How to Benchmark? Is Benchmarking of any value? Seeking advice
Is Benchmarking of any Value?
  • Yes - We use Benchmarking all the time but it's not very important.
    Votes: 0 0.0%
  • No - We use Benchmarking but it's of no value.
    Votes: 0 0.0%
  • Total voters
    12
  • Poll closed .
#31
Re: How to benchmark (seek advice)? Is Benchmarking of any value?
well, it's moderately expensive process, but most organizations find that it more than pays for itself.
You mean something like these:
Xerox: The Benchmarking Story
Benchmarking for Best Practices: Winning Through Innovative Adaptation
Best Practices for Benchmarking
...etc. .... etc. ... etc. ...
I am sure you will find nicely filtered stories of the benefits - or costs - of benchmarking if one sifts through the internet, research and marketing media.
Will it benefit every case? Not always. As you peruse the citations, one of the biggest downsides is inadequate preparation for benchmarking. I think and other is interpretation. What you might interpret as a good idea on the surface simply might not be one. Benchmarking holds many of the same issues as surveys.
Your third link is broken--it has an extra "HTTP" at the beginning. Nonetheless, of the other two, one leads to an abstract of a paper recounting stuff that happened nearly thirty years ago, and the other is just a "Yay! Benchmarking!" article. The thing I was questioning was the blanket statement that most organizations find that benchmarking pays for itself. There's no reliable evidence that I know of to indicate that the statement is true. I've personally seen (at a large OEM) large amounts of money squandered on it. While there might be some benefit to be derived from benchmarking for some companies on a relatively small scale, I still say the best benchmarking strategy is to recognize that the companies you want to emulate have smarter people and smarter management. Get the best people you can get and let them do their jobs.
bobdoering
Stop X-bar/R Madness!!
#32
I fixed it for you and the other readers.
I did not do an exhaustive search, nor do I intend to (that is better left for someone working on their thesis).
My comment on the results of such a search being "filtered" is I doubt you will find any research designed specifically to test the negative (benchmarking may be so expensive that its expense outweighs its benefits). So, there is no reliable evidence that it is not true.
The problem is benchmarking is a broad concept, not a specific methodology like 8D corrective action reporting. Benchmarking can be a full blown project - and yes, those may be difficult to prove to be cost effective. But, it can also be a simple thought of "I noticed that they use this technology in their website and we don't. I can see we are missing a great opportunity." Now, that is pretty cheap. So, generalizing (or debating) - pro or con - on the overall concept is dubious. Its true measure of its benefits goes back to my cardinal rule: "It depends."
Yes, of course. One way people become smarter is look at the mistakes others make and don't do them, look at the things they do right, and do them. One might see that as either "benchmarking" or simply the basis of learning. That is clearly one of the the benefits people find by stopping by the "Cove".
DrTBurns
#34
Professor Deming's view:
"True: anyone could make a list of companies that are doing well, even though their management follows one or all of the above bad practices. These companies are saved by good luck, coincidence, having a product or service that commands good market. Any of these companies might do much better were the management to learn some theory of management. If anyone were to study without theory such a company, i.e., without knowing what questions to ask, he would be tempted to copy the company, on the pretext that 'they must be doing some things right.' To copy is to invite disaster."
"Too often this is the story. The management of a company,...knowing not how to go about it, having not guidance from principles, seeking enlightenment, embark on excursions to other companies that are ostensibly doing well. They are received with open arms, and the exchange of ideas commences. They (visitors) learn what the host is doing...Devoid of guiding principles, they are both adrift. Neither company knows whether or why any procedure is right, nor whether or why another is wrong. The question is not whether a business is successful, but why? and why was it not more successful? One can only hope that the visitors enjoy the ride. They are more to be pitied than censured."
msbettyhunt
#35
I've always thought of benchmarking as comparing to a similar industry / process. So, if I'm a metal stamper and I find that my die change takes 45 minutes, and I find that a competitor which does very similar work and has similar equipment does die changes in 20 minutes, I may be able to look at my die change process and see what I can do to reduce my die change time.
Granted there are differences between companies and processes, not to mention specific manufacturing equipment, but there are aspects which can, and should, be benchmarked if only to see 'where you stand with respecct to one or more competitors'.
Exactly, the benchmarking also became the reason of improvement and innovation in many organizations.
