How to calculate Cpk on Perpendicularity (Cyl Tol Zone at MMC)
#21
Bev
I am not sure what you mean by back calculate from the defect rate.
To 'back calculate' means you take the defect rate, convert it to a Z score then divide by three.
so in excel Cpk = [NORMSDIST(1-p)]/3 where p = defect rate.
the defect rate can be the defect rate using the bonus tolerance...
#22
I disagree with you about the role of "bonus tolerance" that I prefer to call variable limit tolerance. It is defined the way it is because it is the way the real parts work and assemble.
We agree on this. I don't have anything against the use of 'bonus' tolerances to accept and ship parts that will work. that's just good business sense. I am opposed to using for them for statistical analysis (beyond my comment below) and process improvement. Tehre are times when variation reduction is nto cost effective due to technology and organizational maturity issues. However, often we can reduce the variation and then have no need for 'bonus' tolerances...
Is it improperly applied to designs? Absolutely!!! Is it summarily ignored in continuous data statistical conformance predictions? Absolutely!!! Should we continue to ignore it for those reasons? Absolutely not!!!
uhhhh. Here is where I have issues. Using statistical capability models which rely on a fairly accurate assumption on the underlying distribution to predict future conformance is seductive, but ultimately futile in my experience. I have found that we are far better off if we understand the process, characterize the inputs and outputs and where applicable create real models of Y=f(X) form to control our processes. If we need to know how many defects we are making a simple counting of the defects we actually encounter is usually close enough for any business purpose and is far easier than distributional models. (I prefer to spend my statistical energy on analytic studies that improve and really predict future performance than to waste energy - and time - on precise enumerative studies of material I've already made and then use that to 'predict' future performance.)
I think you will agree that the real value is realized in examining the data and improving the process so that the probability of a defect is so remote that the process performance can put statisticians out of business.
Absolutely. except that I think statisticians are still needed...
Is Blueplanet's hole shallow or deep? What is causing such a uniform or skewed distribution for both perpendicularity and size? If the holes are shallow is the perpendicularity deviation generated mostly from measurement error or finish? If it is deep is its orientation deviation predictable... can its mean orientation error be adjusted? Why is the size skewed toward the upper limit? Do we even have enough data to make any valid conclusions???
All great questions that go to true capability; the Cpk value and it's calculation have no bearing on these questions....but they are the money making questions...
#24
how many times did you have to invoke the bonus tolerance?
The alternative is to look at the totality of your process and not just some arbitrary 30 piece sample. 30 pieces can be good enough IF they are representative of your process - typically a random sample from some substantially larger population produced over time. Too often I see these capability studies done only on the last 30 sequential pieces or the last 30 samples and they aren't representative.
What is your current defect rate (last 3 months)? Can you plot your results for the last 3 months in time series? (I don't know the volume of your production or your current sample plan so 3 months is a guess...)
I think the barrier you are experiencing right now is your own internal constrained thinking (I don't intend that to be a mean or insulting comment). There are other ways to do this but you need to be open to considering them. What you are hearing from the folks here is that you are running down a dead end alley with your current 30 piece sample approach. We need to get you on a different path to determine capability.
Blueplanet
#25
We are a job shop. The customer has an order of 300 pcs. Under their requirments we do a capability study on the first 30 parts. The customer picks several features they want the capability study on. We do the study and if our Cpk is > 1.33 then we are not required to perform 100% inspection on the features that meet their Cpk requirements. If we do not then 100% inspection is required along with every measurement documented (which we have to submit with the parts). The customer will field test these parts and then have them manufactured else where. We only have a couple customers with this requirement.
Paul F. Jackson
#26
I was speaking of the appropriate application and use of the variable MMC or LMC tolerance modifier on the design not the reliability of the distribution model.
If one chooses not to apply the variable tolerance in a continuous data model and the variable portion is ignored then he also chooses to accept economic penalties of rejecting and scraping potentially conforming product.
