How to calculate Cpk & Ppk if the tolerance changes during the period?
adityatanuwijaya
Hello everybody, I'm new here, I hope you can help me.
Do anyone know how to calculate cpk and ppk if in the period of calculation, the spec has changes?
For example during cpk calculation in November, the tolerance change from 10-13 cm to 11-14 cm in the middle of the month.
Can I calculate one by one (before and after) and make average?
Thanks for your kind help.
:thanks:
aditya
Re: How to calculate Cpk & Ppk if the tolerance change during the period?
You can, but that doesn't mean you should.
The capability should be be the current capability for the period and be actionable. At this point I would recommend only calculating the capability using the current tolerance. To do otherwise would imply a process change when only the tolerance has changed...
adityatanuwijaya
Thanks Bev D. I'm doing this in order to not lose the "capability of process" before the tolerance change. Is doing the average for cpk correct scientifically?
You know they may have different data, etc2...
Anyone who can share their experience?
Thanks all!
It is not statistically or practically correct to average the indexes.
If you don't want to 'lose the capability' calculate the indexes for the two periods separately. Remember the process hasn't changed. The tolerances did.
bobdoering
Stop X-bar/R Madness!!
Here is a key point: did the process or its control change to accommodate the new tolerance? If so, you need to start fresh at that point. If not, then using the old data applying the new tolerance to the old data would still be applicable to understand its historical capability.
As BevD says, averaging a global statistic of this type is really statistical gibberish...more so than the indices themselves to begin with.
I might also ask what your real question is? in other words, what question are you trying to answer with the capability index calculations? this will allow us to give a much more helpful answer.
S Which one is better to calculate, Cpk or Ppk? Statistical Analysis Tools, Techniques and SPC 11
F Please share an MS Excel sheet to calculate Cpk and Ppk Statistical Analysis Tools, Techniques and SPC 1
N Cpk vs Ppk - Which should you use and How to Calculate Cpk and Ppk Statistical Analysis Tools, Techniques and SPC 25
B How to calculate CPK with n = 1 Manufacturing and Related Processes 2
A Simple 125 piece part Capabilty Excel .xls sheet to calculate Cpk Capability, Accuracy and Stability - Processes, Machines, etc. 3
G Should I calculate both Cp and Cpk for a Unilateral Tolerance? Statistical Analysis Tools, Techniques and SPC 8
M Cpk - How to calculate when the number of samples is less than 30 pieces? Capability, Accuracy and Stability - Processes, Machines, etc. 7
D Use of Customer Specifications to calculate Cpk IATF 16949 - Automotive Quality Systems Standard 13
B How to calculate Cpk on Perpendicularity (Cyl Tol Zone at MMC) Capability, Accuracy and Stability - Processes, Machines, etc. 32
F How to Calculate Cpk with only a Minimum Tolerance Capability, Accuracy and Stability - Processes, Machines, etc. 11
C How to Calculate and Generate a Cpk Chart Statistical Analysis Tools, Techniques and SPC 4
B If I know x-bar, spec limits, and Cpk, can I calculate the control limits? Capability, Accuracy and Stability - Processes, Machines, etc. 16
J Methods used to calculate Cpk value - Need help for Cpk Calculation Statistical Analysis Tools, Techniques and SPC 8
H How can I calculate Cp & Cpk and make a control chart for maintenance activities? Capability, Accuracy and Stability - Processes, Machines, etc. 3
A Sampling Plans and Cpk - Ways to Calculate the Sample Quantity Inspection, Prints (Drawings), Testing, Sampling and Related Topics 15
N Capability study - What Values do I have to input to calculate Cp and Cpk Capability, Accuracy and Stability - Processes, Machines, etc. 9
B How do I calculate Cpk with a single Control Limit? Capability, Accuracy and Stability - Processes, Machines, etc. 15
S Cmk and Cpk - When will we need to calculate Cmk? Machine Capability Capability, Accuracy and Stability - Processes, Machines, etc. 4
J How do I calculate the percentage of errors, when I know min, max, mean, cp and CPK Capability, Accuracy and Stability - Processes, Machines, etc. 3
D Can I calculate Cpk from Cp and Cr? Capability, Accuracy and Stability - Processes, Machines, etc. 5
S Bend allowance formula to calculate per degree per radii Manufacturing and Related Processes 2
P Commercial excel templates that calculate overhead, hourly rates, fee proposal Excel .xls Spreadsheet Templates and Tools 0
M How to calculate benefits? Moving some developed non controlled software/automation systems Service Industry Specific Topics 2
qualprod Calculate number of people in processes, considering cycle time/takt time = quantity of people Lean in Manufacturing and Service Industries 9
S How to Calculate the producer Risk AQL - Acceptable Quality Level 25
qualprod Methods to Calculate Available Production Rate ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 0
K Why calculate LCL in P-chart? Statistical Analysis Tools, Techniques and SPC 4
A Add-On software for VMC to calculate setting time, Idle Time, OEE etc.. Manufacturing and Related Processes 2
L How to calculate the Probability of Deficiency of the AQL of an Inspection AQL - Acceptable Quality Level 16
V How to Calculate Unbiasing Constant C4 Statistical Analysis Tools, Techniques and SPC 1
J How to Calculate OEE Indicator for a Workshop (15 Machines) Lean in Manufacturing and Service Industries 6
R How to calculate UCL (Upper COntrol Limit) and LCL (Lower Control Limit) Statistical Analysis Tools, Techniques and SPC 5
T I want to calculate reliability at 750 hours Reliability Analysis - Predictions, Testing and Standards 8
R How To Calculate & Print CDF and Lower Bound CDF value for some t(time) with Minitab? Using Minitab Software 1
N How to calculate the Premium Freight charges Service Industry Specific Topics 4
A How to calculate Mean and standard deviation without sample size in Minitab Using Minitab Software 5
R When do I need to calculate Process OEE? Manufacturing and Related Processes 12
kedarg6500 How to calculate Thread Pitch Diameter for non standard TPI like 5/8" 17.75 NF3 Manufacturing and Related Processes 3
C Definition and Way to Calculate some Metrics Lean in Manufacturing and Service Industries 6
M How calculate P value for Linearity and Bias using Excel Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
N Formula that will calculate the NoGo Major Diameter of an M20 x 1.5 6H Thread gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
M How to calculate Cg and Cgk for a 2-Dimensional Area Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
T Calculation Question - Calculate the runner weight for a part Manufacturing and Related Processes 2
M Spreadsheet on How to Calculate SMT Capacity wanted Manufacturing and Related Processes 2
F How to Calculate the unbiased Standard Deviation in Excel using Minitab Formula Capability, Accuracy and Stability - Processes, Machines, etc. 6
S Spreadsheet that will Calculate Audit Duration times based on IAF MD5 and MD11 Excel .xls Spreadsheet Templates and Tools 7
M Calculate PPMs by going back to Date of Production or Date Noticed Quality Tools, Improvement and Analysis 7
M How to calculate MTTF (Mean Time to Failure) Reliability Analysis - Predictions, Testing and Standards 1
H How to calculate the Lot Reject Rate Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
