How should I analyze measurement correlation between me and customer?
QE1993
We have to do this in a pinch, so we don't have a large sample size to work with.
We measured 21 parts and they measured the same 21 parts.
Now, I"m unsure what to do with this data.
Normally, I would put something like this into an expanded GR&R study, but I'm not sure that we have enough data points for that to be representative.
I've tried finding the correlation coefficient between the 2 sets of data, but have no idea what the threshold for that is. I know it should be close to 1, but how close? I also don' t know if this is the appropriate stat.
Any suggestions?
Ninja
Looking for Reality
FWIW, I've often simply sent the data to the customer with a nice note saying, "Looks great to me, please confirm".
Don't let the data cover over the purpose...
Ninja
Looking for Reality
LOL...I thought of that right as I hit the "post reply" button...
In that case, I would call the customer and discuss the data and collection technique...same as if the customer took a look at what I sent and replied "no, it doesn't look adequate".
Either way, it is the customer handling the data that generates approval, not my handling of it...I guess that was the point of my post.
Thanks for calling me on it.
Welshwizard
You measure 21 parts and your customer measures 21 parts. You hint at normally using GRR so that implies that you have measured the 21 parts with multiple people or some other level.
As you wish to compare against your customer, they must also carry out the same process and procedure otherwise any comparisons are nonsense. In particular, the achievement identified in step 3 is critical.
The process I describe is an alternative to GRR which could also be performed, it would however take a long time to complete for the 21 parts although it would also be possible to substitute the estimate for part variation of the 21 parts into a GRR study.
1.
I would select one of your parts and measure it at least 20 times using your most familiar operator over an appropriate time frame to expose any sources of variation.
2.
I would arrange the data in time series order and plot them on an individual moving range chart. Any points outside the control limits will indicate a lack of measurement consistency which would need to be formally addressed before carrying out further studies. Assuming consistency...
3.
Repeat the study for all the operators or levels carrying out steps 1 and 2.
At this point you should have demonstrable measurement consistency for all your operators/levels, this is a major achievement on its own but we can then go on if necessary
4. Check for equivalence of measurement error and bias, either between the operators/levels or to a known standard as applicable
5. Select any of the operators and measure the 21 parts, plot the values in time series order on an individual moving range chart. Extract the part variation from this chart and compare with the measurement error plus any detectible bias (if its detectible)) to compute the Intraclass Correlation.
Following all this you can demonstrate to your customer:
-The measurement process is consistent across all the operators/levels
-The measurement error is equivalent (if not I have documented it and understood the possible impact)
-The bias is equivalent (if not I have documented it and understood the possible impact)
-The measurement process is capable, or not as the case may be, of picking up and tracking variation in my manufacturing process
At this point you are then in a strong position to compare against your customer measurements and ask questions. Perhaps your customer would not then feel the need to check your measurements, a time saving for you both.?
I hope this helps.For more detail on equivalence please look at Don Wheeler's 3 recent articles published on Quality Digest.
Cheers
Mike S.
Happy to be Alive
you can simply plot the data on a youden plot and calculate the intraclass correlation coefficient. a standard correlation is not appropriate.
you can check out the two attachments for background.
You did a LOT of work creating all this. I'd like to sit in on one of your presentations but I may leave with a headache. "Fake math" - love the term, BTW. (y)
Emmyd
You and your customer are using the same measurement method?
That would be my question as well. We've done this exercise with our customers before only to find they were using a different method of measurement/datuming/clamping than what was approved on the gauging. We had to make sure the measurement methods are exactly the same or you can't correlate anything.
