How to Calculate the unbiased Standard Deviation in Excel using Minitab Formula
F
ferme
does someone know how to calculate the unbiesed standard devistion in excel using the formula as minitab?
Stijloor
Re: How to Calculate the unbiased Standard Devistion in Excel using Minitab Formula
A Quick Bump!
Can someone help?
Thank you very much!!
Do you currently have Minitab? If so, you can find the formulae that Minitab uses using these instructions.
Steve Prevette
Deming Disciple
For Excel, generally the "unbiased" estimate of the standard deviation from a sample is the STDEV formula, versus the STDEVP formula which assumes you know the entire population.
However, there are some more esoteric issues with "unbiased standard deviation" which I found some sniffs of with this Wikipedia article -> Wikipedia reference-linkUnbiased_estimation_of_standard_deviation I do not vouch for this information, I've not run across it elsewhere. Not being a Minitab user, I don't know what Minitab does and (IMO) don't much trust Minitab.
F
ferme
Thanks guys, the really issue here is that i know the formula that minitab use, but i am not able to replicate it in excel, i know that i need the C4 factor and all the data, i have it, but the result is not the same in minitab i am doing something wrong but i dont know what. i attached one file that other guy post here i studied the format and can't get the pooled unbised standard deviation, hope someone can help.
E
El Capten
I am not familiar with minitab. I looked at your excel spreadsheet. You can determine your standard deviation from your R Bar value. My text book, "Statistical Quality Control" Grant and Leavenworth 4th Ed. table B page 644 give a d2 factor of 2.326 for Rbar n=5. Formula is Rbar / factor. Your example:
R bar = .931 / 2.326 = .4003 is your unbiased estimate of S'
E
El Capten
I looked at your excel spreadsheet and assume that you are doing a capability study or it represents shop floor data as a control chart.
I used your data and calculated upper and lower control limits for X bar and R bar and see that while your R chart is ok, you have several data points out of control limits for your X bar control chart.
My calculations are based on the reference text noted in my previous reply. UCL X = Xbar +A2Rbar LCL X = Xbar - A2Rbar for n=5, A2 =.58 and for range chart D4 = 2.11
for X bar = 36.858 and R bar = .931 control limits are: UCL = 36.858 + .58 x .931 = 37.398, LCL = 36.858 -.
58 x .931 =36.318 range is Rbar x D4 = .931 x 2.11 = 1.964
I dont know what you application is for this data, but since there are data points outside the control limits, you have an unstable process from which you can not draw any assumptions or predictions about process capability.
A Need to calculate tolerance Intervals with a set of non-normal data and 3-Parameter Weibull distribution Using Minitab Software 0
U Calculate acceptance of equipment reading after calibration General Measurement Device and Calibration Topics 2
U Calculate acceptance of calibration reading Measurement Uncertainty (MU) 1
S How would you calculate this? Capability, Accuracy and Stability - Processes, Machines, etc. 4
S Bend allowance formula to calculate per degree per radii Manufacturing and Related Processes 2
P Commercial excel templates that calculate overhead, hourly rates, fee proposal Excel .xls Spreadsheet Templates and Tools 0
M How to calculate benefits? Moving some developed non controlled software/automation systems Service Industry Specific Topics 2
qualprod Calculate number of people in processes, considering cycle time/takt time = quantity of people Lean in Manufacturing and Service Industries 9
S How to Calculate the producer Risk AQL - Acceptable Quality Level 25
qualprod Methods to Calculate Available Production Rate ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 0
K Why calculate LCL in P-chart? Statistical Analysis Tools, Techniques and SPC 4
B How to calculate CPK with n = 1 Manufacturing and Related Processes 2
A Add-On software for VMC to calculate setting time, Idle Time, OEE etc.. Manufacturing and Related Processes 2
L How to calculate the Probability of Deficiency of the AQL of an Inspection AQL - Acceptable Quality Level 16
V How to Calculate Unbiasing Constant C4 Statistical Analysis Tools, Techniques and SPC 1
J How to Calculate OEE Indicator for a Workshop (15 Machines) Lean in Manufacturing and Service Industries 6
R How to calculate UCL (Upper COntrol Limit) and LCL (Lower Control Limit) Statistical Analysis Tools, Techniques and SPC 5
T I want to calculate reliability at 750 hours Reliability Analysis - Predictions, Testing and Standards 8
R How To Calculate & Print CDF and Lower Bound CDF value for some t(time) with Minitab? Using Minitab Software 1
N How to calculate the Premium Freight charges Service Industry Specific Topics 4
A How to calculate Mean and standard deviation without sample size in Minitab Using Minitab Software 5
R When do I need to calculate Process OEE? Manufacturing and Related Processes 12
kedarg6500 How to calculate Thread Pitch Diameter for non standard TPI like 5/8" 17.75 NF3 Manufacturing and Related Processes 3
C Definition and Way to Calculate some Metrics Lean in Manufacturing and Service Industries 6
M How calculate P value for Linearity and Bias using Excel Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
N Formula that will calculate the NoGo Major Diameter of an M20 x 1.5 6H Thread gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
M How to calculate Cg and Cgk for a 2-Dimensional Area Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
T Calculation Question - Calculate the runner weight for a part Manufacturing and Related Processes 2
M Spreadsheet on How to Calculate SMT Capacity wanted Manufacturing and Related Processes 2
S Spreadsheet that will Calculate Audit Duration times based on IAF MD5 and MD11 Excel .xls Spreadsheet Templates and Tools 8
M Calculate PPMs by going back to Date of Production or Date Noticed Quality Tools, Improvement and Analysis 7
M How to calculate MTTF (Mean Time to Failure) Reliability Analysis - Predictions, Testing and Standards 1
H How to calculate the Lot Reject Rate Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
L How calculate the number of samples Statistical Analysis Tools, Techniques and SPC 2
A Simple 125 piece part Capabilty Excel .xls sheet to calculate Cpk Capability, Accuracy and Stability - Processes, Machines, etc. 3
R How to calculate MMC when is placed after datum Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
S Which one is better to calculate, Cpk or Ppk? Statistical Analysis Tools, Techniques and SPC 11
C How to calculate P value on Probability Plot Statistical Analysis Tools, Techniques and SPC 1
S Supplier Disruption Score and how to calculate it Quality Tools, Improvement and Analysis 4
D IAQG OASIS - New tool to calculate Audit Time AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
M How to calculate dimensions of trapezoid ? Quality Tools, Improvement and Analysis 3
J How to calculate Surveillance Audit Days in Corporate Audit Scheme IATF 16949 - Automotive Quality Systems Standard 4
S How to calculate Supplier PPM at Receiving Inspection Document Control Systems, Procedures, Forms and Templates 2
K How to Calculate Sample Size at 95% Confidence Interval on Surface Roughness Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
R How to calculate the value add time? Lean in Manufacturing and Service Industries 2
G Should I calculate both Cp and Cpk for a Unilateral Tolerance? Statistical Analysis Tools, Techniques and SPC 8
H Continuous Monitoring Instrument Data Validation and how to calculate Outliers Quality Tools, Improvement and Analysis 1
R How to calculate the Air Flow Rate in clause 201.12.4.4.105 of IEC 60601-2-16:2012 IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
A How to calculate Cpk & Ppk if the tolerance changes during the period? Capability, Accuracy and Stability - Processes, Machines, etc. 5
