How to carry out Gage R&R for automatic machines? Automated Equipment
syeedabu
Hi
I am syed,
I want to know that how we do Gage R&R study for Automatic machine.
for automatic machine no appraiser in needed.So how we calculate the reproducibility in this case.
regards
syed
Re: How we study Gage R&R for automatic machines
It depends on the machine. If it has multiple stations, treat each station as an operator. If it only has one station, you can perform a simple repeatibility study using an Xbar/R chart.
For example, take 10 parts and measure each part 5 times. Plot the average and range for each of the 10 parts on an Xbar/R chart. You can assess the Range chart and the Xbar chart exactly as a standard MSA. You can use the Rbar to estimate the standard deviation for Repeatibility (Rbar/d2), and can use this to calculate the P/T Ratio or %GRR as required. The total GRR will equal the GRR due to repeatibility since there is no reproducibility component.
All normal rules for collecting samples still apply, that is the samples must represent the actual process variation.
Howard Atkins
Forum Administrator
Welcome to the cove
If you look at the bottom of the page you can see some more discussions on the same issue.
Please look at them as well
As there are tolerances the mounting of the sample on the fixture, even if it is automatic , still is slightly different
syeedabu
Thanks a lot.
That threads will be halpfull to me
:thanx:
Re: How to carry out Gage R&R for automatic machines?
be careful with "automatic" machines - if the part is manually placed in a fixture then you do have real operator to operator differences to assess.
David DeLong
Bev:
I think that you mean that the part is taken out off the machine and placed in a checking fixture and then is measured automatically. I would then agree that there would be a developed R & R value.
But
If the gauge reads the dimension automatically during the process, that would be quite different. In this case we would have to isolate 10 parts and run them through the automatic sensor with 2 or 3 operators and have 2 or 3 reps. There should be very little R & R unless we are reading a dial rather than a digital readout.
If the process would not allow one to run parts through more than once, then an R & R study may not be applicable here.
Stijloor
Bev:
But
David,
You raise a very interesting point! Because even though the operator manually loads the part in the fixture, the checking/measuring/verification device could still establish a unique datum reference frame, or establish a new/unique "0" point so that the observed variation would only be part-dependent.
Does that make sense?
Stijloor.
David DeLong
David,
Stijloor.
If we load the same part differently each time, we would get different readings thus a R & R that could be substantial. We would be establishing different datums.
Also, taking the reading off a dial differs depending upon the angle of view. At perpendicular, we might read a 0 but looking at the dial from the left side, we might read a 1.
I really don't think one is taking the part and placing it in a fixture. I think the the part dimension is read once during the process such as on automatic screw machins and an R & R is impractical since we cannot run the same part though the process again and again.
K Does company who manufacture but does not design or carry out clinical trials is responsible for CE marking for single use medical devices? ISO 13485:2016 - Medical Device Quality Management Systems 3
M Criteria and when to carry out Setup Approval Manufacturing and Related Processes 5
T Single or Multi site Internal Audits - Any difference in how to carry out? Internal Auditing 2
V How to carry out a Process Audit General Auditing Discussions 4
A PPAP for carry over (from an existing to a new model) components APQP and PPAP 4
P Who can carry out CQI-9 Assessments? CQI-9 Assessor Qualifications? IATF 16949 - Automotive Quality Systems Standard 2
K ISO 9001:2008 Project Start - How to carry out a Gap Analysis? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
P How to carry out Risk Analysis in a company with pastry products Food Safety - ISO 22000, HACCP (21 CFR 120) 1
somashekar The CE Certificate may no longer carry the CE Mark EU Medical Device Regulations 2
P Product Requalification Test - Auditor want us to carry out IATF 16949 - Automotive Quality Systems Standard 16
6 How to implement a functional system and carry out high quality internal Audit? Quality Manager and Management Related Issues 2
M TS Clause 7.6.3.2 - Can Non-Accreditated External Laboratory Carry out Calibration? IATF 16949 - Automotive Quality Systems Standard 14
Z How to Carry Out ?Customer Focus? on All Parts of Management System? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 35
A How to carry out 'Monitoring and measurement of processes' - Clause 8.2.3. Nonconformance and Corrective Action 12
A Action on Quality Records - Approve, Update and Carry Out Revision Control Records and Data - Quality, Legal and Other Evidence 10
L Is it necessary to carry out all the MSA studies? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
E APQP on Current Production and Carry Over Parts APQP and PPAP 3
M Can external quality consultant carry out internal audit? Internal Auditing 17
S Competence (4.4.2) Records - Contractors who carry out skilled maintenance tasks Miscellaneous Environmental Standards and EMS Related Discussions 8
L Special Characteristics in DFMEA (Design FMEA) - Carry over to PFMEA? FMEA and Control Plans 9
Sidney Vianna Should products carry the certification marks? Other ISO and International Standards and European Regulations 8
J Measurement Resolution - How far to carry the decimal place out Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 13
E Is it obligatory that only trained personel can carry out calibration? General Measurement Device and Calibration Topics 1
L Gage RandR on automated equipment. IATF 16949 - Automotive Quality Systems Standard 7
S Type 1 Gage R&R or something else? Reliability Analysis - Predictions, Testing and Standards 6
R Gage R&R Excel templates Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
K Gage R&R with more than 3 appraisers Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
M Definitive answer on Type 1 vs Type 2 vs Type 3 Gage Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
V Gage Management and Gage R&R Software General Measurement Device and Calibration Topics 1
D Gage R&R Study on Load Cells - Large chemical blending tanks IATF 16949 - Automotive Quality Systems Standard 1
S Gage R&R on alloy Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