G Reverse FMEA - Benchmark for my studies IATF 16949 - Automotive Quality Systems Standard 2
Geoff Cotton What is the benchmark for Cost of Quality in a Heavy Engineering organization ? Benchmarking 2
C Benchmark Control Plan for Helical Gears FMEA and Control Plans 3
M SMED - 2750 Ton Injection Molding Machine Benchmark Benchmarking 3
Z Is There a Benchmark for PPM for Medical Devices? Benchmarking 4
P Benchmark of OEM (Original Equipment Manufacturer) Sourcing Audit Process Audits and Layered Process Audits 8
bobdoering Documentation Benchmark: The Pentagon's brownie recipe is 26 pages long... Coffee Break and Water Cooler Discussions 9
T EMS Benchmark Characteristics - Your review and comments appreciated Miscellaneous Environmental Standards and EMS Related Discussions 2
C Automotive Quality Benchmark data - Reliability and Durability Quality Metrics Benchmarking 3
M Customer Satisfaction Scale - How to Benchmark Customer Satisfaction? Benchmarking 16
Q Benchmark Survey - FMEA Deployment, Implementation and Use FMEA and Control Plans 4
S Are Pp and Ppk more useful than Cp and Cpk as a benchmark for further studies? Statistical Analysis Tools, Techniques and SPC 1
S Why historical data & benchmark data is important in APQP planning phase APQP and PPAP 6
Q Suggestion Program - Suggestion programs to improve our own and benchmark against Quality Tools, Improvement and Analysis 5
B Looking to Benchmark MFA (Market Feedback Analysis) Forms / Templates Benchmarking 3
M Percent recycle versus land fill benchmark - What percentage are you at? Miscellaneous Environmental Standards and EMS Related Discussions 1
SteelMaiden Customer Returns/External Reject Rate - Seeking world class performance benchmark ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
S Heijunka - Looking for a company we can benchmark in heijunka system Lean in Manufacturing and Service Industries 2
T Seeking Company to Benchmark With IATF 16949 - Automotive Quality Systems Standard 1
D Looking for a benchmark on traceability. Any offers? Quality Tools, Improvement and Analysis 18
M Business plan/ Benchmark - Input of business plan/marketing strategy and benchmarks APQP and PPAP 2
K Seeking Guidance on the most effective items and ways to Benchmark Preventive Action and Continuous Improvement 4
G Web based tool for benchmarking audit findings Benchmarking 6
M Benchmarking Process Data - Man-day calculation gone wrong Benchmarking 5
M What is Benchmarking? Benchmarking 7
gunnyshore Benchmarking: Approved Supplier List for Multiple Sites Supplier Quality Assurance and other Supplier Issues 2
M Benchmarking - Timely Closure of Corrective Actions Nonconformance and Corrective Action 3
M Tell me about Benchmarking Benchmarking 4
W Benchmarking Teardown and Salvage Process Benchmarking 1
P Benchmarking and Continuous Improvement Tool Benchmarking 3
A CATERPILLAR BGPP (Benchmarking Guide for Painting Process) Questionnaire Customer and Company Specific Requirements 4
P Cross Site Benchmarking of levels of business excellence Benchmarking 3
C Benchmarking Warranty Rates - What Rates should Trigger Actions? Benchmarking 1
C PPAP Benchmarking as it relates to the Aerospace Industry APQP and PPAP 7
V Benchmarking cGMP compliance (Systems compliance ) US Food and Drug Administration (FDA) 4
B Automotive Supplier Benchmarking - Supplier PPM Data Benchmarking 5
R Cost of Quality Benchmarking Information for the Electronics Industry Benchmarking 1
C Benchmarking our QMS against other organisations Benchmarking 8
R Benchmarking Supplier Certification Programs Supplier Quality Assurance and other Supplier Issues 7
S Benchmarking of Capability, Accuracy and Stability analyses - In Heat treatment Capability, Accuracy and Stability - Processes, Machines, etc. 3
S Load Testing Benchmarking Benchmarking 3
S Benchmarking PVC Profile Extrusion Metrics Benchmarking 2
R Benchmarking New Supplier First Article Processes Supplier Quality Assurance and other Supplier Issues 4
W Benchmarking vs. Goal Setting - Differences Benchmarking 3
M Benchmarking Audit programs General Auditing Discussions 13
F What's the best way to present benchmarking data? Benchmarking 6
C Benchmarking Preventive Maintenance Sales Benchmarking 0
Z Injection Molding cycle time benchmarking - Ball State University student Benchmarking 10
W Internal Benchmarking between product groups Benchmarking 4
B QFD (Quality Function Deployment) - World Class / Competitor Benchmarking Benchmarking 3
