How to boost morale of Inspection Department
Abelethan
In a world of do more with less, I'm confronted with the tasking of keeping my inspectors morale up. After sitting down as a team, their big complaint is they don't feel like they ever make progress as the list continues to grow and people insist their parts should take priority. So they are left with inspecting things out of order and never making a dent in whats needed. I know that we work hard, I know that we churn out parts.
How do you show/share your departments wins? What metrics are you using to measure your inspection department by?
I have a few metrics I track, however, it doesn't seem to boost confidence to our customers or my people.
Any suggestions would be appreciated.
Jen Kirley
Quality and Auditing Expert
Re: How to boost morale of Inspection Department?
Your phrase "In a world of do more with less" highlighted the problem.
I am not sure how you can make people feel better about being overextended. But that is just a symptom. I have questions:
Can any of these inspections be given over to production, saving your team for critical inspections?
Can additional internal persons be trained for the simpler tasks?
Are there any non-technical/administrative tasks that could be given over to another person?
Is this a temporary bottleneck or is production outpacing your team's ability to fulfill their tasks in an ongoing basis?
I am not sure what a metric will do for you, besides highlight for top management how behind you are. But that could be a start, as the standards all expect management to adequately resource their organization and its activities. This is why, I have found that even the otherwise ridiculous-looking metric "Number of ___ accurately performed over number of ___ scheduled" can actually be a worthwhile metric, as it is speaking to resources, or perhaps planning of schedules or cross training.
David-D
Do you have any ability to change the methods that you inspect/accept parts/products. For example, are you able perform variable sampling rather than attribute sampling. This may enable you to inspect less parts but also provide more rich and insightful data and analysis about the parts you are inspecting. Can you add value on the capability and distribution of the products? If you can give good insight on the quality of the products, you can also potentially better influence the appropriate level of inspections being performed to better allocate and focus your limited quality resources on the greatest risks.
David
Eredhel
Quality Manager
I'll follow up on their questions as well. Are you all running into hiccups with in process inspections, inspections at the end of the run, and/or both? Are they feeling bogged down by daily/shift First Part Inspections? Are you all using an AQL sample level? Do you ever let production do any of the higher volume checks or do you have Designated Inspectors that aren't in QA? Knowing some of this could help learn where you're coming from and make it easier to troubleshoot.
N
ncwalker
My opinion - many "requests" just aren't necessary. We get asked for data and measurements far too often to check a box. And it is a bit of a trap - usually the request SOUNDS like a reasonable thing to do. The data would be nice to have.
But then, you carefully gather the data and it isn't used to make a decision. That is the waste of over processing.
Many times, someone on the floor is root causing and instead of thinking, they just say "measure everything, and we will sift the data looking for an answer." And they don't have to do the measuring ...
It sounds like you have measurements you HAVE to do - part of your processes. And then there are fires - people bringing you the emergencies. Without hesitation, I would say only 20% of those fires are REALLY adding value.
If it were me, I would very specifically allot time to the fires. Let's say your staff is going to spend 60% of the time on the regularly scheduled things they are responsible for and 40% of the time on the fires. (You'd need to do a study to find out YOUR percentages). Well, do your 60% of the work and the 40% fire fighting means some of the "emergencies" are going to sit, or even get turned away.
If you are tracking your time carefully and can justify the 60%, you are (should be) covered. You HAVE to do that stuff by procedure. If management doesn't like it, then they need to change the procedure. The "misses" of the 40% that don't get done ... that's a staffing problem.
But morale? You step in the line of fire and shield your staff and you'll get a morale boost. They'll do anything for you if they see you doing this. That's what a leader does ....
Sidney Vianna
Post Responsibly
According to your profile, you work in an organization that produces household chemical products. Is the inspection activities you are referring to, tests of such chemicals?
Big Jim
May I suggest that you obtain a copy of "The Goal" by Eliyahu M. Goldratt and learn about production bottlenecks and how to manage them. Read it, then pass it on to those above you.
There is risk here, as it can be difficult to manage up, but if they catch on they will learn how your bottleneck is hurting their bottom line.
Even if your the only one that benefits from reading it, you will be better off for doing so.
ronaldjankens23
Simple Awards:
Sometimes the simplest awards can have the most meaning. For example, at AT&T Universal Card Services, they have a pad of paper shaped like a globe with "Thank You" written all over it. Anyone in the company can use the pad to send a thank you to anyone else.
Fun Days:
Keep employees fit and boost morale by organizing an inter-office softball league and giving employees time off to cheer on their team. Some companies, such as Texas-based Whataburger, even have their own company Olympics with events related to work activities.
Peer-Initiated Recognition:
Start a program to encourage employees to reward each other. According to Bob Nelson, author of "1001 Ways to Reward Employees," recognition from one's peers has a special significance because the employee knows it is sincere and well-earned.
Celebrations:
Anything a bit out of the ordinary can help raise morale by giving employees something different to do. Celebrate events such as Chinese New Year with chopstick competitions and dumpling-making classes. Have employees decorate their area for holidays, such as Halloween, and offer prizes for the best decorations etc
:thanks:
Bakka323
As you stated, we as a company are forced to "do more with less" is a reality. As Jen mentioned above, we have to highlight the benefits to adding another member to our inspection team. In the business case you will have to focus on the Cost of Poor Quality and the affects it has on the customer.
On the flip side, we have two programs to help ease the work load of our inspectors:
1) Supplier Delegation or Dock to Stock (DTS) - This is where you qualify suppliers based on performance (quality) of part supplied and have the supplier do the inspection rather than your team.
