How to calculate the minimum Value of Mass needed for Scales Calibration?
F
FIRAS_N
Hello for all members ,,,
i would like to ask about Scales Calibration ,,, what is the minimum value of Mass ( weight ) needed to calibrate the scale?
for Example if i have Electronic Scale with Max. Capacity of 750 Kg with d=100 g
what is the Range of Weights / Mass that we need to make Calibration for4 this weight?
i need to use weight till 200 Kg, 250 Kg, 300 Kg, .... please if there are some Equations or Rules to Calculate that provide me ,,, with My Best Wishes for all.
Chance
Hi, please refer to the user's manual of your scale. It will tell you how to calibrate your scale.
In my case, some of our scales don't have user's manual anymore, so we did a research in internet and created internal procedure. To calibrate a scale in compliance to ISO 9001 (we are), we purchased test weights along with statement of accuracy traceable to national standards like NIST.
We then use at least three mass weights, one close to the minimum capacity, one close to middle capacity and one close to maximum capacity of the scale. We also set tolerance.
Jerry Eldred
NIST Handbook 44 "SPECIFICATIONS, TOLERANCES, AND OTHER TECHNICAL
REQUIREMENTS FOR WEIGHING AND MEASURING DEVICES" contains detailed standard tolerances, methods, etc. for calibrating scales. Depending on your quality system, you may or may not use it, but it is a very good resource.
F
FIRAS_N
thank you Chance, i used weights in range similar to the range of the scale, so when i make scale with Max. 750 kg i used weights until 750 Kg, but may be we need to fix weights until the middle range in the Calibration Records so we are also ISO 9001 certified, and the external auditor advice me to use NIST or OIML Standard to find Table or Equation to find the relation.
F
FIRAS_N
thank you Jerry Eldred, i will review and read the NIST Handbook 44 off course it is useful,
BradM
Jerry is very correct about Handbook 44. Do be on notice, though, it is a pretty extensive document. :D Handbook 44 is written primarily for vendors calibrating large scales (like truck scales). For large scales, the standard allows for abbreviated range testing; meaning it is acceptable to check a scale up to 50% of range. That may not always serve the needs in the best manner.
I think you should be evaluating how you use the scale/balance also. I'm not as sure about scales (typically using 3-4 load cells), but analytical balances (typically with 1 sensor) has a "sweet spot". So if you have a balance with a range of 0-1000 grams, it's optimal operating area is around 50% (500 grams). It will become much less stable as you get closer to 0%, with trying to weigh 10 grams will be challenging (if you are verifying repeatability). If an analytical balance is used for assay measurement in the FDA realm, per USP 41 the minimum weight must be identified and documented. Not a bad idea to do on any balance, though.
So you should consider qualifying your scale. What is the range of the scale, and what test points do you use it at? Consider what the maximum weight that will be applied to the scale, and the minimum (probably if you tare out a container or something).
Typically, we try to hit around 10%, 50, and 90% of full range (if applicable). Otherwise, you should shoot for something like 0, 25, 50, 75, and 100% of use range. Don't forget to conduct corner load tests.
Mass Standards:
In general, try to purchase several small denomination weights. There is a pretty big difference in moving around 10, 5kg weights and one 50kg weight.:) There's a huge difference between 1 500 kg weight and 10 50 kg weights; and so on. You can construct metal carts to transport the weights. If you can stay small, around 20 kg and below per weight, someone should easily be able to lift them. From there up, you will probably want a hoist/pulley system.
Depending on the desired accuracy, Class F weights should be good.
Unless you have a lot of scales, it may not be worth it to do it yourself. There may be a local competent lab to do it for you. However, do recall they may not check it up to full range (per Handbook 44).
F
FIRAS_N
Mass Standards:
thank you very much BradM for your clarifications, really Handbook 44 is very useful and i found all information that i need for the minimum weights needed for calibration,
i found the table - minimum test weights and test load page 2-31 from handbook 44,
thank you for all members share us here.
