How should I Keep my various types of records ..
Q
QAMTY
Hi all
How should I Keep my records
For example a NCR, CAR is composed
of a form sent by the someone, in such form
should exist a signature, in the same way
the responsible writes down the solution add the signature
and so on..
My idea is the form to be sent by email, and when
not available, the people should scan the form and send it by fax.
So my system is a mix manual and electronic, The question is
How the responsible should keep the records?
-In case of emails (Print them out) and have a printout as record
or can I keep them in Outlook?
- In case of drawings and calculations, can I keep them for the purpose
of records a physical copy with me, because the original ones
are kept in the Engineering area?
- In case of agreements made by phone, how this is put in
records?
How do you handle this?
Thanks for your time
in giving me feedback
I really appreciate too much your help.
As long as the records are identified, stored in a way they remain protected, and are readily retrievable, when required, you are fine.
It can be a happy mix of manual and electronics.
Outlook .. ? is it identified and stored in a way it remains protected ? For a week, month, year, 3 years or more as you determine ? Can the owner of the record readly retrive it when necessary ? If YES for all of them its OK. (Tomorrow, if the system crashes, do you have a method to go and fetch the backup and make records available again)
Can the drawings and calculations be where you have said, and can you say this in the procedure for records control ? The originals are the record. A copy is a waste of time ...
If agreements are your determined records, then make them valid with due signatures and date and store them in any form, paper or soft, again taking care that they are identified, stored in a way they remain protected, and are readily retrievable, when required.
samsung
- In case of agreements made by phone, how this is put in records?
If agreements are done on telephone, it's probably your organization doesn't require them to be recorded else why would they be done this way. However, if you still need to record the 'agreement', you can just write down the things on a piece of paper (or a from) and record them.
J Organization merger. Should we keep two separate ISO 13485 certificates? ISO 13485:2016 - Medical Device Quality Management Systems 6
D How long should we keep the spare parts available for our medical device, after we have stopped the production? ISO 13485:2016 - Medical Device Quality Management Systems 0
T How much information should I keep in my Master Document Register? Document Control Systems, Procedures, Forms and Templates 8
Q How many records should I keep when implementing Corrective Actions Records and Data - Quality, Legal and Other Evidence 3
K Gage R&R Records - Should we keep data longer as 'suggested' by our TS Auditor? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
Q Conference Call with Supplier - What points/issues should we keep in mind? Supplier Quality Assurance and other Supplier Issues 4
CarolX Deleted (Obsoleted) Procedures - How do I track? Should I keep a copy? Document Control Systems, Procedures, Forms and Templates 7
D Life of the part - How long should I keep processing data, powder, raw material tests Document Control Systems, Procedures, Forms and Templates 3
I IEC 60812 or ISO 14971 for PFMEA? What should we use? ISO 14971 - Medical Device Risk Management 3
qualprod Do sum of results of quality objectives should met a high level goal? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
F Should I perform several Gage R&R for every caliper to cover all specs range of use? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
E Opening meeting for Third-Party Audit--Who should say what? General Auditing Discussions 22
8 MSA--Should I Use Parts or Gage Pins? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
B Should I buy IEC 62304:2006, IEC 62304:2006/AMD 1:2015 or both? EU Medical Device Regulations 1
W "Accurate to ±2%" means "64% of measurements should be within 2% of the actual value"? US Medical Device Regulations 4
H Should we stop inspecting a part if its never been rejected? Reliability Analysis - Predictions, Testing and Standards 6
D What distributor requirement should we (manufacturer) require from the Distributor? EU Medical Device Regulations 0
M Should there be another column in the Optimization section (step 6) of AIAG-VDA DFMEA form? FMEA and Control Plans 1
C By when should harmonized standards be complied with? EU Medical Device Regulations 5
W Strategy for determining which components from a system should be "ME EQUIPMENT" -- home healthcare environment IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
B Documented information - Should be controlled? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
Q Is engineering a process and should it have its own process turtle? IATF 16949 - Automotive Quality Systems Standard 7
P Which MDCG Document should I use for PMS Plan and PSUR? EU Medical Device Regulations 2
M Who should quality representative report to? ISO 13485:2016 - Medical Device Quality Management Systems 5
H When should the first PSUR be issued? EU Medical Device Regulations 5
I If i do not want to be an initial importer should i register with FDA? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
O Should a Covid vaccine and testing policy be included as part of ISO9001 or AS9100 risk management? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
B UKRP to what level should you audit Class I Technical Documentation? UK Medical Device Regulations 0
C When should you quit programming? Job Openings, Consulting and Employment Opportunities 9
C Should resolution be included in uncertainty budget for digital caliper or micrometer calibration? Measurement Uncertainty (MU) 5
Ed Panek External Standards List - Should this document include previously revised standards? ISO 13485:2016 - Medical Device Quality Management Systems 4
T How should I approach REACH, CM, etc. as a job shop? RoHS, REACH, ELV, IMDS and Restricted Substances 18
A Should we assign the PRRC before the date of application of MDR (26 May 2021)? EU Medical Device Regulations 0
J UDI-DI how should we interpret Device version or model to determine if a new UDI-DI is needed? EU Medical Device Regulations 0
Sidney Vianna Interesting Discussion Should ISO 9004 be changed from a guidance document to a requirements standard? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
S Which Sampling Plan(s) Should I Use? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 13
N Master Samples - What should we be keeping? IATF 16949 - Automotive Quality Systems Standard 9
G Supplier delivered recent PPAP, should he deliver yearly layout inspection? IATF 16949 - Automotive Quality Systems Standard 7
John Broomfield Should ISO 9004 Become a Requirements Standard? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 70
J Should Loading and Unloading be Included in Cycle Times? Lean in Manufacturing and Service Industries 14
E Manufacturers should develop a testing device for covid19 Service Industry Specific Topics 0
