How to apply Incoming (Receiving) Inspection to Customer Supplied Material?
N
nkson
Hello everybody,
Our company starts of TS16949, and I encounter some problem during making Work instruction for Incoming Inspection. Let me explain in detail:
- Our company makes automotive part, and only have 1 customer. This customer supplies all material to us, we just assemble, final inspection and send F.G back to them.
- The material takes about 4 weeks to go from customer to our plant.
- The Acceptance Level of automotive is Zero defect. But if we find defect parts during Incoming Inspection, we can't reject whole lot because if we do that, we don't have any material for production and plant shutdown. We also don't have enough person to verify 100% of lot.
- Currently, we don't apply Incoming Inspection but instruct operators during operation to find and segregate defect parts, and inform back to customer to get replacement.
TS16949 system requires Incoming Inspection, so what and how can I do to control the incoming quality in this situation?
Thanks for reading,
Nguyen Kim Son
qusys
Re: How to apply Incoming Inspection with customer supplied material?
Is there an agreement in place with your Customer regarding with the incoming material which it itself provides to you?
I see the application of 7.5.4 Customer property, because I am assuming that the the material is not purchased, but directly provided by your unique Customer.
I think you are conform to the standard, based upon the procedure you have set, to segragate defective material and then inform customer for replace.
You should also speak with Customer if they want to change procedure, but in this case you should increase resource. In this case this could carry to re-negoziation of the price of the provided service.
Hope this helps. Waiting for other feedback of other Covers. What about it?
qusys
I would like to also add to my previous post that you can also refer to acceptance criteria clause too ( 7.1.2), where sample plan for attibutes must be zero defects.
Criteria shall be established by the organization and , when requested, approved by the Customer. In this terms, I did reference to the agreement in place.
Hello everybody,
Thanks for reading,
Nguyen Kim Son
somashekar
Hello everybody,
Thanks for reading,
Nguyen Kim Son
When you say that you instruct your operator to find and segregate defect parts, you are applying the incoming inspection. If your instructions to find and segregate parts are documented in a systamatic way for the operator to follow, you have made your work instruction for incoming inspection.
qusys
Hi Somashekar ,
I agree with you about what you have said.
My previous posts went to that sense.
To add something, these work instruction could be also inserted in the related control plan, that could encompass processes from incoming to shipping.
:bigwave:
KIDDO
What do you have recorded in the applicable FMEA?
We also have customer supplied material (castings) and our Shipper/Receiver completes a visual inspection for damage, rust, dunnage damage, part number and quantity (matches packing slip). We also have a reference guide with pictures showing what acceptable raw parts should look like for the Shipper/Receiver. The operators also have pictoral type instructions (quality alerts, operator instructions, inspection sheets with casting numbers)It works well for us.
KIDDO
qusys
It is a good point too.
However, based upon what the initial post reports, I think he makes reference to the single items of an unique pallet.
The castings could arrive packed in single big boxes in the receiving dock, where the receiver can make an overal control on the integrity ( either visible on the box or on the enclosed shipping documents), but only when the material reaches the production line, the operators/technican staff can see the eventual defective piece, but they cannot reject the entire lots cointaining all pieces, even though they are ok for assembly.
This was my understanding...:bigwave:
KIDDO
N
nkson
Thank you for all replying.
We don't have any agreement with Customer of Incoming inspection.
I also thought about applying 7.5.4 "Customer Property".
But at this time I was not sure of conformation with TS requirement 7.4.3.1 "Incoming Product Quality" if we don't have an individual Incoming inspection procedure in-place.
Currently, we only have procedure of Control NC Product mentioned about disposition of NC material, but not yet have any documented work instruction to show operators and QC how to verify suspect material (only verbal). If I make it, so no need any more Incoming Inspection procedure?
harry
I am not sure what kind of materials are you referring to. In the case of bulk materials (drums of cables or rolls/bales of fabric - as examples) you can't do much during incoming stage.
N
nkson
Our material is cut parts cloth, leather (for seat trim cover), about 40,000 parts per lot.
