are to be performed, what are the set-up and inspection requirements? In other words - what are the variables that must be controlled to produce the parts to customer specifications?
tasinquefield
Thanks for the reply, Carol.
Right now, we don't really have work instructions. What we do is very specialized and is mostly based on trade secrets passed down through generations of training and experience, at least in terms of welding. The welders don't have a checklist to follow, such as: heat die to 800 degrees, use certain rod, hold at angle, etc. They wouldn't make sense, since they are all trained and experienced and know what to do. Plus, each job is different, all are custom repairs to customer's specifications.
In terms of process maps, we created some that shows the primary supporting processes (welding and heat treating). The welding shows quoting-->shipping/receiving-->weigh and hardness check--> and so on.
My question is more concerned with documenting what we do. Do I need to have a record for each job showing who the welder is, how much time into the job, what welding rod/reel was used, and the process used (MIG, TIG, arc, etc.)? Right now we just have the time sheets, but everything else is pretty much kept in the head of the plant manager. A lot of what we do is standardized, so if we know a job is a P-20 mold (plastic injection mold), we know the type of rod it requires, but we haven't documented that.
Thanks.
al40
I would suggest that you document as much as possible as long as you and your organization thinks that it adds value.
Ask yourself, what would happen if the person that had important information or "Tribal Knowledge" of a particular operation that wasn't written down or part of a know standard quit or won the lottery?
I know from past experiences that you should document critical processes so that you have the information for future references.
Regards,
al40
CarolX
Really - only you can answer that questions. Sounds like you do real custom work, with no two jobs the same.
So you have process maps that show the general operations. How does anyone know all the operations to perform on a particlular job? Can those be documented in some way?
On your repeat jobs, like your example of P-20, document as much as you can - but also leave yourself some room for flexiblity.
For example - you could have a traveler that says
inspect unit for repair estimate
submit to customer
complete repair
inspect
ship to customer
Keep it simple and written in the language (wording) that everyone understands.
tasinquefield
Thanks for the replies, CarolX and al40. I guess we'll have to sit down and figure out what we need. I need more than what we have at this point, since "it's all in the plant manager's head" isn't going to work when it comes to audit time. :D
Carol, we can document some things, but again everything is custom. Yes, there are certain procedures to follow for welding, like making sure the mold is heated, the gas pressure is set correctly, voltage set properly on the welder, etc. but they aren't documented.
Benjamin28
I have to agree, tribal knowledge that is critical to operations needs documentation. On a further note though, work/traveler instructions are not only instructions, often they prove to be a system for maintaining efficient interaction between processes, and fluid flow of production.
For instance, our travelers are computerized, in this manner our production manager can look up any in process job and see what process it is in, how long its been there, who did the work, etc...when one process is completed the technician enters in the relevant data and forwards it to the next step, a lot of information is gained from this activity and it also allows us to better determine bottlenecks and quickly access an audit trail for a specific job or jobs.
At the same time the technicians can access the traveler and are supplied with specific information, special requirements, material hazards, purchase order info, relevant blueprints/dwgs, etc. It is a very effective system for controlling the flow of work and supplying staff with the information necessary to complete the job.
CliffK
Travis,
What problem are you trying to solve?
To put it another way, why is your company contemplating ISO 9001?
Hello all,
Interesting question. At a minimum, you're going to need some inspection/test/verification record for the product. Even for the fifteen minute jobs. Ref 8.2.4. Search through ISO 9001 for references to 4.2.4 - each of those references indicates the requirement for a quality record.
They're not required.
Either way is okay. If you elect to go the large job only route, you will need to set up rules for deciding which jobs get travelers and which don't. I'm not sure they're the right answer for you.
Travis
Depends on what you are trying to accomplish.
The question is, "how do they know how to do what they do?" It can be answered by detailed work instructions or it can be answered by training, experience and competence. For the latter answer, you will need to have records substantiating the welders' qualifications. Ref 6.2 of ISO 9001:2000.
For guidance on the amount of documentation needed for ISO 9001:2000, check note 2 under 4.2.1. Not much help, is it? But it does tell you that there's no cookie cutter answer.
It goes back to what you are trying to accomplish. If you are concerned about capturing the knowledge of the old greybeards (as you should be), then by all means drain their brains and get it on paper.
