How to calculate the Probability of Deficiency of the AQL of an Inspection
L
leturc
Hi All,
I'm trying to calculate the probability of deficiency of an inspection conducted. We already know that AQL has 2 risks from it's nature:
  • Good lots can be rejected, or
  • bad lots can be accepted.
My qyestion is how we can define the probability of failure of a "accepted" inspection and vice versa.
Mike S.
Happy to be Alive
Try looking at the OC (operating characteristic) curves and/or tables for the sampling plan you are using.
For example, for a lot size of 50 and a sample size of 13, with no rejects allowed in the sample, the probability of lot acceptance is 50% if around 5% of the parts in the lot are bad.
My question is how we can define the probability of failure of a "accepted" inspection and vice versa.
I'm not sure of your exact question. It would be helpful to understand what you mean by "failure" of an "Accepted" lot. Is it a lot having more defects than the AQL level? Is it a lot having more defects than the RQL or LTPD level? or is it the probability of the lot being rejected under the same plan later in time (such as at your Customer). Also what do you mean by the 'failure' of a rejected lot?
L
leturc
Hi all,
Thanks for your answers. In fact I'm working for a 3rd party inspection company and give inspection services for our customers. Often, our client come back to us with a complaint that they didn't found the same defects percentage and / or defects of our sampling. I explain them that our sampling is random and due to the nature of the AQL sampling there is always a risk to accept bad lots or refuse good lots but unfortunately they do not want to understand. So, I was wondering if it is possible to give them after each service the probability of failure of our sampling? I now that ISO 2859 gives us a table with some % but I'ld like to calculate the probability for each individual sampling. Is it possible?
The dilemma is that the probability is based on the actual defect rate of the lot. Which you cannot know from sampling. The probabilities are based on what would happen if you sampled the same lot many, many times. It is accurate on average over the long run...it is not accurate for any individual lot. The best you can do is to share the OC curve of the sampling plan you use. That describes the range of probabilities associated with various actual defect rates...
Some people also forget that the AQL is the acceptable defect rate that will be accepted 95% of the time...they think it is the defect rate that will be rejected 95% of the time...
The worst part is that a non-homogenous distribution of defects in the lot cannot be overcome by random sampling. So non-homogeneity increases the actual probability of 'missing' a 'bad' lot.
The other factor is the measurement error which is also rarely accounted for. Every measurement system, including visual inspection, has measurement error. The OC curves 'assume' that no measurement error exists...
Simply put, sampling is imperfect. Improving the quality so that defects are very rare is the only reliable way of knowing if you have an acceptable lot or not...
Mike S.
Happy to be Alive
If you homogenize the lot it can......
Mike S.
Happy to be Alive
Yup, I'm a big Wheeler fan. :agree1:
I agree you can't always homogenize a lot for sampling, but sometimes you can. The nit I picked was that you said you "cannot" overcome a non-homogenous distribution of defects in the lot, when sometimes you can. :2cents:
ah, so the nit I'll pick back is that I did say you can't overcome non-homogeneity with random sampling....:D
C How to calculate P value on Probability Plot Statistical Analysis Tools, Techniques and SPC 1
D How to calculate the A4 constants in Median/Range control charts? Statistical Analysis Tools, Techniques and SPC 2
S How to calculate Effective Number of People for ISO 13485 Certification? General Auditing Discussions 2
A Need to calculate tolerance Intervals with a set of non-normal data and 3-Parameter Weibull distribution Using Minitab Software 0
U Calculate acceptance of equipment reading after calibration General Measurement Device and Calibration Topics 2
U Calculate acceptance of calibration reading Measurement Uncertainty (MU) 1
S How would you calculate this? Capability, Accuracy and Stability - Processes, Machines, etc. 4
S Bend allowance formula to calculate per degree per radii Manufacturing and Related Processes 2