If a competent continuous data model cannot be then you are left with using the attribute data model and you know how many defect free instances are permitted in many thousands of parts to make a simple prediction from that. One is better off resigning themselves to a 100% attribute gage check.
If it was my process I would pay attention to the details until I understand their behavior over time with continous data until I can demonstrate the processes inherent ability to produce to those specifications... then either strive for improvement or consider an alternate process.
Paul
#27
Well the first 30 pieces violates the whole premise of a capability study.
If it were me, then I would simply do a straightforward calculation of the capability without regard to the bonus tolerances. Bonus tolerances should only be applied part by part anyway so if you fail the 'study', 100% inspection is the right thing to do. If you pass you don't need the bonus tolerances.
Blueplanet
#28
I thought that a capability study could be done using 30 pcs, using 3 sigma instead of 6?
Paul noted that the diameters were on the high side above the nominal; this was not a drift in our process we did this to use the MMC bonus. I was able to do a graph in mini tab under capability analysis using Stat > Quality Tools > Capability Analysis > Normal (assumed). The graph does not show the typical +/ - sigma it just shows the LSL; it does however give me a Cpk of 2.19 for my perp; which I think the customer will buy.
#29
30 pieces is on the low side but it is a rough 'rule of thumb' for the minimum number of pieces. If we are serious about the answer, the sample size is dependent on the standard deviation of the process and the amount of accuracy we desire for the estimate of the index, average and SD. 100 samples is a better rule of thumb for a minimum sample size
BUT the SIZE isn't the biggest issue, the randomness of the sample is. Your customer is requiring a bastardized version of a capability study - it is a blatant misuse and misunderstanding of statistics. But you're stuck with their simplicity...My advice is: do the minimum youhave to do to make yoru customer SQE happy and focus your efforts on real quality problems...
I have no idea what this means to you. Capability studies for capability index calculations use +/- 3 sigma about the mean
Paul F. Jackson
#30
Blueplanet you must use 0.015 as your USL for your capability in Minitab... you cannot add the maximum variable tolerance allotment to your USL to predict conformance. When I figured the RFS capability with your data the Cp(upper) was a negative number meaning that the mean perpendicularity deviation was above the Minimum variable USL 0.015.
Paul
B How to calculate CPK with n = 1 Manufacturing and Related Processes 2
A Simple 125 piece part Capabilty Excel .xls sheet to calculate Cpk Capability, Accuracy and Stability - Processes, Machines, etc. 3
S Which one is better to calculate, Cpk or Ppk? Statistical Analysis Tools, Techniques and SPC 11
G Should I calculate both Cp and Cpk for a Unilateral Tolerance? Statistical Analysis Tools, Techniques and SPC 8
A How to calculate Cpk & Ppk if the tolerance changes during the period? Capability, Accuracy and Stability - Processes, Machines, etc. 5
F Please share an MS Excel sheet to calculate Cpk and Ppk Statistical Analysis Tools, Techniques and SPC 1
M Cpk - How to calculate when the number of samples is less than 30 pieces? Capability, Accuracy and Stability - Processes, Machines, etc. 7
D Use of Customer Specifications to calculate Cpk IATF 16949 - Automotive Quality Systems Standard 13
F How to Calculate Cpk with only a Minimum Tolerance Capability, Accuracy and Stability - Processes, Machines, etc. 11
C How to Calculate and Generate a Cpk Chart Statistical Analysis Tools, Techniques and SPC 4
B If I know x-bar, spec limits, and Cpk, can I calculate the control limits? Capability, Accuracy and Stability - Processes, Machines, etc. 16
J Methods used to calculate Cpk value - Need help for Cpk Calculation Statistical Analysis Tools, Techniques and SPC 8
