How RTY (Rolled Throughput Yield) applies to different industries
bdinicola
We are a manufacturing facility that specializes in high speed CNC maching, mainly brass and copper. The management team was recently challenged with developing and implementing an RTY metric. RTY itself is very straight forward, however, how to apply to our specific industry is challenging. It was requested that we apply it by part and apply it by machine. We have about 120 different machines that manufacture in the neighborhood of 10K different parts. My thought is that we can use RTY to evaluate processes if used in short intervals, not looking at things on a monthly basis or longer. I don't believe that RTY was intended to be applied for machine evaluation. That is more of an efficiency application. The other variable is some of our parts may have 6-9 processes they go through. Any guidance or thoughts on how we could apply this would be greatly appreciated. I think what has happened is that someone at corporate saw or heard that RTY was "a really neat metric to make the plant report", without understanding it's true basis of application and that it is really intended to identify processes where improvements can be made. Thanks in advance for your help.
insect warfare
QA=Question Authority
Re: How RTY applies to different industries
I agree with you that it should be applied to processes, and not machines or parts. It is probably more applicable if you can apply RTY by lines that exhibit similar characteristics or use similar processes, and then do your comparisons to monitor performance that way. Not too long ago, I attached a short presentation in this post that we used for internal training on the true application of RTY (Rolled Throughput Yield).
Brian :rolleyes:
N Definition TDU (Total Defects per Unit) and RTY (Rolled Throughput Yield) Definitions Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 5
H Rolled Throughput Yield (RTY) Loss - Can you measure in PPM? Six Sigma 3
S RTY (Rolled Throughput Yield) - Use Poisson Distribution Calculation Quality Tools, Improvement and Analysis 4
H Rolled Throughput Yield (RTY) Calculations for a Sequential Process Six Sigma 2
B How to define and Calculate the DPU, DPMU, DPMO, Yield, Rolled Throughput Yield (RTY) Manufacturing and Related Processes 3
S DPMO (Defects Per Million Opportunities) vs. RTY (Rolled-Throughput-Yield) Six Sigma 7
L RTY (Rolled Throughput Yield) Calculation Other ISO and International Standards and European Regulations 4
M Question About Rolled Throughput Yield Manufacturing and Related Processes 5
M Rolled Throughput Yield Benchmarking 0
P Is throughput yield the same as FPY or FTY? Rolled Throughput Yield Manufacturing and Related Processes 3
J SST .625 dia Cold Rolled 303 bar and Magnetism Manufacturing and Related Processes 6
L Wearing an ESD Smock with Rolled Up Sleeves Misc. Quality Assurance and Business Systems Related Topics 4
R How to determine the Thickness tolerance of the Cold Rolled Steel Manufacturing and Related Processes 6
B Hot Rolled Steel Coil Rust Prevention Tests Manufacturing and Related Processes 3
Bev D World Class Rolled Throughput Yields - 2012 Six Sigma 1
F Rolled Throughput Yield and Confidence Interval Six Sigma 3
P Trying to figure Minor ? on Female Rolled Threads Various Other Specifications, Standards, and related Requirements 1
G How do I calculate PPM from a Rolled Wire Suppllier Supplier Quality Assurance and other Supplier Issues 3
A Ovality and Flatness generated after Heat Treatment of Rolled Rings Manufacturing and Related Processes 3
D Herringbone Defect Condition in Rolled Steel Misc. Quality Assurance and Business Systems Related Topics 3
E Normalized vs. Rolled Throughput Yield - First Pass Yield metrics for our processes Manufacturing and Related Processes 16
F Technical question - U-BOLT microscopic cracks on the tooth of the rolled thread Manufacturing and Related Processes 14
C Standard for surface roughness on hot rolled steel Manufacturing and Related Processes 2
J How to Define Scrap Metrics & Objectives - Stamped Cold Rolled Steel Fasteners ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
E NCR (Nonconformance Report) for device defects - Hot rolled coils Nonconformance and Corrective Action 1
K Resistance welding process - Cold rolled and some zinc plated welding Various Other Specifications, Standards, and related Requirements 2
K Resistance Welder Settings for cold rolled and galvanized steel Manufacturing and Related Processes 3
R Rolled Throughput Yield - Is anyone using this metric, and if so, how Lean in Manufacturing and Service Industries 6
apestate Tolerances for cold rolled, hot rolled, DOM tubing Other ISO and International Standards and European Regulations 10
D Flatness tolerances for tempered cold rolled stainless steel coils Manufacturing and Related Processes 3
K Definition Throughput - Definition and Calculation Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 1
L Definition Throughput Yield (TPY) or First Pass Yield Calculation - Help Needed Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 3
F Throughput time measurement Cpk summary Capability, Accuracy and Stability - Processes, Machines, etc. 2
B Calculating Throughput Yield or Yield Six Sigma 10
P How Do I Measure Productivity? Throughput yield? OEE measures? Misc. Quality Assurance and Business Systems Related Topics 3