J How much to charge for helping a startup company with initial ISO 13485 certification? Consultants and Consulting 3
M Hiring Decisions - How much effort do you put into the hiring process these days? (7/2020) Misc. Quality Assurance and Business Systems Related Topics 6
M Do I Expect Too Much of Job Candidates? Career and Occupation Discussions 33
B ISO 9001:2015 Transition: Much Easier Than You Think! Misc. Quality Assurance and Business Systems Related Topics 0
E How much a bioequivalence study will cost in the UK Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
P So much turnover, How to improve our training process? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 32
T ISO 9001:2008 to 2015 transition - How much work to change? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
P ISO 9001:2015 4.2 and 6.1 - Interested Parties - How much detail is required? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
I How much does an eQMS (Electronic/Software QMS) cost? Quality Assurance and Compliance Software Tools and Solutions 1
J Process Capability - How much percentage of tolerance? VDA Standards - Germany's Automotive Standards 3
W How much would it cost to setup a Quality System for a Repackager or Relabeler? Quality Manager and Management Related Issues 1
G How much to pay a Freelance Six Sigma Trainer in India Six Sigma 1
M 7.5.3.2 Traceability - How much traceability is required? ISO 13485:2016 - Medical Device Quality Management Systems 6
S How much do trainers charge typically for an Adobe Connect / WebEx based training? Training - Internal, External, Online and Distance Learning 3
kedarg6500 How much test force to be applied for Vickers hardness Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
D AS9100 Recertification Audits - How much in advance of the Certificate Expiration AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
J Sourcing a Sterile Product - Asking for supplier for too much regulatory stuff? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
D IMR (Individuals and Moving Range) Chart for Short-Run SPC - How much data to include Statistical Analysis Tools, Techniques and SPC 1
V How much Supplier Information do I have to provide to a Customer? APQP and PPAP 6
V For an RSM, how much R-sq is good R-sq Using Minitab Software 3
R How much Protective Current Rating of Building Branch Circuit should be considered? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
R How much "harder" is an ISO 13485 Registration Audit compared to ISO 9001 ISO 13485:2016 - Medical Device Quality Management Systems 6
M MSA - According to the formula cg how much tolerance should be put in place? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
Sidney Vianna The frequent flyers that flew too much... Unlimited AAirpass Coffee Break and Water Cooler Discussions 11
E Consulting Fees - How much to charge Career and Occupation Discussions 33
A How Much Validation is needed for OTS Software - Marketing material only 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
G How much time must pass after the first Certification Audit for us to appear in OASIS AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
A Advice on setting up BD Distribution Deals - How much oversight is required? Quality Manager and Management Related Issues 2
K Key Employees and Officers - How much conflict is tolerable? Quality Manager and Management Related Issues 19
A How much effort is needed for Certification of Class II Medical Devices ISO 13485:2016 - Medical Device Quality Management Systems 9
Stijloor Thank you very much!! Covegratulations 5
K Supplier Audit - How much information do we have to give them? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
Q Document Control Procedure - Too much detail? Document Control Systems, Procedures, Forms and Templates 8
somashekar Too much data, Too little analysis - Manual Stages Assembly Shop Data Collection Quality Tools, Improvement and Analysis 2
R OASIS Database Fees - How much are you paying your CB? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
M Defining what is a Medical Device Accessory and what isn't - Much Confusion EU Medical Device Regulations 8
A Customer SQE - Within Specification but too much Variance Customer Complaints 7
A What to do when customer requirements are too much? Quality Manager and Management Related Issues 29
D How much Tolerance do I use to Calibrate a 150kgs capacity Scale? General Measurement Device and Calibration Topics 5
M How much Process Description is required or needed? ISO 13485:2016 - Medical Device Quality Management Systems 10
D How much Deviation is Acceptable when Calibrating a Hygrometer? General Measurement Device and Calibration Topics 3
L FDA Audit - How much advance notice do foreign manufacturers get? ISO 13485:2016 - Medical Device Quality Management Systems 4
R MSDS Sheets for Products - How much is too much - Or is there ever too much? Occupational Health & Safety Management Standards 12
T How much information should I keep in my Master Document Register? Document Control Systems, Procedures, Forms and Templates 8
4 Change Control Systems - How much is too much? Document Control Systems, Procedures, Forms and Templates 10
Marc Saying "I only had one beer" doesn't mean much any more Coffee Break and Water Cooler Discussions 3
R NQA-1 Quality Manual vs. Standard - How much should they differ Quality Management System (QMS) Manuals 7
Q How much detail in DHR (Device History Record) is too much? US Food and Drug Administration (FDA) 3
F How much longer can a company declare registration to ISO 9001:2000? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 21