M Does 4.5 - Alternative RISK CONTROL apply to the Particular Standards? IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
D Does Risk Management apply to re-labeler (MDR) EU Medical Device Regulations 1
Ed Panek Does this FDA Requirement Apply to international (not USA) distributors for USA based manufacturing companies? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
J In-house (NHS) manufacture and use (by staff) of non-medical devices.. any regulations apply? UK Medical Device Regulations 6
S MDR - System and procedure pack article 22 and all sub processes that apply ISO 13485:2016 - Medical Device Quality Management Systems 0
shimonv Worthwhileness for a small startups to apply for EUA (Emergency Use Authorization) for COVID-19 US Food and Drug Administration (FDA) 17
qualprod Records where apply and stop recording everything? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
B Operator protection - When to apply table 7, Dielectric strength test voltage IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
B How to apply external voltage to SIP/SOP IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
G Do HIPAA Rules Apply to a 3rd Party Logistics Shipper? Other US Medical Device Regulations 2
D Do purchasing controls apply to non-medical parts? ISO 13485:2016 - Medical Device Quality Management Systems 5
D Monitoring and measuring resources - Example of how section ISO 9001 7.1.5 would apply to a manufacture of software ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
C Does ITAR apply to Exporters only? Other ISO and International Standards and European Regulations 6
E Does CQI-23 (Molding Sys. Asses.) apply to RUBBER molding? IATF 16949 - Automotive Quality Systems Standard 2
M Informational From RAPS – UK NB Will Not Apply for EU MDR/IVDR Medical Device and FDA Regulations and Standards News 11
B Does EMC Directive 2014/30/EU cease to apply when the Machine Directive 2006/42/EC is applicable? CE Marking (Conformité Européene) / CB Scheme 4
E Discussion between co-worker on tolerance and uncertainty and how to apply it. Thoughts? 17025 ISO 17025 related Discussions 1
B How to assess which directives and standards apply - Brewing and distilling products CE Marking (Conformité Européene) / CB Scheme 1
N Student trying to apply Lean Six Sigma on a Construction project in my thesis Lean in Manufacturing and Service Industries 3
F Device Standards - Managing Changes to existing standards that apply to our devices Other Medical Device Related Standards 1
armani ISO 9001:2015 - How to apply 7.1.5 to an organization performing only design ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
F What directives/regulations apply to Analyte Specific Reagents (ASRs) in EU EU Medical Device Regulations 0
F Can an individual apply for an MDEL in Canada, as an establishment? Canada Medical Device Regulations 6
N Apply control limits to a non-normal distribution Statistical Analysis Tools, Techniques and SPC 13
M IATF Clause 8.4.2.2 - What procedures does this apply to? IATF 16949 - Automotive Quality Systems Standard 1
S Optical coherence tomography (OCT) device - Do we need to apply IDE? Other US Medical Device Regulations 0
R Communication of CSR's throughout the organization and who they apply to IATF 16949 - Automotive Quality Systems Standard 4
M Apply for a job when no opening is posted? Career and Occupation Discussions 64
M AS9100 D - How to apply 8.1.1-8.1.4 to a coating service AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
M Does ISO 10993 Apply to Packaging? (e.g. Travel Case) Other Medical Device Related Standards 4
C Optic Patchcord Cables - Does 8.3 (Design) Apply Here? ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
M Does the Scope of 21 CFR Part 820.72 (Equipment) apply to Design? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
D Does IATF 16949:2016 Clause 7.3 (now 8.3) Apply to "Grandfathered" Products IATF 16949 - Automotive Quality Systems Standard 4
Moncia Tall Manufacturer - VDA Audit - Which parts of the audit apply to us? IATF 16949 - Automotive Quality Systems Standard 4
Q How to apply 21 CFR Part 11 and/or cGMP in the Life Sciences industry Qualification and Validation (including 21 CFR Part 11) 3
V When and How to apply the Bayes Success Run approach for Sample Size Determination Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
A 3 scenarios of accident and I want to apply OHSAS18001 Occupational Health & Safety Management Standards 2
I ISO 26262 standard may apply to automotive IC suppliers IATF 16949 - Automotive Quality Systems Standard 1
GStough Looking to Apply for IRCA Certification Using 2nd Party Audits Career and Occupation Discussions 2
M Does AS9120 (aerospace first article inspection) apply to all customers AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
J If/how to apply LVD (Low Voltage Directive) in this case CE Marking (Conformité Européene) / CB Scheme 6
A How soon can I apply for ISO 9001:2015 certification? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
J Who needs to apply for a CLIA waiver 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
D Does Record Control apply to the company business processes as well? Records and Data - Quality, Legal and Other Evidence 6
P When can we apply DOE (Design of Experiments)? Six Sigma 8
L AS9100 7.5.2 Special Processes - Clean Room Apply? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
M Not sure what standards apply to non-electrical patient bed EU Medical Device Regulations 6
A Shall I apply for this job position (Quality Manager)? Career and Occupation Discussions 5