2) Certified Operator Program - this is where you certify technicians to inspect and sign off others work. Every machine shop should have a similar program.
***Watch out b/c these programs could improve efficiency so much that you may be forced do a ROF.
What about keeping inspectors focused throughout a normal 8 hour day shift? What has worked for you?
Mike S.
Happy to be Alive
If you hire well, most people come with good morale and attitudes, and your primary job as a manager, etc. is to not squash or destroy it. If you only do that, you will be ahead of most places. If you provide an environment for it to grow, you will be truly top 5% or higher.
Unfortunately, far too many organizations still adhere to an autocratic, top-down, my-way-or-the-highway, adversarial boss-employee relationship paradigm and seem to be set-up perfectly to systematically destroy rather than support good employee morale and attitudes.
JMO
L Employee Morale Boosters - Low cost, quick, and easy ideas to boost morale Preventive Action and Continuous Improvement 31
Sidney Vianna ISO/IEC standard for "one-stop accreditation" to boost cross-border trade ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 2
L "Morale" as an indicator - How to track "morale"? Misc. Quality Assurance and Business Systems Related Topics 16
J Quality, Cost, Delivery, Safety, Morale/Man, Machine, Material, Method Spread Sheet Quality Tools, Improvement and Analysis 6
A How do you Measure Operator Motivation / Morale? Our Auditor wants Documentation IATF 16949 - Automotive Quality Systems Standard 39
Marc Survey shows that employee morale has taken a hit World News 3
L Seeking Suggestions: How to Improve Low Morale in Company Misc. Quality Assurance and Business Systems Related Topics 3
W Ford Production Sytem - SQDCME Safety, Quality, Delivery, Cost, Morale, Environment Customer and Company Specific Requirements 35
S Why do suppliers submit bad parts // Quality Incoming Inspection Supplier Quality Assurance and other Supplier Issues 12
U How should we build the FDA inspection preparedness team for FDA inspections at factories? General Auditing Discussions 0
K Equipment IQ/OQ/PQ required when you have 100% product inspection? ISO 13485:2016 - Medical Device Quality Management Systems 2
B IATF 7.1.5.1.1 Measurement system analysis (Visual Inspection) IATF 16949 - Automotive Quality Systems Standard 3
Q Failure modes for Inspection processes ISO 14971 - Medical Device Risk Management 15
J Crimp inspection and process verification AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
H Looking to make inspection faster for part with over 100 dimensions. Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
U FDA foreign inspection and COVID19 US Medical Device Regulations 4
H Is it a requirement for run charts to have inspection data or can it have just a pass/fail check mark Records and Data - Quality, Legal and Other Evidence 4
T Need advice on what inspection equipment to buy. General Measurement Device and Calibration Topics 2
optomist1 PCBA Inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
J Best Practices for Choosing In-process Inspection Dimensions & SPC Dimensions Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
B Inspection procedure for components Oil and Gas Industry Standards and Regulations 8
Bev D Acceptance Inspection Sampling Plan Calculators Misc. Quality Assurance and Business Systems Related Topics 0
J Justification for visual inspection ISO 13485:2016 - Medical Device Quality Management Systems 3
M Cameras and Visual Inspection Equipment General Measurement Device and Calibration Topics 3
John Broomfield Construction Inspection and Test Plan Misc. Quality Assurance and Business Systems Related Topics 5
F Self Evident Inspection Method ISO 13485:2016 - Medical Device Quality Management Systems 11
M How does FDA determine OAI and VAI after inspection? ISO 13485:2016 - Medical Device Quality Management Systems 0
P 21 CFR 58 GLP Periodic Study Phase Inspection Report Other US Medical Device Regulations 0
C Inspection Operation in PFMEA FMEA and Control Plans 13
L Language of quality system in case of FDA inspection US Food and Drug Administration (FDA) 1
I In-Process Inspection Raw Data ISO 13485:2016 - Medical Device Quality Management Systems 3
B Inspection of polymer palletes - sampling plan Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
C Discus Software for First Article Inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
R Suggest modern equipment/instrument for plastic bottle inspection? Quality Tools, Improvement and Analysis 1
H Starting my own 3rd party inspection company Service Industry Specific Topics 6
N Quality Inspection Quality Tools, Improvement and Analysis 10
W Proper gage to use for receiving inspection General Measurement Device and Calibration Topics 9
P Test Method Validation (TMV) for all Measurement Methods in Rec/Inspection Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
C KAPPA index Reference Value for Visual inspection IATF 16949 - Automotive Quality Systems Standard 1
A Industry Standards for Cosmetic Inspection Criteria Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
Azaarus Help with CAPA for an IATF finding regarding inspection documentation IATF 16949 - Automotive Quality Systems Standard 10
A % of defects on the whole batch based on result from inspection under AQL Level II Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
T IATF 16949 Recording inspection results IATF 16949 - Automotive Quality Systems Standard 2
J Drawing Example Request: Inspection Section Plane of Aluminum Casting Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
Azaarus Looking for important points regarding First Piece Inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
K Is Calibration Required for Non-Adjustable Commercial Inspection Devices? General Measurement Device and Calibration Topics 11
M Lighting Standard for Metal Processing Inspection Manufacturing and Related Processes 4
U How to pick between ANSI Z1.4 vs. ISO2859-1 for AQL Inspection? What are the major differences? AQL - Acceptable Quality Level 4
S For Parts Manufacturer Approval (PMA) Is 100% Inspection Required? Federal Aviation Administration (FAA) Standards and Requirements 2
M Detection rank for sampling vs 100% inspection & 15x vs 400x magnification FMEA and Control Plans 4
