How to Balloon Drawings using Excel
basselope
For you Excel gurus, or those who may have seen this issue before. I couldn't find another forum here that seemed more appropriate for this question, and Google has been no help on this question, so here goes.
I have been using a custom Excel workbook to create PPAP documentation for several years. When Ballooning a drawing, I will often (but not always) convert the original drawing file to JPEG, import the image to a work sheet within the PPAP workbook, and then use autoshapes & text boxes to number the characteristics.
For some reason this particular one will print the autoshapes & text boxes, but the JPEG image refuses to render (see attached).
* Everything looks fine in print preview.
* The "print object" box is checked in image properties.
* Moving the worksheet to a separate workbook does nothing to help.
* Converting to PDF (rather than printing) produces the same result.
* 4 different computers have produced the same result.
I have already worked around the issue by using the "pen & ink" method, but you know how we Quality people are... just solving the problem isn't enough - I want to know why it was broke in the first place.
Thanks in advance, everybody.
:thanx:
mguilbert
Re: issue with Balloon drawings using Excel
I do not know the solution to your problem but a site I often use for excel questions is http://www.mrexcel.com/forum/index.php . Others in the Cove may be able to solve this issue but I thought I would give you another avenue to have your problem solved.
PS Be sure to include the version of Excel that you are using.
F
falconer65
I create all of my numbered prints in Excel and this is a common issue. If the image being copied is too large, I get the effect you showed in the attachment.
The trick is to reduce the resolution of what you are copying. An easy way to do this is with Microsoft Paint and it comes with Windows. Open the image with Paint. Open the pull down menu and stretch/skew. This is where a WAG comes in. You want it smaller, but not so much that it is illegible.
Good Luck!
Erik
Darius
it's hard to know if we don't see an example, (not the output but the worksheet).
It could be the worksheet format or a configuration for Excel such as draft printing (I dunno if that exists). Because you tested in a pdf file, the printer is not the problem.
Mr.Happy
If you open or convert your drawing in pdf and than make a snapshot of the drawing you can past it into Excel, this works better than past it as an (jpeg)image.
If pdf Reader gifs a poor result try Brava Reader.
adamsjm
Here is how I handle this type of issue.
You want to place a graphic in Excel.
Graphic "means" PowerPoint, therefore, place your drawing into a PP slide and add your bullet numbers and what else you wish to 'apply' on top of the drawing using the drawing tool bar or by importing other graphics.
When you have completed your 'slide', select all of the objects on the slide, copy them, and then "paste special" as an 'Picture (Enhanced Metafile)' or as a 'Device Independent Bitmap' the image in your Excel worksheet. A Bitmap image will create a better looking image, but is much larger than a Metafile.
If you have very large images to begin with, you may which to segment them into smaller (and more usable) slides / pictures.
Note: This also works in Word, but it is easier to create the 'picture', copy it, and place it into the document via the simple paste function.
(It relate to text wrapping issues.)
Note2: Be sure to include the letter-number border of the print in order to identify where on the print the bullet number is located, i.e., C6.
adamsjm
A jpg image is a 'picture.
Your bullet images are drawing 'objects.'
The result of the two is an 'object' and cannot be treated as a 'picture.'
By rendering the 'object' into a 'picture', it can again be treated as a 'picture.'
adamsjm
You had a problem in the importing of the picture.
The image, 'picture', was on the screen, but ...
By placing 'objects' on the 'picture', the result becomes an 'object.'
The printed 'object' displays the corrupted 'picture.'
By creating a new 'picture' the error can be eliminated.
