How to apply a Tolerance to a Bend Radius
#11
Lot's of good info in this thread. Palmer and Kevin Mader covered about everything I could have thought of.
Basically if the drawing uses a "title block" tolerancing and not GDT, go with the Title block. If GDT is indicated go with that.
I always took the position that they can't reject a part that is made using their tolerancing. ;):D:rolleyes:
Although, that being said, we DID have a customer occasionaly reject a part that was in print by their title block but when they ahd made it they "knew better" and applied a tighter tolerance to some feature. You know - The old issue of old drawings never being updated, cause the guys on the floor knew what was needed. Then when the part was farmed out to us, all we had to go by was the drawing.
Anyway - Long story short. If you stick with the best toleancing available - that which is documented on their drawing - you can hardly go wrong.
Peace
James
bobdoering
Stop X-bar/R Madness!!
#12
Basically if the drawing uses a "title block" tolerancing...go with the Title block.
Just a word of caution: Be careful about title blocks. Sure, it is the default print requirement, but sometimes you will have title blocks developed for machining (for example), and applying it to bending or welding may not be applicable (but nobody verified that there might be a problem!) That is why it is good to go through a print with a fine tooth comb before quoting and starting a job!
#13
Of course by the time I got to looking at these things it was usually after the darn thing was already quoted and started and one of tow questions come up. "We don't have that radius can I use this one?" or it is already made and tehy want to know "if it will work".
In other words flying by the seat of their britches.....
Peace
James
Kevin Mader
One of THE Original Covers!
#14
ScottS,
My fellow Covers helped pick me up! Triggered another thought, although I think that you were looking to make the radius larger. Especially with the aerospace industry, radii have expanded importance. If you stretch the metal or coin it, you could bring dimensions into print, but ruin the material properties. I recall our trying to reduce a radius for a part made out of aluminum but ended up cracking the material on the bends. We had to grow the radius beyond the drawing dimensions to avoid this condition, which for this part would not have led to a catastrophic failure of a key component, but it could have for another.
Using a toleranced profile is not a bad suggestion. If you are lucky enough to have good back lighting or face lighting that allows you to catch the profile, an overlay on a comparator or toolscope might be a good way to verify your radii. In the end, its really about the tooling in your toolbox drawers. What can you achieve without investing in a new tool? As I noted earlier, it's best to work these details out up front. It may not matter, it may be cosmetic, or it could mean whether you get paid for the part or not. Engineers tend to put down ideal dimensions for features (ideal to them) without thinking about the cost it might bring (e.g. tightly toleranced vs. Form, Fit, and Function practical). They're human after all, and capable of oversight.
Regards,
Kevin
P
palmer
#15
Kevin brought up a thought from me as well about material damage.
In some cases, we heated the material to prevent cracking or tearing.
In other cases we formed radii in steps to keep the material consistent. In this case, the steps didn't require the material to form all at once which let it relax before being stretched again.
In both cases there was a lot of trial and error before we acheived consistency.
Hot rolled and cold rolled metal are one thing, SST and alum are a whole nother animal when it comes to bending. We had #3 grain in our SST and had to maintain it throughout the process which required bending and welding. It had to look like there never was a weld.....:truce:
We also would form 2 1/2 radii and weld them together to place the weld in the corner to prevent warping across the flat part. Finishing the weld (making it look like no weld at all) seemed to be easier as well as putting the grain back in the material (It was SST)
For not being an engineer I sure have performed miracles with some metal.... LMAO
P
palmer
#16
To all that care to help,
We have a forming (bend) radius of .35" on our print but we only have a .375" punch for our pressbrake. The title block gives us a generic tolerance of .030" + or - for all two place decimal deminsions. There is no special note on the print covering radius deminsions. Our question is, does the title block deminsion cover the radius deminisons or is there a special rule that covers radius deminsions? Thank you kindly in advance. Scott and Robert
Scott and Robert,
Ask the engineer also. Or the company that you are making this for. .35" radius is a strange dimension for a radius but it may be mating up to something that has that radius.
The engineer may not have knowledge of bending and used a formula to place a dimension for it. The material thickness plays a part in this.
We were always fighting with engineering about wanting a 1/16" radius in 10 ga. material. To do that you were putting an indentation where it was formed and tearing the material on the outer radius......