I usually present at the ASQ Lean Six Sigma conference in Phoenix and I might be presenting at the ASQ world conference in Columbus next year. My presentations are typically fairly 'rich' in content and I do tend to challenge popular 'thinking' ;)
N Master Samples - What should we be keeping? IATF 16949 - Automotive Quality Systems Standard 9
G Supplier delivered recent PPAP, should he deliver yearly layout inspection? IATF 16949 - Automotive Quality Systems Standard 4
John Broomfield Vote - Should ISO9004 Become a Requirements Standard? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
J Should Loading and Unloading be Included in Cycle Times? Lean in Manufacturing and Service Industries 14
E Manufacturers should develop a testing device for covid19 Service Industry Specific Topics 0
T 510(k) submission - Which name should I use in the submission? Other US Medical Device Regulations 3
N ISO 19011:2018 - 5.4.2 "...audit program should engage in appropriate continual development..." Training - Internal, External, Online and Distance Learning 4
M Should 510(k) Predicates be Actively Listed Devices? Other US Medical Device Regulations 12
H Who should be listed as the manufacturer/distributor on the box? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 15
M MDR, RED and LVD - Should our device comply with them? EU Medical Device Regulations 3
BeaBea How Many Processes should be created for each Department? Process Maps, Process Mapping and Turtle Diagrams 5
M Should volume of sales be factored into risk probability assessments? ISO 14971 - Medical Device Risk Management 33
S Should safety checks be included in the Control Plan? IATF 16949 - Automotive Quality Systems Standard 5
M Which incubation condition should be selected to recover both bacteria and fungus effectively Miscellaneous Environmental Standards and EMS Related Discussions 3
D Is there a specific location for PPE such as safety glass holders and glove dispensers should be mounted Occupational Health & Safety Management Standards 10
M Who should receive the bills from suppliers and vendors, account payable or procurement? Consultants and Consulting 4
A We are ISO 13485:2016 should we be audited to ISO 14971 ISO 13485:2016 - Medical Device Quality Management Systems 16
E Received a Major finding during IATF Surveillance audit for loss of BIQS Level 3 (more than 6 SPPS in 6 months)...how should we address SYSTEMIC CA? IATF 16949 - Automotive Quality Systems Standard 11
J Organization merger. Should we keep two separate ISO 13485 certificates? ISO 13485:2016 - Medical Device Quality Management Systems 6
S Companies that maintain your machine should be in ASL? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
S Use of "Shall" versus "Should" in Procedures ISO 13485:2016 - Medical Device Quality Management Systems 26
D Class II medical device - When should a complaint be closed? Customer Complaints 6
Sidney Vianna IATF 16949 News Presentations from the latest IATF Stakeholder Event - Expectation that IATF 16949 certification should equate with product quality. Misguided? IATF 16949 - Automotive Quality Systems Standard 7
Ed Panek Part 11 Self Certify Memo - What else should it cover? Qualification and Validation (including 21 CFR Part 11) 5
H Should I mention machine/Equipment password In SOP? Qualification and Validation (including 21 CFR Part 11) 4
D How long should we keep the spare parts available for our medical device, after we have stopped the production? ISO 13485:2016 - Medical Device Quality Management Systems 0
H Statistical Techniques Procedure - What should be included Document Control Systems, Procedures, Forms and Templates 4
Sidney Vianna Interesting Discussion ISO 9001:2024 - What should be changed in the next Edition of ISO 9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 105
N Should it even be on the hazard analysis (software)? FMEA and Control Plans 2
V Which batches should or could be considered for design validation and design verification? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
L A Taiwan company want to sell Class I medical device (510(k) exempt) on Amazon, should we register with FDA? US Food and Drug Administration (FDA) 4
M Routine testing of medical electrical systems - What specific electrical safety tests should be performed? IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
G ISO 17025:2017 7.1.2 - Should I produce a document for the customer? ISO 17025 related Discussions 8
F Quality Objectives - Where in the QMS Quality Objectives should be located ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
P ISO 80369-7 standard - Interpreting which Parts should be in scope Other Medical Device Related Standards 7
V Who should define and own the Design and Development Plan and how to maintain the updates and revisions. ISO 13485:2016 - Medical Device Quality Management Systems 2
A How should the Medical Device OEMs be declared to ANVISA? Other Medical Device Regulations World-Wide 0
D Should "Waste" be included as Output in SIPOC Chart? Process Maps, Process Mapping and Turtle Diagrams 8
N Control plan evaluation methods - Which methods should be carried over from the PFMEA? FMEA and Control Plans 3
A PFMEA - How long should the recommended actions remain in the recommended actions column? APQP and PPAP 3
M Should Quality be an independent organization in aerospace company? Quality Manager and Management Related Issues 25
