How to calculate Surveillance Audit Days in Corporate Audit Scheme
jelly1921
If a company had three sites with 100, 250 and 500 staffs respectively, and 25 staffs in support location, then audit days of initial stage 2 audit can be calculated like this:
Site 1: 100 staffs + 3 (# of employees apportioned form support location 3 = 25*(100/875=12%))= 103 --> 6.0 (from Table 5.2 of the RULES)
6.0*80%(1-20%) [% reduction --- corporate scheme ] --> 4.8
Site 2: 6.4
Site 3: 8.4
Total 19.6
According to 5.2 of the Rules: The percent reduction shall only be applied to the initial and recertification audits day calculation. Subsequent audit days are based on this reduced initial day calculation.
I got confuse about the word "reduced", so please help me to calculate surveiliance audit day?
Thanks! [ 3kq --- chinese way to speak thank you on the net :lol: ]
Jelly
Greg19
When using a Corporate scheme you get a reduction ( as seen in your example).
Surveillance days are based on registration audit Days. So when you calculate audit Days for your surveillance audit the reduction is already made.
What you do is that you divide audit Days from stage 2 with number of surveillance audits in your audit cycle:
Example.
For one site site you have calculated 4,8 Days. This will give you 5 Days for stage 2. (Always rounded up to the nearest 0.5).
If you are on a yearly scheme ( 1 audit per year) you will have 2 surveillance audits each certification cycle- To get the audit Days for each surveillance you divide 5 Days/ 2 = each surveillance will be 2,5 Days.
If your on 6 month scheme you will have four surveillance audits. 5/4 = 1.25 . Rounded up to nearest 0.5 this will give you 1.5 Days for each surveillance.
Hope this was reply to your question.
Please note that audit Days stated in rules are minimum required Days. Each CB are required to make their own calculation based on eg history, complexity.
jelly1921
Thank you for your answer.
It seems the reduction is also applicable to the calculation of surveilance audit days, but the Table 5.3 Audit days Reduction for "Corporate" Audit scheme" defined Percent reduction for initial and recertification audits only"
One more question about r) when calculating audit days, the result shall be rounded up to the earest half day in 5.2 Audit days determination of the Rules :
One way to round up is just like you did in your answer, i.e. to round up for each site separately:
Site 1 : 4.8 --> 5
Site 2: 6.4 --> 6.5
Site 3: 8.4 --> 8.5
Total: 20
Another way to round up the final results (19.6) to nearest half day.
In my example, the result is the same. But in some circumstance, it will be 0.5 day more or less. For example:
Site 1: 4.6 --> 5
Site 2: 6.3 -->6.5
Site 3: 8.2 -->8.5
Total: 19.1 --> 19.5 But 20 = 5+6.5+8.5
I am not sure which calculation is correct.
Thanks!
Jelly
Greg19
Hi again,
No worries, we are here to help each other.
If you see the scentence Below in 5.3 you can also see that it states that surv. Audit days are based on the reduced initial audit day calculation. If we should add reduction on the surv. Days as well the reduction would be doubled.
Corporate schemes are a synergy effects. Each site Will still get Their own certificate. But we skall have in mind that problems in one site can affect the certificate of the other site (s). Corporate scheme is not a multisite certificate.
Each site is treated on Their own in the calculation ( see My first reply).
Hope this was reply to your questions.
