How Reliable are Published Methods (ASTM,FDA) when referenced in a lab?
Susiepmt
How reliable are published methods ie) ASTM, FDA When a published method is referenced in a lab method ... does the lab need to be accredited for the published method?
Daniel Walker - 2011
I am not aware of any possible accreditations for published methods (procedures)
You should check with your accreditation body to see what organizations they recognize as publishing "validated" procedures. If you do adopt a procedure from an organization such as ASTM you need to be aware of any updates or revisions.
Craig H.
Be aware that a test method, as published, is still subject to interpretation and differences in lab instrumentation and equipment. They are not the "be all, end all".
Ajit Basrur
If I understand your question right, are you saying if a non accreditated lab cab can use published methods from ASTM or FDA ?
If this was your question, YES, any lab can use these methods. In fact the classic example is of the various Pharmacopeia like United States Pharmacopeia, European Pharmacopeia, British Pharmacopeia and various similar documents which mention monographs for testing each materials.
These monographs including their test methods are to be used for testing the materials for showing compliance.
Hope this clarifies.
Susiepmt
I believe my question was not clear enough ... so I'm going to try again.
Lets say that you are an accredited lab ... and you are being audited to maintain your accreditation. You seek to add a couple of methods to your scope which are developed by the lab based on a published method. You reference this published method in the references section of the method ... would you need to be accredited for the published method aswell as the lab method ... or do you only seek accreditation for the lab method because the published method is considered to be scientifically sound by industry and regulating bodies ?
Thank you.
Benjamin28
If your testing procedure meets all the requirements of the controlling specification (ASTM or other) then you only need be accreditted to the standard test method.
If, however, you are deviating from the ASTM specification and performing a test "method" that is entirely home brewed you will need to show significant data to validate the method used. If this is the case, I would contact your AB for further guidance as you wouldn't want to commit significant resources to validating a method only to have your AB reject it in audit.
I hope I've interpretted the question correctly...I believe you're asking if you produce an internal laboratory "procedure" based on an ASTM test "method" would you only need accreditation to the ASTM method. If this is the correct interpretation of the question then the answer is yes. ;)
Mr Niceguy
Susiepmt,
I don't know how generic your test methods are but I suppose in some specialised areas an AB might allow accreditation of the simplest published methods exactly as written, but why not write your in-house version with citation and just accredit that. It can be brief as long as you show the deviations are valid. Otherwise are you really going to use the published method as a local work instruction ? Our scope is full of "in-house SOPxxx based on ISOxxxx, ASTMxxxx" etc.
I have written a published test procedure for a UK regulatory agency which became an ISO standard, then later an ASTM method was based on it, but even I as original author have my own accredited in-house version.
Hershal
Metrologist-Auditor
Thank you.
Given this scenario, the scope of accreditation will likely reference the published method, not the distilled method.....
Incidentially, taking the published method (e.g., ASTM), referencing that method and only distilling it in order to add specific detail like "Use this fixture" or "Turn this switch" is usually not considered "lab developed" and usually does not require separate validation, except for the specific detail added for your specific lab and equipment.
Of course, double-check with your AB, as they may have specific rules for such distilled procedures.
Hope this helps.