H How can I calculate Cp & Cpk and make a control chart for maintenance activities? Capability, Accuracy and Stability - Processes, Machines, etc. 3
N Cpk vs Ppk - Which should you use and How to Calculate Cpk and Ppk Statistical Analysis Tools, Techniques and SPC 25
A Sampling Plans and Cpk - Ways to Calculate the Sample Quantity Inspection, Prints (Drawings), Testing, Sampling and Related Topics 15
N Capability study - What Values do I have to input to calculate Cp and Cpk Capability, Accuracy and Stability - Processes, Machines, etc. 9
B How do I calculate Cpk with a single Control Limit? Capability, Accuracy and Stability - Processes, Machines, etc. 15
S Cmk and Cpk - When will we need to calculate Cmk? Machine Capability Capability, Accuracy and Stability - Processes, Machines, etc. 4
J How do I calculate the percentage of errors, when I know min, max, mean, cp and CPK Capability, Accuracy and Stability - Processes, Machines, etc. 3
D Can I calculate Cpk from Cp and Cr? Capability, Accuracy and Stability - Processes, Machines, etc. 5
S Bend allowance formula to calculate per degree per radii Manufacturing and Related Processes 2
P Commercial excel templates that calculate overhead, hourly rates, fee proposal Excel .xls Spreadsheet Templates and Tools 0
M How to calculate benefits? Moving some developed non controlled software/automation systems Service Industry Specific Topics 2
qualprod Calculate number of people in processes, considering cycle time/takt time = quantity of people Lean in Manufacturing and Service Industries 9
S How to Calculate the producer Risk AQL - Acceptable Quality Level 25
qualprod Methods to Calculate Available Production Rate ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 0
K Why calculate LCL in P-chart? Statistical Analysis Tools, Techniques and SPC 4
A Add-On software for VMC to calculate setting time, Idle Time, OEE etc.. Manufacturing and Related Processes 2
L How to calculate the Probability of Deficiency of the AQL of an Inspection AQL - Acceptable Quality Level 16
V How to Calculate Unbiasing Constant C4 Statistical Analysis Tools, Techniques and SPC 1
J How to Calculate OEE Indicator for a Workshop (15 Machines) Lean in Manufacturing and Service Industries 6
R How to calculate UCL (Upper COntrol Limit) and LCL (Lower Control Limit) Statistical Analysis Tools, Techniques and SPC 5
T I want to calculate reliability at 750 hours Reliability Analysis - Predictions, Testing and Standards 8
R How To Calculate & Print CDF and Lower Bound CDF value for some t(time) with Minitab? Using Minitab Software 1
N How to calculate the Premium Freight charges Service Industry Specific Topics 4
A How to calculate Mean and standard deviation without sample size in Minitab Using Minitab Software 5
R When do I need to calculate Process OEE? Manufacturing and Related Processes 12
kedarg6500 How to calculate Thread Pitch Diameter for non standard TPI like 5/8" 17.75 NF3 Manufacturing and Related Processes 3
C Definition and Way to Calculate some Metrics Lean in Manufacturing and Service Industries 6
M How calculate P value for Linearity and Bias using Excel Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
N Formula that will calculate the NoGo Major Diameter of an M20 x 1.5 6H Thread gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
M How to calculate Cg and Cgk for a 2-Dimensional Area Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
T Calculation Question - Calculate the runner weight for a part Manufacturing and Related Processes 2
M Spreadsheet on How to Calculate SMT Capacity wanted Manufacturing and Related Processes 2
F How to Calculate the unbiased Standard Deviation in Excel using Minitab Formula Capability, Accuracy and Stability - Processes, Machines, etc. 6
S Spreadsheet that will Calculate Audit Duration times based on IAF MD5 and MD11 Excel .xls Spreadsheet Templates and Tools 7
M Calculate PPMs by going back to Date of Production or Date Noticed Quality Tools, Improvement and Analysis 7
M How to calculate MTTF (Mean Time to Failure) Reliability Analysis - Predictions, Testing and Standards 1
H How to calculate the Lot Reject Rate Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