J Inspection Software to Balloon Drawings and Create First Article Reports Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
M Performance Standard for Balloon Trocars Other Medical Device Related Standards 2
A Doubt on multiple inspection carrying out for same balloon number during Stage Inspection and Final Inspection? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
Marc A NASA Failure Analysis of the April 28 2010 failed balloon launch World News 0
N Grilamid L25 vs. L20 for Nylon 12 Balloon Tubing Manufacturing and Related Processes 1
D Leak Test Method for Balloon Catheters EU Medical Device Regulations 2
G Supplier doesn't share drawings IATF 16949 - Automotive Quality Systems Standard 15
A Design History File - Not ready to share the design drawings or Bill of Material US Food and Drug Administration (FDA) 2
A FDA and NB audit of Engineering Drawings in DHF and DMR. Medical Device and FDA Regulations and Standards News 1
N Non traumatic edge - Remark in some of my company drawings EU Medical Device Regulations 1
R Supplier related drawings and verification of process requirements - Source Inspection AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
M Interesting Discussion Curious old drawings about electrical shock and safety IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
B AS9102 FAI & Lower Level Drawings - How should we perform the FAI? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
S Is it okay to store the design files (device drawings) at contract manufacturer location? ISO 13485:2016 - Medical Device Quality Management Systems 6
S Ballooned Drawings and Engineering Changes Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
S Graphic Overlay/Membrane Switch Drawings Manufacturing and Related Processes 2
pbojsen Supplier drawings used for purchase orders Document Control Systems, Procedures, Forms and Templates 6
S Document control for tooling drawings (Document control clause 7.5.3) IATF 16949 - Automotive Quality Systems Standard 5
N DFMEA, Drawings and PFMEA of an Assembly Process FMEA and Control Plans 12
S IATF 16949 Clause 8.3.3.3 - Documentation of all Special Characteristics in Drawings IATF 16949 - Automotive Quality Systems Standard 2
Q Converting Manufacturing Drawings from a Contract Supplier ISO 13485:2016 - Medical Device Quality Management Systems 7
R AS9102 - Are FAIs against a Customer Red-Lined Drawings Allowed? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
M McDonnell Douglas Specification Control Drawings Various Other Specifications, Standards, and related Requirements 4
R AS9102 FAI with No Drawings Supplied AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
Q Drawings from Client - ISO 9001:2008 Clause 4.2.3 or 7.5.4? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
L How do you manage your Inspection Drawings? IATF 16949 - Automotive Quality Systems Standard 9
G Implementation of Customer Requirements in Drawings Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
P CMM measurement using 2D drawings Calibration and Metrology Software and Hardware 1
I NCR for Customer not updating their drawings AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
B Creation of CAD solid models using customers supplied drawings AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
F Marking Requirements on Drawings (Prints) Document Control Systems, Procedures, Forms and Templates 1
N Inspection Requirements & Engineering Drawings - Measuring Shaft Dia. Inspection, Prints (Drawings), Testing, Sampling and Related Topics 16
I Drawing standard (VDA) - Drawings in 3 different status VDA Standards - Germany's Automotive Standards 4
D Should Customer Drawings be controlled per AS9100 QMS ? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
T Engineering Drawings - Once a customer has signed off on an engineering drawing ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
B How do design drawings affect QMS ? Quality Manager and Management Related Issues 8
S Product Registration - Assembly Drawings Japan Medical Device Regulations 7
M Computer System for Inspection Balloons in Technical Drawings Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
D Best Engineering Practices related to Top Assembly Drawings Document Control Systems, Procedures, Forms and Templates 6
B Shop Drawings that Integrate Information from a Database Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
S Supplier Quality with Prototyping Parts with no Part Number or Drawings ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
M Delta FAIs on essentially unchanged drawings AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
Z DPMO? Metrics for Engineering Drawings Six Sigma 1
J Thousands of Outdated Drawings/Prints - Help! Manufacturing and Related Processes 3
C Signing of Drawings and Technical Specification in Medical Device EU Medical Device Regulations 5
T Ballooning/Bubbling PDF drawings - My Dynamic Stamp AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 29
R In drawings, What is the K when is placed as temperature tolerance? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 11
D Redundant BOMs - Maintaining a Reference Only BOM on our Top Level Assembly Drawings Document Control Systems, Procedures, Forms and Templates 7
S Inspection to Non-Toleranced Drawings Inspection, Prints (Drawings), Testing, Sampling and Related Topics 10
R What does P-release mean in APQP documents regarding drawings and approvals? Design and Development of Products and Processes 1
