How Probability of Acceptance of a Part is Calculated
Rameshwar25
Can Someone explain me the methodology adopted in determining the probability of accepting a part with given ref value.
This has been explained on Page 177, 178 of MSA manual 4th Ed.
My confusion is how Ø(9.0)-Ø(1.0)=1.0-0.84=0.16 -Pg 178, Line-12
and how Ø(5.0)-Ø(-3.0)=0.999 -Pg 178, Line-20
regards
rameshwar
Barbara B
The greek symbol Phi (uppercase) indicates the standard normal distribution, that is the normal distribution with mean 0 and standard deviation 1.
To calculate the values in the MSA manual in Excel you could use the function NORMDIST
Phi(9.0): =NORMDIST(9.0, 0, 1, 1) value: 1.000000000
Phi(1.0): =NORMDIST(1.0, 0, 1, 1) value: 0.841344746
Phi(5.0): =NORMDIST(5.0, 0, 1, 1) value: 0.999999713
Phi(-3.0): =NORMDIST(-3.0, 0, 1, 1) value: 0.001349898
The difference between Phi(9.0) and Phi(1.0) is 0.16=16%. This equals the probability of acceptance and therefore the probability of rejection is 100%-prob_acceptance = 100%-16%=84%. (The same goes for the third and fourth value.)
Best Regards,
Barbara
Rameshwar25
Thank you Barbara
Further, i would ask that the syantax for normdist is: NORMDIST(x, mu, sigma, cumulative). It means that the value is dependent on Mean and Std Dev also.
But in your answer (Phi(9.0): =NORMDIST(9.0, 0, 1, 1) value: 1.000000000), you have assumed mean=0 and std dev=1.
Kindly refer Example given on Pg 178 (sample pages attached) and show the calculation with real std dev given in example.
Thanks and regards
Rameshwar
Barbara B
The values in the MSA manual are based on the standard normal distribution (mean=0, stddev=1), because they are standardized by the formula itself.
On page 177 the distribution of the actual value is given as normal distribution with mean (X_T+bias) and standard deviation sigma^2, so the probability for accepting a part P_alpha is the integral form LSL (lower specification limit, LL in MSA manual formula) to USL (upper specification limit, UL in MSA manual formula). This could be directly calculated with
P_alpha = NORMDIST(LL, X_T+bias, sigma, 1) - NORMDIST(UL, X_T+bias, sigma, 1)
For the example given in the MSA manual (see p.178):
LL=LSL=0.6, UL=USL=1.0, b=0.05, sigma=0.05, X_T=0.5 (reference torque value)
NORMDIST(UL, X_T+bias, sigma, 1) = NORMDIST(0.6, 0.5+0.05, 0.05, 1) = 0.841344746
NORMDIST(LL, X_T+bias, sigma, 1) = NORMDIST(1.0, 0.5+0.05, 0.05, 1) = 1.000000000
P_alpha = 1.0 - 0.841344746 = 0.16 = 16%
But instead of using the values directly in the MSA manual, the values are first standardized:
subtract mean (X_t+b), divide result by standard deviation (sigma)
yielding 9.0 and 1.0 in the first example, but with equal result as in the direct calculation of the acceptance probability:
Phi( ( UL - (X_t+b) )/sigma ) - Phi( LL - (X_t+b) )/sigma )
= Phi( ( 1.0 - (0.5+0.05) )/0.05 ) - Phi( 0.6 - (0.5+0.05) )/0.05 )
= Phi(9.0) - Phi(1.0)
= NORMDIST(9.0, 0, 1, 1) - NORMDIST(1.0, 0, 1, 1)
The benefit of first standardizing the real values and than using the standard normal distribution Phi (mean 0 and stddev 1) like in the MSA manual proposed is, that you can look up the values in textbooks without access to Excel or a statistics software package. The result remains the same (and it is IMHO questionable if this approach is an advantage compared to the direct calculation not shown in the MSA manual as today nearly everyone has access to at least Excel).
I hope this clarifies your question further.
Best regards,
Barbara
Rameshwar25
Hello Barbara
Thank you very much for such a detailed answer. I am very much clear now on the subject. This has helped me in making a GPC (gauge performance Curve) for the example given in MSA manual.
The GPC has been given in my another thread posted today just to share with other readers.