E Discussion between co-worker on tolerance and uncertainty and how to apply it. Thoughts? 17025 ISO 17025 related Discussions 1
L When and how to apply Bonus Tolerance MMC - Hole Dimension Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
E Full Scale Tolerance - How to apply full-scale accuracy specification to a gage? General Measurement Device and Calibration Topics 4
S MDR - System and procedure pack article 22 and all sub processes that apply ISO 13485:2016 - Medical Device Quality Management Systems 0
shimonv Worthwhileness for a small startups to apply for EUA (Emergency Use Authorization) for COVID-19 US Food and Drug Administration (FDA) 17
qualprod Records where apply and stop recording everything? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
B Operator protection - When to apply table 7, Dielectric strength test voltage IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
B How to apply external voltage to SIP/SOP IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
G Do HIPAA Rules Apply to a 3rd Party Logistics Shipper? Other US Medical Device Regulations 2
D Do purchasing controls apply to non-medical parts? ISO 13485:2016 - Medical Device Quality Management Systems 5
D Monitoring and measuring resources - Example of how section ISO 9001 7.1.5 would apply to a manufacture of software ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
C Does ITAR apply to Exporters only? Other ISO and International Standards and European Regulations 6
E Does CQI-23 (Molding Sys. Asses.) apply to RUBBER molding? IATF 16949 - Automotive Quality Systems Standard 2
M Informational From RAPS – UK NB Will Not Apply for EU MDR/IVDR Medical Device and FDA Regulations and Standards News 11
B Does EMC Directive 2014/30/EU cease to apply when the Machine Directive 2006/42/EC is applicable? CE Marking (Conformité Européene) / CB Scheme 4
B How to assess which directives and standards apply - Brewing and distilling products CE Marking (Conformité Européene) / CB Scheme 1
N Student trying to apply Lean Six Sigma on a Construction project in my thesis Lean in Manufacturing and Service Industries 3
F Device Standards - Managing Changes to existing standards that apply to our devices Other Medical Device Related Standards 1
A ISO 9001:2015 - How to apply 7.1.5 to an organization performing only design ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
F What directives/regulations apply to Analyte Specific Reagents (ASRs) in EU EU Medical Device Regulations 0
F Can an individual apply for an MDEL in Canada, as an establishment? Canada Medical Device Regulations 6
N Apply control limits to a non-normal distribution Statistical Analysis Tools, Techniques and SPC 13
M IATF Clause 8.4.2.2 - What procedures does this apply to? IATF 16949 - Automotive Quality Systems Standard 1
S Optical coherence tomography (OCT) device - Do we need to apply IDE? Other US Medical Device Regulations 0
R Communication of CSR's throughout the organization and who they apply to IATF 16949 - Automotive Quality Systems Standard 4
M Apply for a job when no opening is posted? Career and Occupation Discussions 64
M AS9100 D - How to apply 8.1.1-8.1.4 to a coating service AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
M Does ISO 10993 Apply to Packaging? (e.g. Travel Case) Other Medical Device Related Standards 4
C Optic Patchcord Cables - Does 8.3 (Design) Apply Here? ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
M Does the Scope of 21 CFR Part 820.72 (Equipment) apply to Design? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
D Does IATF 16949:2016 Clause 7.3 (now 8.3) Apply to "Grandfathered" Products IATF 16949 - Automotive Quality Systems Standard 4
Moncia Tall Manufacturer - VDA Audit - Which parts of the audit apply to us? IATF 16949 - Automotive Quality Systems Standard 4
Q How to apply 21 CFR Part 11 and/or cGMP in the Life Sciences industry Qualification and Validation (including 21 CFR Part 11) 3
V When and How to apply the Bayes Success Run approach for Sample Size Determination Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
A 3 scenarios of accident and I want to apply OHSAS18001 Occupational Health & Safety Management Standards 2
I ISO 26262 standard may apply to automotive IC suppliers IATF 16949 - Automotive Quality Systems Standard 1
GStough Looking to Apply for IRCA Certification Using 2nd Party Audits Career and Occupation Discussions 2
M Does AS9120 (aerospace first article inspection) apply to all customers AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
J If/how to apply LVD (Low Voltage Directive) in this case CE Marking (Conformité Européene) / CB Scheme 6
A How soon can I apply for ISO 9001:2015 certification? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
J Who needs to apply for a CLIA waiver 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
D Does Record Control apply to the company business processes as well? Records and Data - Quality, Legal and Other Evidence 6
P When can we apply DOE (Design of Experiments)? Six Sigma 8
L AS9100 7.5.2 Special Processes - Clean Room Apply? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
M Not sure what standards apply to non-electrical patient bed EU Medical Device Regulations 6
A Shall I apply for this job position (Quality Manager)? Career and Occupation Discussions 5
V Can we apply bracketing & matrixing simultaneously for stability studies @ ICH Q1D US Food and Drug Administration (FDA) 1
N Which regulations apply to Medical Stand Alone Software in Europe? ISO 13485:2016 - Medical Device Quality Management Systems 3