//Greg
S How to calculate Effective Number of People for ISO 13485 Certification? General Auditing Discussions 2
A Need to calculate tolerance Intervals with a set of non-normal data and 3-Parameter Weibull distribution Using Minitab Software 0
U Calculate acceptance of equipment reading after calibration General Measurement Device and Calibration Topics 2
U Calculate acceptance of calibration reading Measurement Uncertainty (MU) 1
S How would you calculate this? Capability, Accuracy and Stability - Processes, Machines, etc. 4
S Bend allowance formula to calculate per degree per radii Manufacturing and Related Processes 2
P Commercial excel templates that calculate overhead, hourly rates, fee proposal Excel .xls Spreadsheet Templates and Tools 0
M How to calculate benefits? Moving some developed non controlled software/automation systems Service Industry Specific Topics 2
qualprod Calculate number of people in processes, considering cycle time/takt time = quantity of people Lean in Manufacturing and Service Industries 9
S How to Calculate the producer Risk AQL - Acceptable Quality Level 25
qualprod Methods to Calculate Available Production Rate ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 0
K Why calculate LCL in P-chart? Statistical Analysis Tools, Techniques and SPC 4
B How to calculate CPK with n = 1 Manufacturing and Related Processes 2
A Add-On software for VMC to calculate setting time, Idle Time, OEE etc.. Manufacturing and Related Processes 2
L How to calculate the Probability of Deficiency of the AQL of an Inspection AQL - Acceptable Quality Level 16
V How to Calculate Unbiasing Constant C4 Statistical Analysis Tools, Techniques and SPC 1
J How to Calculate OEE Indicator for a Workshop (15 Machines) Lean in Manufacturing and Service Industries 6
R How to calculate UCL (Upper COntrol Limit) and LCL (Lower Control Limit) Statistical Analysis Tools, Techniques and SPC 5
T I want to calculate reliability at 750 hours Reliability Analysis - Predictions, Testing and Standards 8
R How To Calculate & Print CDF and Lower Bound CDF value for some t(time) with Minitab? Using Minitab Software 1
N How to calculate the Premium Freight charges Service Industry Specific Topics 4
A How to calculate Mean and standard deviation without sample size in Minitab Using Minitab Software 5
R When do I need to calculate Process OEE? Manufacturing and Related Processes 12
kedarg6500 How to calculate Thread Pitch Diameter for non standard TPI like 5/8" 17.75 NF3 Manufacturing and Related Processes 3
C Definition and Way to Calculate some Metrics Lean in Manufacturing and Service Industries 6
M How calculate P value for Linearity and Bias using Excel Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
N Formula that will calculate the NoGo Major Diameter of an M20 x 1.5 6H Thread gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
M How to calculate Cg and Cgk for a 2-Dimensional Area Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
T Calculation Question - Calculate the runner weight for a part Manufacturing and Related Processes 2
M Spreadsheet on How to Calculate SMT Capacity wanted Manufacturing and Related Processes 2
F How to Calculate the unbiased Standard Deviation in Excel using Minitab Formula Capability, Accuracy and Stability - Processes, Machines, etc. 6
S Spreadsheet that will Calculate Audit Duration times based on IAF MD5 and MD11 Excel .xls Spreadsheet Templates and Tools 8
M Calculate PPMs by going back to Date of Production or Date Noticed Quality Tools, Improvement and Analysis 7
M How to calculate MTTF (Mean Time to Failure) Reliability Analysis - Predictions, Testing and Standards 1
H How to calculate the Lot Reject Rate Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
L How calculate the number of samples Statistical Analysis Tools, Techniques and SPC 2
A Simple 125 piece part Capabilty Excel .xls sheet to calculate Cpk Capability, Accuracy and Stability - Processes, Machines, etc. 3
R How to calculate MMC when is placed after datum Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
S Which one is better to calculate, Cpk or Ppk? Statistical Analysis Tools, Techniques and SPC 11
C How to calculate P value on Probability Plot Statistical Analysis Tools, Techniques and SPC 1
S Supplier Disruption Score and how to calculate it Quality Tools, Improvement and Analysis 4
D IAQG OASIS - New tool to calculate Audit Time AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
M How to calculate dimensions of trapezoid ? Quality Tools, Improvement and Analysis 3
S How to calculate Supplier PPM at Receiving Inspection Document Control Systems, Procedures, Forms and Templates 2
K How to Calculate Sample Size at 95% Confidence Interval on Surface Roughness Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
R How to calculate the value add time? Lean in Manufacturing and Service Industries 2
G Should I calculate both Cp and Cpk for a Unilateral Tolerance? Statistical Analysis Tools, Techniques and SPC 8
H Continuous Monitoring Instrument Data Validation and how to calculate Outliers Quality Tools, Improvement and Analysis 1
R How to calculate the Air Flow Rate in clause 201.12.4.4.105 of IEC 60601-2-16:2012 IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
