How much to charge for helping a startup company with initial ISO 13485 certification?
Hello, I have been referred by my colleague to help a startup company set up their ISO 13485: 2016 QMS and the problem is this is my first time and I have no idea how much to charge for this project, in which I prefer a lump sum for the whole project.
Here is the scope of the work expected of me and it is quite extensive:
1. Draft complete QM, SOP, WI, QF tailored to the company. The company size is small 3-5 people at most.
2. The company is a repackage, relabler, and distributor of IVDs under its own brand. The OEM products are made else where in which will need to execute quality agreement with. The only product this company produce itself are bunch of antibody/antigen reagents.
3. I'm expected to travel onsite, inspect the place and make their entire reagent operation ISO compliant.
4. Help making reagent production GMP compliant.
5. Help implement the QMS Documents that also covers IVD part which means having the company take over the responsibility to oversee the quality aspect of the IVD Production at OEM sites. Design control, complaint handling, etc because the goal of the company is to have manufacturer of IVD as part of the Scope on the ISO certificate.
6. Train internal auditors
7. Possibly help looking for and setting up a QMS software solution like cloud based sharepoint
8. Possibly sit through the initial certification audit
As you can see the workload is quite heavy as I'm pretty much holding their hands through the entire process and may take quite a while as a side job since I can't work on it during the day. I just have no idea how much I should charge for this service in fear of underquoting or overquoting my work. Would $50000 be a reasonable starting point or is it too low or too high? Any idea is appreciated. Just reminder that this is a start up company of only 2-3 people.
John Broomfield
When you become experienced (successfully completing ten projects with a variety of clients) you should be able to elicit the client's business objectives in terms of what they want to achieve with their certified system.
From this and other inputs you should be able to design your management system consulting and training services to result in a service spec including the schedule of tasks and milestones, responsibilities of the client and the consultant, the deliverables and a lump sum inclusive of expenses.
The value to the client of fulfilling their objectives should be two or three times what you charge the client for helping them to develop their management system. But I agree with @normzone not to try the lump sum approach just yet.
monoj mon
I would suggest to evaluate yourself, how much money your suggestions/help worth depending on your seniority. Also, evaluate yourself how quickly you can accomplish the task. For example, if this is your first consultancy job then you may not have the level of experience that one seasoned consultant has. So, it will not be reasonable to charge your client an equivalent amount what other experienced consultants used to charge. Additionally, I would suggest you to charge on the basis of hour and not to charge a lump sum amount as (I guess) you are not aware of the hidden costs that you may face during this journey. So, below are my two cents;
1. As it sounds from your post that you have a regular job. So, first figure out how much you earn on daily basis from your regular job and determine your consultancy fee/hour around that figure. I have seen consultant (with lesser experience in consultancy but with more job to accomplish in a single project) from some firms charging between 100-150$ per hour whereas consultants (with more experience but with role of supervising and approving tasks in a project) from the same firm charge nearly two times of that. Ultimately both are earning almost equivalent amount from that project but the former one does a lot of job while the experienced consultants brings his/her pool of knowledge to make the project a perfect one. That is why I suggest (again) to evaluate yourself, which experience bracket you want to put yourself in. Ultimately that start-up is paying for your experience and to some extent for your hard work.
2. Set aside your travel and other expenditure from your hourly charge. That is why setting a lump sum amount may backfire you if you end up spending more and more money in your travel and other things. I used to be in a start-up and I saw the consultants (even the seasoned one) we hired they always tried to provide us a minimalist expenditure list for their travel and other stuffs. This helped us to gain faith on them and also helped us to nurture a long term relationship with them.
