How to audit a department without a written procedure?
L
Libnani
I am facing frequently during the ISO 9001 external audit i perform departments working without written procedure ((for example the estimation department in contracting company). I have a difficulty to establish conformity or not . could you please advise how to proceed in this case ?
Coury Ferguson
Moderator here to help
Re: How to audit a department without a written procedure ?
My opinion is to Audit the process.
Randy
They don't have written procedures or you don't have an audit procedure?
Do you know how to audit?
Are you a trained auditor?
SteelMaiden
Having worked as a design manager in a construction company, I would have to say it would (in my experience) be rare to find a procedure for this...most estimators have some training and experience that qualifies them for this function. (I spent a fair amount of money to get a degree that gave me the basics, the rest was training until the lead estimator felt I was "competent")
Actually, as alluded to already, you need to audit the process. With or without a procedure (which is not required by the standard, btw) Does everyone know what to do? When was the last time there was a "nonconformance" caused because there isn't a written procedure? Are there training records showing education, on-the-job training? Records to show the person(s) have been deemed competent? Are estimators given customer requirements, and using them to work up the estimates? Do estimators know legal and other requirements (codes) to be met? etc. etc.
harry
In some other threads, I had been lamenting about auditors not having knowledge or experience in the construction industry but were assigned to audit construction organizations in my country. I hope the picture is not the same here.
Basically, most estimation departments in contracting companies worked in very similar manners or process. People in the industry will know and there really isn't a need to have a procedure. But I will recommend at least a flow chart to guide those who are new.
However, if you really need to audit them and have no idea of their process, just ask them to describe or outline it for a start and carry out your audit from there.
Colin
In addition to auditing the process, you can also audit against the relevant clauses of ISO 9001.
It's really quite simple........
You plan and prepare based on your knowledge and experience of the process. If you don't know much about the process, you'll need to get some help, possibly some training.
You schedule the audit and you meet with the manager who is the process owner. They describe the process to you, while you make lots of notes and you then confirm your understanding of what you heard. This is important. You also ensure you know what the process objectives and measurements are.
Then, you go and audit the people who are running the process and you ask them similar questions, checking against the notes you have made. You also observe the records of the process, any documentation the people might have and you compare that to what you're being told.
You make notes too, then you have something to comapare each 'story' against. If there's no significant difference, and the process is delivering good performance it's effective. If not you must investigate and decide what's happening.
People have been auditing without recourse to (documented) procedures for years.....
Stijloor
Excellent advice from Andy! :agree1:
In addition, consider that every process is performed with a defined purpose in mind. It may not be documented, but hopefully generally understood by the folks who do that work. Every process has a customer. You may want to talk to the (internal) customer to find out how well their needs and expectation were met. In other words: did the process deliver the goods?
Stijloor.
John Broomfield
Processes and undocumented procedures exist in every successful organization. Competent auditors can audit them for effectiveness.
I look for evidence of control. For example, what are the requirements and are the requirements fulfilled with intent (instead of occasionally by accident). Is the work planned and are they working their plan? Is the work monitored and corrected as the work progresses? Are repeated problems recorded and the root causes removed?
Depending on the objective of your audit (hopefully every one of your audits has an objective), focus on how well the process fulfills the requirements of its customers. For example, in estimating:
1. How do the estimators determine the risks associated with the contracts they are trying to win? The customer here is the site team having sufficient resources (clause 6.1) to safely fulfill the requirements of the contract.
2, How much money do the estimators leave on the table when their company is awarded a contract (difference between the winning bid and next lowest bid price)? The customer here may be the owner of the business who also has return on investment requirements (clause 7.1 may work here but remember; between the estimating and submitting the tender/bid a senior manager usually adjusts the price according to market and other criteria). Your audit should determine those criteria so you can then evaluate the effectiveness of the wider tendering or bidding process.
3. Are the estimates continually improved (clauses 8.1 and 8.5.1) to reflect the actual productivity or costs of labor and materials in the field? If the system is doing its job of increasing efficiency you may see evidence of this in the new rates for labor and materials.
4. Is the company winning the contracts it needs to fulfill its business objectives (this may involve other processes such as marketing so apply the requirements of clause 5.4.2)?
5. Is the estimating team allocating the time needed to fully train the field crews (visit with the QESH manager to determine the time needed to train field crews and complete any testing and inspections as part of your audit planning)?