P Commercial excel templates that calculate overhead, hourly rates, fee proposal Excel .xls Spreadsheet Templates and Tools 0
M How to calculate benefits? Moving some developed non controlled software/automation systems Service Industry Specific Topics 2
qualprod Calculate number of people in processes, considering cycle time/takt time = quantity of people Lean in Manufacturing and Service Industries 9
S How to Calculate the producer Risk AQL - Acceptable Quality Level 25
qualprod Methods to Calculate Available Production Rate ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 0
K Why calculate LCL in P-chart? Statistical Analysis Tools, Techniques and SPC 4
B How to calculate CPK with n = 1 Manufacturing and Related Processes 2
A Add-On software for VMC to calculate setting time, Idle Time, OEE etc.. Manufacturing and Related Processes 2
V How to Calculate Unbiasing Constant C4 Statistical Analysis Tools, Techniques and SPC 1
J How to Calculate OEE Indicator for a Workshop (15 Machines) Lean in Manufacturing and Service Industries 6
R How to calculate UCL (Upper COntrol Limit) and LCL (Lower Control Limit) Statistical Analysis Tools, Techniques and SPC 5
T I want to calculate reliability at 750 hours Reliability Analysis - Predictions, Testing and Standards 8
R How To Calculate & Print CDF and Lower Bound CDF value for some t(time) with Minitab? Using Minitab Software 1
N How to calculate the Premium Freight charges Service Industry Specific Topics 4
A How to calculate Mean and standard deviation without sample size in Minitab Using Minitab Software 5
R When do I need to calculate Process OEE? Manufacturing and Related Processes 12
kedarg6500 How to calculate Thread Pitch Diameter for non standard TPI like 5/8" 17.75 NF3 Manufacturing and Related Processes 3
C Definition and Way to Calculate some Metrics Lean in Manufacturing and Service Industries 6
M How calculate P value for Linearity and Bias using Excel Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
N Formula that will calculate the NoGo Major Diameter of an M20 x 1.5 6H Thread gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
M How to calculate Cg and Cgk for a 2-Dimensional Area Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
T Calculation Question - Calculate the runner weight for a part Manufacturing and Related Processes 2
M Spreadsheet on How to Calculate SMT Capacity wanted Manufacturing and Related Processes 2
F How to Calculate the unbiased Standard Deviation in Excel using Minitab Formula Capability, Accuracy and Stability - Processes, Machines, etc. 6
S Spreadsheet that will Calculate Audit Duration times based on IAF MD5 and MD11 Excel .xls Spreadsheet Templates and Tools 8
M Calculate PPMs by going back to Date of Production or Date Noticed Quality Tools, Improvement and Analysis 7
M How to calculate MTTF (Mean Time to Failure) Reliability Analysis - Predictions, Testing and Standards 1
H How to calculate the Lot Reject Rate Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
L How calculate the number of samples Statistical Analysis Tools, Techniques and SPC 2
A Simple 125 piece part Capabilty Excel .xls sheet to calculate Cpk Capability, Accuracy and Stability - Processes, Machines, etc. 3
R How to calculate MMC when is placed after datum Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
S Which one is better to calculate, Cpk or Ppk? Statistical Analysis Tools, Techniques and SPC 11
S Supplier Disruption Score and how to calculate it Quality Tools, Improvement and Analysis 4
D IAQG OASIS - New tool to calculate Audit Time AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
M How to calculate dimensions of trapezoid ? Quality Tools, Improvement and Analysis 3
J How to calculate Surveillance Audit Days in Corporate Audit Scheme IATF 16949 - Automotive Quality Systems Standard 4
S How to calculate Supplier PPM at Receiving Inspection Document Control Systems, Procedures, Forms and Templates 2
K How to Calculate Sample Size at 95% Confidence Interval on Surface Roughness Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
R How to calculate the value add time? Lean in Manufacturing and Service Industries 2
G Should I calculate both Cp and Cpk for a Unilateral Tolerance? Statistical Analysis Tools, Techniques and SPC 8
H Continuous Monitoring Instrument Data Validation and how to calculate Outliers Quality Tools, Improvement and Analysis 1