F How to Calculate Cpk with only a Minimum Tolerance Capability, Accuracy and Stability - Processes, Machines, etc. 11
R What is minimum sample size to calculate Cp? Statistical Analysis Tools, Techniques and SPC 9
S Bend allowance formula to calculate per degree per radii Manufacturing and Related Processes 2
P Commercial excel templates that calculate overhead, hourly rates, fee proposal Excel .xls Spreadsheet Templates and Tools 0
M How to calculate benefits? Moving some developed non controlled software/automation systems Service Industry Specific Topics 2
qualprod Calculate number of people in processes, considering cycle time/takt time = quantity of people Lean in Manufacturing and Service Industries 9
S How to Calculate the producer Risk AQL - Acceptable Quality Level 25
qualprod Methods to Calculate Available Production Rate ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 0
K Why calculate LCL in P-chart? Statistical Analysis Tools, Techniques and SPC 4
B How to calculate CPK with n = 1 Manufacturing and Related Processes 2
A Add-On software for VMC to calculate setting time, Idle Time, OEE etc.. Manufacturing and Related Processes 2
L How to calculate the Probability of Deficiency of the AQL of an Inspection AQL - Acceptable Quality Level 16
V How to Calculate Unbiasing Constant C4 Statistical Analysis Tools, Techniques and SPC 1
J How to Calculate OEE Indicator for a Workshop (15 Machines) Lean in Manufacturing and Service Industries 6
R How to calculate UCL (Upper COntrol Limit) and LCL (Lower Control Limit) Statistical Analysis Tools, Techniques and SPC 5
T I want to calculate reliability at 750 hours Reliability Analysis - Predictions, Testing and Standards 8
R How To Calculate & Print CDF and Lower Bound CDF value for some t(time) with Minitab? Using Minitab Software 1
N How to calculate the Premium Freight charges Service Industry Specific Topics 4
A How to calculate Mean and standard deviation without sample size in Minitab Using Minitab Software 5
R When do I need to calculate Process OEE? Manufacturing and Related Processes 12
kedarg6500 How to calculate Thread Pitch Diameter for non standard TPI like 5/8" 17.75 NF3 Manufacturing and Related Processes 3
C Definition and Way to Calculate some Metrics Lean in Manufacturing and Service Industries 6
M How calculate P value for Linearity and Bias using Excel Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
N Formula that will calculate the NoGo Major Diameter of an M20 x 1.5 6H Thread gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
M How to calculate Cg and Cgk for a 2-Dimensional Area Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
T Calculation Question - Calculate the runner weight for a part Manufacturing and Related Processes 2
M Spreadsheet on How to Calculate SMT Capacity wanted Manufacturing and Related Processes 2
F How to Calculate the unbiased Standard Deviation in Excel using Minitab Formula Capability, Accuracy and Stability - Processes, Machines, etc. 6
S Spreadsheet that will Calculate Audit Duration times based on IAF MD5 and MD11 Excel .xls Spreadsheet Templates and Tools 7
M Calculate PPMs by going back to Date of Production or Date Noticed Quality Tools, Improvement and Analysis 7
M How to calculate MTTF (Mean Time to Failure) Reliability Analysis - Predictions, Testing and Standards 1
H How to calculate the Lot Reject Rate Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
L How calculate the number of samples Statistical Analysis Tools, Techniques and SPC 2
A Simple 125 piece part Capabilty Excel .xls sheet to calculate Cpk Capability, Accuracy and Stability - Processes, Machines, etc. 3
R How to calculate MMC when is placed after datum Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
S Which one is better to calculate, Cpk or Ppk? Statistical Analysis Tools, Techniques and SPC 11
C How to calculate P value on Probability Plot Statistical Analysis Tools, Techniques and SPC 1
S Supplier Disruption Score and how to calculate it Quality Tools, Improvement and Analysis 4
D IAQG OASIS - New tool to calculate Audit Time AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
M How to calculate dimensions of trapezoid ? Quality Tools, Improvement and Analysis 3
J How to calculate Surveillance Audit Days in Corporate Audit Scheme IATF 16949 - Automotive Quality Systems Standard 4
S How to calculate Supplier PPM at Receiving Inspection Document Control Systems, Procedures, Forms and Templates 2
K How to Calculate Sample Size at 95% Confidence Interval on Surface Roughness Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
R How to calculate the value add time? Lean in Manufacturing and Service Industries 2
G Should I calculate both Cp and Cpk for a Unilateral Tolerance? Statistical Analysis Tools, Techniques and SPC 8
H Continuous Monitoring Instrument Data Validation and how to calculate Outliers Quality Tools, Improvement and Analysis 1
R How to calculate the Air Flow Rate in clause 201.12.4.4.105 of IEC 60601-2-16:2012 IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
A How to calculate Cpk & Ppk if the tolerance changes during the period? Capability, Accuracy and Stability - Processes, Machines, etc. 5
S PPAP - How to calculate tolerance on basic dimension APQP and PPAP 5