A Reliable sources for following EU medical device regulatory EU Medical Device Regulations 0
H Reliable Prototype PCB service manufacturer Manufacturing and Related Processes 3
7 Is testing 99.7% reliable? Reliability Question Reliability Analysis - Predictions, Testing and Standards 3
A Where to get the cheapest yet reliable airline tickets Travel - Hotels, Motels, Planes and Trains 12
C GM wants reliable software World News 0
O EN 301 489-1 and EN 301 489-17 - Where do we get the information of the Published versions? CE Marking (Conformité Européene) / CB Scheme 1
dgrainger Informational UK guidance on Device regulation from Jan 2021 published UK Medical Device Regulations 19
dgrainger Informational UK guidance on FSNs - Published 20 May 2020 UK Medical Device Regulations 1
dgrainger Informational EU published new Harmonised Standards List for the Directives (25/3/2020) Medical Device and FDA Regulations and Standards News 0
Richard Regalado ISO 22301:2019 has been published - Nov 2019 Business Continuity & Resiliency Planning (BCRP) 0
W Informational VDI 2017 - Medical Grade Plastics - German VDI has published a "Richtlinie" Other Medical Device Related Standards 1
M Informational Team-NB published a press release regarding the survey run among its members to analyse the certificates being issued Medical Device and FDA Regulations and Standards News 0
A Timeline for harmonised standards to be published under MDR CE Marking (Conformité Européene) / CB Scheme 5
M Informational EU – Corrigenda for MDR and IVDR published in Official Journal Medical Device and FDA Regulations and Standards News 0
M Informational Corrigendum for the EU IVDR Published Medical Device and FDA Regulations and Standards News 0
M Informational Corrigendum for the EU MDR Published Medical Device and FDA Regulations and Standards News 0
M Informational Team-NB published a press release regarding the capacities of notified bodies to meet the sector needs Medical Device and FDA Regulations and Standards News 0
M Medical Device News Medical Device Directives – New templates for Field Safety Notices published Medical Device and FDA Regulations and Standards News 0
M Medical Device News Novas normas publicadas pelo ABNT/CB-026 / New standards published by ABNT/CB-026 Medical Device and FDA Regulations and Standards News 0
M Is there a published List of AIAG members requiring IATF certification ? IATF 16949 - Automotive Quality Systems Standard 2
M Medical Device News New guidance sheets for the MDR/IVDR published EU Medical Device Regulations 0
planB ISO 10993-1:2018 has just been published Other Medical Device Related Standards 2
Richard Regalado ISO 31000:2018 is now published! Risk Management Principles and Generic Guidelines 0
bio_subbu CAMD published FAQs to the transitional provisions of MDR and IVDR EU Medical Device Regulations 0
Ajit Basrur Informational ISO/IEC 17025:2017 Published - November 2017 ISO 17025 related Discussions 8
M MDR and IVDR to be published May 5th 2017 EU Medical Device Regulations 14
S Use of Published IMDS Data from our Raw Material Supplier RoHS, REACH, ELV, IMDS and Restricted Substances 6
S 'Clean' Draft Medical Device Regulations Published EU Medical Device Regulations 0
M MEDDEV 2.7/1 rev.4 published - June 2016 EU Medical Device Regulations 42
bio_subbu Official Journal of EU published two new RoHS Exemptions EU Medical Device Regulations 1
M IEC 62366-1 published - March 2015 IEC 62366 - Medical Device Usability Engineering 7
T When will IEC 60601-1-2 Ed.4 be published? IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
M EN ISO 60601-2-22:2013 hasn't been published in OJEU yet Quality Manager and Management Related Issues 11
G What are the changes in the BS EN 1041:2008 recently published amendment Other Medical Device Related Standards 11
S Unannounced Audits - Commision Recommendation 2013/473/EU Published 25.9.2013 CE Marking (Conformité Européene) / CB Scheme 6
bio_subbu Eucomed published guidance document on RoHS 2.0 EU Medical Device Regulations 13
G New list (01-2013) of Harmonised Standards for The MDD published EU Medical Device Regulations 18
I New AIAG CQI guidelines published - Are they worth buying? Misc. Quality Assurance and Business Systems Related Topics 2
Sidney Vianna EMS auditor competence ISO Standard published - ISO/IEC TS 17021-2:2012 Miscellaneous Environmental Standards and EMS Related Discussions 1
S EU Medical Devices (Amendment) Regulations 2012 have been published EU Medical Device Regulations 2
Richard Regalado ISO 22301 was published 2012 May 15 - New Standard for BCM - Published! Business Continuity & Resiliency Planning (BCRP) 2
W MEDDEV: Qualification and Classification of Stand Alone Software Published EU Medical Device Regulations 4
AnaMariaVR2 GMP News: New Version of ISO 19011 on Auditing published Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 2
D Is ISO/TS 16949:2009 due for review and new edition to be published in 2012? IATF 16949 - Automotive Quality Systems Standard 6
RoxaneB Just been published! Coffee Break and Water Cooler Discussions 23
P New Renault CSR just published on the IATF Global Oversight webpage Customer and Company Specific Requirements 0
chris1price The final version of the RoHS2 recast was published last week as 2011/65/EU RoHS, REACH, ELV, IMDS and Restricted Substances 8
W MDDS Final Rule Published - February 15, 2011 US Food and Drug Administration (FDA) 0
bio_subbu CDSCO Published Draft version of Medical Devices Guidance Documents Other Medical Device Regulations World-Wide 3
bio_subbu Egyptian MOH published ?Draft Regulation for Medical Devices? Other Medical Device Regulations World-Wide 2
