How to calculate Subgroup Size for Machine Capability Study
G
gcpa81
I have given the task of conducting machine capability study. We are going to run 50 parts through each machine. We are measuring all the significant characteristics in every single part (about 15 different measurement through CMM). My question is how does once calculate subgroup size?
Is is 1 or 50?
bobdoering
Stop X-bar/R Madness!!
Should be one. There is no logical grouping for what you are doing. If you were doing 300, and checked 5, skipped 10, did 5 more, etc., then you would have subgroups of 5.
KCIPOH
Is is 1 or 50?
Hello bob,
I just want to clear out my doubt as i'm quite confuse with subgroup size definition in doing capability study, so, you mentioned should 1 and according to gcpa81, 50 parts and need to measure 15 significant characteristics, is that mean we take only 1 part out of 50 and measure the 15 characteristics? :confused:
bobdoering
Hello bob,
I just want to clear out my doubt as I'm quite confuse with subgroup size definition in doing capability study, so, you mentioned should 1 and according to gcpa81, 50 parts and need to measure 15 significant characteristics, is that mean we take only 1 part out of 50 and measure the 15 characteristics? :confused:
If he is doing a capability study where he runs 50 parts in a row through a machine, then measures the parts, then for any statistics used to analyze to data the subgroup should be 1. If you were to chart the parts and a traditional Shewhart chart was appropriate, then you would use I-MR. Some folks like to dream up a subgroup - maybe 4 or 5 - then use X bar -R or similar calculations. but, logical subgroups and made-up-to-make-software-work subgroups are two very different things. Only one is truly useful.
Of course, as an aside, no matter what process it is, you should do both a run chart and do curve fitting. Always get the data in time order sequence. If you find multi-modal variation, you will want to see if it is a time function. Dumping data into software and chugging out a "normal" curve, Cpks and Ppks is backyard stuff. The true distribution may not even support Cpks or Ppks. Also, it is critical that the measurement system not contribute to the distribution, or it may mask the true process distribution. Poor measurement technique and gage R&R can make a lot of non-normal distributions look normal by masking. So will overcontrol.
Interesting, huh? :popcorn:
Just to throw another fast ball: 50 parts in a row will only show short term variation and could lead to a very misleading result. (lots of measuremetns with very littel useful information provided). The original intention of these 'capability studies' was that they would be comprised of subgroups* (samples) that were taken over time such that they would represent the full range of variation that the process could be expected to see when operating within the specified parameters. The subgroups are plotted in time series and the process is assessed for stability. The so-called 'short term capability' is then calculated from the within subgroup standard deviation and the 'long term capability' is calculated from the total standard deviation.
Short cuts are the quick way to confusion and wasted effort as evidenced by the large number of postings here asking "what went wrong with my Cpk study"?
*Of course, for very low volume production, the subgroup size would have to be 1 and the parts would be sequential.