S How much do trainers charge typically for an Adobe Connect / WebEx based training? Training - Internal, External, Online and Distance Learning 3
E Consulting Fees - How much to charge Career and Occupation Discussions 33
C How much to charge to be a Management Representative? Career and Occupation Discussions 22
T How much does an accreditation body charge a registrar for auditing? Registrars and Notified Bodies 5
Q The Management system is too much ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
M Hiring Decisions - How much effort do you put into the hiring process these days? (7/2020) Misc. Quality Assurance and Business Systems Related Topics 6
M Do I Expect Too Much of Job Candidates? Career and Occupation Discussions 33
B ISO 9001:2015 Transition: Much Easier Than You Think! Misc. Quality Assurance and Business Systems Related Topics 0
E How much a bioequivalence study will cost in the UK Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
P So much turnover, How to improve our training process? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 32
T ISO 9001:2008 to 2015 transition - How much work to change? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
P ISO 9001:2015 4.2 and 6.1 - Interested Parties - How much detail is required? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
I How much does an eQMS (Electronic/Software QMS) cost? Quality Assurance and Compliance Software Tools and Solutions 1
J Process Capability - How much percentage of tolerance? VDA Standards - Germany's Automotive Standards 3
W How much would it cost to setup a Quality System for a Repackager or Relabeler? Quality Manager and Management Related Issues 1
G How much to pay a Freelance Six Sigma Trainer in India Six Sigma 2
M 7.5.3.2 Traceability - How much traceability is required? ISO 13485:2016 - Medical Device Quality Management Systems 6
kedarg6500 How much test force to be applied for Vickers hardness Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
D AS9100 Recertification Audits - How much in advance of the Certificate Expiration AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
J Sourcing a Sterile Product - Asking for supplier for too much regulatory stuff? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
D IMR (Individuals and Moving Range) Chart for Short-Run SPC - How much data to include Statistical Analysis Tools, Techniques and SPC 1
V How much Supplier Information do I have to provide to a Customer? APQP and PPAP 6
V For an RSM, how much R-sq is good R-sq Using Minitab Software 3
R How much Protective Current Rating of Building Branch Circuit should be considered? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
R How much "harder" is an ISO 13485 Registration Audit compared to ISO 9001 ISO 13485:2016 - Medical Device Quality Management Systems 6
M MSA - According to the formula cg how much tolerance should be put in place? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
Sidney Vianna The frequent flyers that flew too much... Unlimited AAirpass Coffee Break and Water Cooler Discussions 11
A How Much Validation is needed for OTS Software - Marketing material only 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
G How much time must pass after the first Certification Audit for us to appear in OASIS AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
A Advice on setting up BD Distribution Deals - How much oversight is required? Quality Manager and Management Related Issues 2
K Key Employees and Officers - How much conflict is tolerable? Quality Manager and Management Related Issues 19
A How much effort is needed for Certification of Class II Medical Devices ISO 13485:2016 - Medical Device Quality Management Systems 9
Stijloor Thank you very much!! Covegratulations 5
K Supplier Audit - How much information do we have to give them? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
Q Document Control Procedure - Too much detail? Document Control Systems, Procedures, Forms and Templates 8
somashekar Too much data, Too little analysis - Manual Stages Assembly Shop Data Collection Quality Tools, Improvement and Analysis 2
R OASIS Database Fees - How much are you paying your CB? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
M Defining what is a Medical Device Accessory and what isn't - Much Confusion EU Medical Device Regulations 8
A Customer SQE - Within Specification but too much Variance Customer Complaints 7
A What to do when customer requirements are too much? Quality Manager and Management Related Issues 29
D How much Tolerance do I use to Calibrate a 150kgs capacity Scale? General Measurement Device and Calibration Topics 5
M How much Process Description is required or needed? ISO 13485:2016 - Medical Device Quality Management Systems 10
D How much Deviation is Acceptable when Calibrating a Hygrometer? General Measurement Device and Calibration Topics 3
L FDA Audit - How much advance notice do foreign manufacturers get? ISO 13485:2016 - Medical Device Quality Management Systems 4
R MSDS Sheets for Products - How much is too much - Or is there ever too much? Occupational Health & Safety Management Standards 12
T How much information should I keep in my Master Document Register? Document Control Systems, Procedures, Forms and Templates 8
4 Change Control Systems - How much is too much? Document Control Systems, Procedures, Forms and Templates 10
Marc Saying "I only had one beer" doesn't mean much any more Coffee Break and Water Cooler Discussions 3
R NQA-1 Quality Manual vs. Standard - How much should they differ Quality Management System (QMS) Manuals 7
