How to ask probing questions during Audits..?
Jen Kirley
Quality and Auditing Expert
#22
our company systems....they demand we use a standard checklist to conduct the audit while we are auditing our suppliers.
I'm going to make a guess that the intent here was to help make sure all the desired ground gets covered when doing a supplier audit.
That's the rosy explanation. The darker option is that the expectation was to have auditors without sufficient skills to do a good job without these checklists.
Such can be the case in management systems that have not been operating long enough to mature into functional, people centric organizations with the needed skills and desire to perform without being told to breathe in and out.
The checklists are good as reminders to look for this, that and the other thing. However, using them as scripts tends to invite a superficial, low value approach to a supplier audit. You might as well just send them the checklist as a survey!
Why not use the checklist as a survey, but also visit to look at concerns your organization has with the supplier and inquire about the processes involved? In this way you can directly communicate your needs and perhaps offer suggestions or options to help get your needs met. For example, "Have you tried XYZ Transport? We have found they are very prompt and affordable, and our goods haven't been damaged when they do the shipping."
:2cents:
The_TBCD
#23
Thanks jane......if found them ,myself...yesterday...Now I have completed the test as well.. :))
thanks anyway..
You may find some useful info here on further "probing questions".
A useful distinction is between closed and open questions. Try Googling for closed questions vs open questions & you should find a lot.
Closed question = one where a single response usually 'closes' the exchange, because it can be answered by just a yes/no or a fact. eg:
  • Are you British?
  • Are you an employee or contractor?
  • Does company policy permit smoking in office buildings?
Open (or open-ended) questions = ones that open up an exchange, invite further information. Good auditors use a lot of open-ended questions! eg:
  • Could you tell me more about how that works?
  • What is the usual practice when that occurs?
  • How does that help achieve the outcome?
Note that both are required, eg, there are times when you want to ask closed questions (Is your correct address 1234 High St?) and other times when open-ended questions are needed.
Nervous interviewers/inexperienced auditors often ask too many closed questions, and not enough open ones.
ralphsulser
#24
Questions such as:
What do you do if you find out of spec. dimensions or parts?
What happens if you drop a gage?
How have you been trained to do this job?
How and where is your training documented?
What do you do in your job to satisfy the customer?
These are helpful to determine the training competency and compliance with the requirements of the system and customer specifics.
Bob Bonville
#25
Checklists are not locked in concrete. They can and should change based the documents from which the requirements originate and the audit history. It is like anything else, If you never have a finding associated with a particular audit question, then consider eliminating it, changing it or doing something like a skip sample using the particular question.
All kinds of approaches.
Bob
#27
In your world, Bob, maybe. But as a consultant for many years I've seen the use of those 'concrete' checklists - by many people!
I think checklists are a bad thing if they're used for anything other than as mnemonic devices--something to help you remember what you're trying to accomplish. Outside of that, I think that most checklists should be "locked in concrete," or somewhere else where no one can get to them.
Bob Bonville
#28
Jim, I get your point. For all the good they do some auditors, they should perhaps be put in a time capsule.
Bob
L
little__cee
#29
One more thing: I always make sure that I ask a question such as "what do you need to help you do your job better?" or "what would make your work easier?" -- something with that intent - before I finish auditing an area.
Some of the replied can't be printed here, others (usually) have to do with alcohol - beer, specifically, but once in a while I get a really great idea out of someone that wouldn't have been covered had I not asked the question.
One person replied "a printer that works" - turns out this individual had the world's oldest printer which frequently malfunctioned - new printer arrived and the person's workload became much easier.
#30
Audits shouldn't be used as a substitute for poor supervision! In this case, what was the person's supervisor doing? If they weren't aware of the inefficiencies caused by an old printer, then that's pretty poor management.
Sure, several kudos points for the auditor, but that's all!