P Commercial excel templates that calculate overhead, hourly rates, fee proposal Excel .xls Spreadsheet Templates and Tools 0
M How to calculate benefits? Moving some developed non controlled software/automation systems Service Industry Specific Topics 2
qualprod Calculate number of people in processes, considering cycle time/takt time = quantity of people Lean in Manufacturing and Service Industries 9
S How to Calculate the producer Risk AQL - Acceptable Quality Level 25
qualprod Methods to Calculate Available Production Rate ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 0
K Why calculate LCL in P-chart? Statistical Analysis Tools, Techniques and SPC 4
B How to calculate CPK with n = 1 Manufacturing and Related Processes 2
A Add-On software for VMC to calculate setting time, Idle Time, OEE etc.. Manufacturing and Related Processes 2
L How to calculate the Probability of Deficiency of the AQL of an Inspection AQL - Acceptable Quality Level 16
V How to Calculate Unbiasing Constant C4 Statistical Analysis Tools, Techniques and SPC 1
J How to Calculate OEE Indicator for a Workshop (15 Machines) Lean in Manufacturing and Service Industries 6
R How to calculate UCL (Upper COntrol Limit) and LCL (Lower Control Limit) Statistical Analysis Tools, Techniques and SPC 5
T I want to calculate reliability at 750 hours Reliability Analysis - Predictions, Testing and Standards 8
R How To Calculate & Print CDF and Lower Bound CDF value for some t(time) with Minitab? Using Minitab Software 1
N How to calculate the Premium Freight charges Service Industry Specific Topics 4
A How to calculate Mean and standard deviation without sample size in Minitab Using Minitab Software 5
R When do I need to calculate Process OEE? Manufacturing and Related Processes 12
kedarg6500 How to calculate Thread Pitch Diameter for non standard TPI like 5/8" 17.75 NF3 Manufacturing and Related Processes 3
C Definition and Way to Calculate some Metrics Lean in Manufacturing and Service Industries 6
M How calculate P value for Linearity and Bias using Excel Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
N Formula that will calculate the NoGo Major Diameter of an M20 x 1.5 6H Thread gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
M How to calculate Cg and Cgk for a 2-Dimensional Area Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
T Calculation Question - Calculate the runner weight for a part Manufacturing and Related Processes 2
M Spreadsheet on How to Calculate SMT Capacity wanted Manufacturing and Related Processes 2
F How to Calculate the unbiased Standard Deviation in Excel using Minitab Formula Capability, Accuracy and Stability - Processes, Machines, etc. 6
S Spreadsheet that will Calculate Audit Duration times based on IAF MD5 and MD11 Excel .xls Spreadsheet Templates and Tools 7
M Calculate PPMs by going back to Date of Production or Date Noticed Quality Tools, Improvement and Analysis 7
M How to calculate MTTF (Mean Time to Failure) Reliability Analysis - Predictions, Testing and Standards 1
H How to calculate the Lot Reject Rate Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
L How calculate the number of samples Statistical Analysis Tools, Techniques and SPC 2
A Simple 125 piece part Capabilty Excel .xls sheet to calculate Cpk Capability, Accuracy and Stability - Processes, Machines, etc. 3
R How to calculate MMC when is placed after datum Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
S Which one is better to calculate, Cpk or Ppk? Statistical Analysis Tools, Techniques and SPC 11
C How to calculate P value on Probability Plot Statistical Analysis Tools, Techniques and SPC 1
S Supplier Disruption Score and how to calculate it Quality Tools, Improvement and Analysis 4
D IAQG OASIS - New tool to calculate Audit Time AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
M How to calculate dimensions of trapezoid ? Quality Tools, Improvement and Analysis 3
J How to calculate Surveillance Audit Days in Corporate Audit Scheme IATF 16949 - Automotive Quality Systems Standard 4
S How to calculate Supplier PPM at Receiving Inspection Document Control Systems, Procedures, Forms and Templates 2
K How to Calculate Sample Size at 95% Confidence Interval on Surface Roughness Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
R How to calculate the value add time? Lean in Manufacturing and Service Industries 2
G Should I calculate both Cp and Cpk for a Unilateral Tolerance? Statistical Analysis Tools, Techniques and SPC 8
H Continuous Monitoring Instrument Data Validation and how to calculate Outliers Quality Tools, Improvement and Analysis 1
R How to calculate the Air Flow Rate in clause 201.12.4.4.105 of IEC 60601-2-16:2012 IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
A How to calculate Cpk & Ppk if the tolerance changes during the period? Capability, Accuracy and Stability - Processes, Machines, etc. 5
S PPAP - How to calculate tolerance on basic dimension APQP and PPAP 5
B Attrition Rate and the formula to calculate Attrition Rate Quality Manager and Management Related Issues 1
I How to calculate the Current Quality Level (CQL) of a Process Statistical Analysis Tools, Techniques and SPC 5
bio_subbu CDSCO-India: Draft Guideline to Calculate Compensation for Victims of Clinical Trials Other Medical Device Regulations World-Wide 0