You do not need to be an expert in the process to come up with good questions. It helps enormously to know how business works and to keep the basic principles in mind (such as process, control, customers, effectiveness, PDCA and the system of preventing nonconformity/ineffectiveness).
Make sure your audits have an written objective and that your audit's conclusion answers the question posed by the audit's objective.
Are documented procedures a crutch for not yet fully competent auditors? :bonk:
Armen Conflict of Interest if I audit the QC department? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
T Internal Audit not done for Quality Department Internal Auditing 11
S ISO 9001 Audit requirement for maintenance department ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
A ISO 27001 function wise or department wise audit questionnaire with control & clauses IEC 27001 - Information Security Management Systems (ISMS) 3
P Is Internal and external audit of Account Department applicable to any ISO standard Internal Auditing 5
M More than canned audit check-sheets? Auditing the Engineering Department Process Audits and Layered Process Audits 5
S Sales Department Internal Audit Internal Auditing 24
M Internal Quality Audit for Maintenance Department ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
E "Internal" CAPA (Audit Nonconformance) Issuance to your own Department Nonconformance and Corrective Action 4
D ISO 9001:2008 Internal Audit ? Strategic Department Internal Auditing 6
C Purchasing Department Internal Audit HELP! Internal Auditing 12
J Best Audit Approach for IT Department with sub-departments ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
A Can I Audit Quality Procedures if I come from the Quality Department Internal Auditing 5
G Internal Audit on IT Department - What to Audit?? Internal Auditing 11
D Internal Audit of Finance Department per ISO 9001:2008? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
A How to Audit the Quality Department (Internal Audit) Internal Auditing 15
L Audit of an Accounting Department - No Documented Procedure for Accounting General Auditing Discussions 19
L Is an internal audit of quality department required? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
S Internal Audit of the Legal Department Process Audits and Layered Process Audits 7
M Does the Head of the Department being audited have the right to amend audit report? General Auditing Discussions 15
J Re-certification Audit with new department in which procedures are not finalized ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
A Relative Humidity + ISO 9001:2000 Audit of Maintenance Department ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 30
G Does ISO 9001 Audit fit in within the Corporate Internal Audit department? Internal Auditing 31
P Decision on NC - Specific department's internal audit ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
J Internal Audit of Tool and Assembly Department - Fastening Tools, Guns and Machines Internal Auditing 1
Q How to Internal Audit a Quality department - ISO 9001:2000 14001:2004 OHSAS18001:1999 Internal Auditing 20
M Audit Finance/Account Department - What/How to audit a Finance/Account Dept? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
C Internal Audit of HR Department... Internal Auditing 2
lanley liao How to understand this words that the planning of internal audit shall take into consideration the results of previous audits? Oil and Gas Industry Standards and Regulations 10
P Audit check for IT company (ISO 9001) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
D Supplier audit Medical Device and FDA Regulations and Standards News 2
M Go Live With New ERP System before Recertification Audit General Auditing Discussions 6
A Add MDSAP to Internal Audit Schedule Medical Device Related Regulations 0
A Define timeline for Major and Miner Audit finding General Auditing Discussions 4
S IATF 16949 Internal Audit Example IATF 16949 - Automotive Quality Systems Standard 7
B Remote IATF 16949 audit preparation General Auditing Discussions 10
M AS9100D Registrar pre-audit requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 15
I Do I need to sign off my annual audit calendar? Internal Auditing 2
M Nice and simple invitation email to an audit kickoff meeting Internal Auditing 1
M IATF 16949 - Audit of Remote Location/Support Site and IT IATF 16949 - Automotive Quality Systems Standard 4
Q IATF audit - Root Cause Analysis results IATF 16949 - Automotive Quality Systems Standard 5
Q Self-assessment audit information Quality Management System (QMS) Manuals 6
Le Chiffre Online training available for ISO/IEC 17021-1: Requirements for bodies providing audit and certification of management systems Training - Internal, External, Online and Distance Learning 3
xfngrs NIOSH Audit for N95 respirators US Food and Drug Administration (FDA) 1
Sidney Vianna IATF 16949 News Risked Based Audit Day Calculation IATF 16949 - Automotive Quality Systems Standard 2
T AS9100 audit due to facility move AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