Thank you once again.:thanx:
Best Regards
Rameshwar
Sravan Manchikanti Software Risk Management & probability of occurrence as per IEC 62304 IEC 62304 - Medical Device Software Life Cycle Processes 8
M Should volume of sales be factored into risk probability assessments? ISO 14971 - Medical Device Risk Management 33
MrTetris How to qualitatively assess initial probability ISO 14971 - Medical Device Risk Management 4
R Probability - Need a help to solve the below question Statistical Analysis Tools, Techniques and SPC 5
Ronen E Tolerance intervals (?) question - Flow Rate Probability Range Statistical Analysis Tools, Techniques and SPC 6
K Small Sample - Lower Limit Probability Statistical Analysis Tools, Techniques and SPC 0
Y IEC 62304 Section 4.3(a) - 100% probability of failure IEC 62304 - Medical Device Software Life Cycle Processes 3
L Balls drawn without replacement probability question Brain Teasers and Puzzles 8
L How to calculate the Probability of Deficiency of the AQL of an Inspection AQL - Acceptable Quality Level 16
Marc Definition PFH - Probability of dangerous failure per hour Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 0
Marc Definition PFD - Probability of failure on demand Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 0
A Risk Acceptability Criteria - Probability and Acceptability Level ISO 14971 - Medical Device Risk Management 1
M Risk Probability - Is there a Better System? ISO 14971 - Medical Device Risk Management 18
J Can Normal Probability Paper and GPC be created with Excel Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
Z What is the Probability of Picking Up "Good" alphabets? Six Sigma 6
N Hazard Probability of Occurrence Definition ISO 14971 - Medical Device Risk Management 11
E Risk Management selection Probability of Occurrence and Severity ISO 14971 - Medical Device Risk Management 24
C How to calculate P value on Probability Plot Statistical Analysis Tools, Techniques and SPC 1
Bev D Probability question - Components of Variation study on a single use diagnostic test Statistical Analysis Tools, Techniques and SPC 1
P One sided confidence interval for probability plot in Minitab Using Minitab Software 1
K Probability of Occurrence Ranking for Low Volume Manufacturing vs High Volume FMEA and Control Plans 11
T Repeated Inspection - Probability of Visual Inspection catching Defects Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
L "Half Normal Plot vs Normal Probability Plot" of Effects Using Minitab Software 1
U PROBLEM: Probability of Resource Access Collision Statistical Analysis Tools, Techniques and SPC 5
S Software Risk Estimation: Probability of Medical Device Software Anomaly Occuring ISO 14971 - Medical Device Risk Management 9
N Bayes Law of Conditional Probability ("The Drunkard's Walk" by Mlodinow) Statistical Analysis Tools, Techniques and SPC 1
S Probability Density Function of a Function of a Random Variable Statistical Analysis Tools, Techniques and SPC 13
V Preparing for SSGB - Six Sigma Probability Question Six Sigma 13
R Risk Management - Probability vs. Frequency IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
V ASQ CSSGB - More In Depth Probability and Sampling Methods prep materials Book, Video, Blog and Web Site Reviews and Recommendations 4
A Probability of a good lot given that the sample was good Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
B Plotting Probability Exceedance using the Probability Plot Graph in Minitab Using Minitab Software 4
I Mathematical Probability Puzzle Brain Teasers and Puzzles 25
1 What are TOP, DPU, DPO, DPMO? Mult-CTQ (discrete) ZST - Is this a probability? Six Sigma 1
B Probability of finding a Defective Part - Probability question Statistical Analysis Tools, Techniques and SPC 8
D ISO 2859 - Probability that sample size is sufficient Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
C Multiple Censored Tests to find out the Survival Probability Reliability Analysis - Predictions, Testing and Standards 3
M Probability Distribution Problem Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
M Confidence Interval on Normal Probability Plot Using Minitab Software 2
bobdoering How's this for a probability function? Player Hits Own Mom With Foul Ball Funny Stuff - Jokes and Humour 7
D Probability of Failure - Seven expansion joints Reliability Analysis - Predictions, Testing and Standards 5
bobdoering Goodness of Fit: Is it normal? Probably...or probably not - it's all probability Imported Legacy Blogs 0
J Xbar - R Control Chart taking into account the Probability Limit Using Minitab Software 8
0 Calculating axis values of normal probability plot Statistical Analysis Tools, Techniques and SPC 4
R Sampling - Total probability of accepting bad lot - Producer's risk Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
W Interpreting a Normal Probability Plot Statistical Analysis Tools, Techniques and SPC 4
A Actual probability of TYPE I error for 3 sigma P-chart Statistical Analysis Tools, Techniques and SPC 10
G Running simulations using Bernoulli Distributions with a certain probability. Using Minitab Software 5
A Probability of points outside of... Statistical Analysis Tools, Techniques and SPC 2
J Failures-in-time (FITs), DPPM and Probability Calculation Questions Reliability Analysis - Predictions, Testing and Standards 9