R [ASK] API Q1 Ninth Edition, Section 5.4.5 Oil and Gas Industry Standards and Regulations 4
G Same parts but new customer - What will the auditor ask me? IATF 16949 - Automotive Quality Systems Standard 2
I Questions to ask when auditing for Organizational Leadership and Planning for the QMS? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
A EC declaration of conformity - In the event clients ask for a copy CE Marking (Conformité Européene) / CB Scheme 12
Ed Panek Website to ask FDA for guidance in Medical Device Industry? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
G Auditor watching tech do procedure - Can tech ask questions? ISO 17025 related Discussions 6
O Reinstating a disqualified supplier—questions to ask before making a decision Supplier Quality Assurance and other Supplier Issues 2
Q New Casting Supplier System Assessment - What technical questions to ask? Supplier Quality Assurance and other Supplier Issues 3
E Ask for supplier control procedure which conforms to IATF16949 IATF 16949 - Automotive Quality Systems Standard 0
S What questions to ask in annual supplier evaluation? ISO 13485:2016 - Medical Device Quality Management Systems 3
Marc Some Questions an Auditor may Ask General Auditing Discussions 0
A Is normal for FORD EU ask for the PSW every year APQP and PPAP 5
L Auditing Top Management - Meeting Competency Requirements and Questions to Ask General Auditing Discussions 11
M Supplier Nonconformances - Key Points to ask a Metal Stamping Supplier Supplier Quality Assurance and other Supplier Issues 7
G New to Internal Auditing - Best questions to ask? Internal Auditing 17
M Is SPC required for Production if a Customer does not ask for it? IATF 16949 - Automotive Quality Systems Standard 13
K Almost embarrassed to ask... SPC UCL/Data Range Quality Tools, Improvement and Analysis 4
T Who should provide information I ask for? Internal Audit question Internal Auditing 4
R What questions should I ask during Internal Audits? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
Sidney Vianna IAQG AS9100C Auditor Guidance Material - What to look for ? What to ask AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
E What kind of questions will you ask on a quality quiz? Misc. Quality Assurance and Business Systems Related Topics 8
K Are these questions approriate to ask in an interview? Career and Occupation Discussions 11
E Interview Questions to ask a Job Applicant on a Second Interview Career and Occupation Discussions 1
L Top Management - Internal Audit Questions to Ask Internal Auditing 17
sagai Why never to ask favours from the designers Funny Stuff - Jokes and Humour 8
ScottK Just Changed Jobs - Ask me anything Career and Occupation Discussions 29
A Questions that auditor may ask during the certification or 2nd stage audit. ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
A Final ISO 9001 Audit - What questions will they ask - Help and advice needed General Auditing Discussions 11
L Questions to ask a New Registrar TS 16949 Auditor Registrars and Notified Bodies 7
A Toyota may ask for $2 billion in loans World News 0
W U.S. Auto Suppliers Ask Treasury for $25.5 Billion Bailout World News 0
T What would the FDA expect to see when they ask for our QSR? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 20
BradM Sometimes you just ask - Why, Why, Why? Funny Stuff - Jokes and Humour 13
P Quality Supervisor Interview - Questions to Ask Career and Occupation Discussions 2
E [Ask] Original Equipment Manufacturing/Manufacturer Misc. Quality Assurance and Business Systems Related Topics 1
K TS 16949 Calibration System Audit - What questions will they ask me? General Measurement Device and Calibration Topics 11
P Internal PPAP Audit - What should I ask? Plastic parts (automotive) TS 16949 IATF 16949 - Automotive Quality Systems Standard 7
B Tips on Technical Things the Auditors might ask during an Audit General Auditing Discussions 15
A Does auditor have conflict of interest? Should we ask for different auditor? Registrars and Notified Bodies 12
S How to ask Leave from your Boss !! Funny Stuff - Jokes and Humour 2
ScottK Remember Auditors - It's all in how you ask the question! Coffee Break and Water Cooler Discussions 1
ScottK Do people ask for raises anymore? Career and Occupation Discussions 5
S Trainees backing out when it comes to delivery - fair to ask for commitment letter? Training - Internal, External, Online and Distance Learning 38
SteelMaiden Watch what you ask for at breakfast Funny Stuff - Jokes and Humour 3
L Audit Logs - What do you do when registrars ask for them? General Auditing Discussions 10
Jim Wynne An awful lot of money for a doorstop, if you ask me Coffee Break and Water Cooler Discussions 20
A Internal Quality Audit - Can I follow the Auditors and Ask Questions? Internal Auditing 11
A Does your Registrar ask folks "Who's the Management Representative"? General Auditing Discussions 58
W Health Care Business QA - What Q's to ask? Service Industry Specific Topics 1
B How can I ask a customer not to issue CARs for trivial issues? Nonconformance and Corrective Action 17
