How to carry out Gage R&R for automatic machines? Automated Equipment
Stijloor
#21
Re: How to carry out Gage R&R for automatic machines?
Failing to understand the concepts involved, the customer won't listen to reason and the supplier just manipulates the numbers in order to get on with his life. The customer looks only at the bottom line, and if it appears satisfactory, he gets on with his life and begins another line of ignorant nitpicking with another supplier. The result is that MSA is rarely used for improvement purposes, unless blindly satisfying the customer requirement is considered improvement.
How true this is....:(
This reminds me of "The blind leading the blind."
Painting by Pieter Breugel the Elder.
Stijloor.
#22
I think you raise some interesting and valid points, as does the Wheeler paper that Artichoke posted. The problem is that the vast majority of people who use GR&R, and MSA in general, have no understanding of what the numbers really mean, or how they come to be. It's a customer requirement, so it gets done in the best tradition of automotive industry self-fulfilling prophecy. If the "ideal" number is < 10%, then that's what it will be, one way or another.
I've seen many instances where in a relatively simple application that's worked well for many years, a GR&R study is done and the results are >10%, or even 30%. Failing to understand the concepts involved, the customer won't listen to reason and the supplier just manipulates the numbers in order to get on with his life. The customer looks only at the bottom line, and if it appears satisfactory, he gets on with his life and begins another line of ignorant nitpicking with another supplier. The result is that MSA is rarely used for improvement purposes, unless blindly satisfying the customer requirement is considered improvement.
yes. It's really too bad. suppliers spend so much time checking the boxes they have little time or energy left to truly improve their processes. The blind compliance to AIAG etc. has obscured the opportunity to teach and learn. I'm coming to the conclusion that mnay of our "standards" are killing Quality.
cladiv
#23
Thanks for reply,
But our case is,Its a automatic measuring line system.there is no operator to place the part which we are measure.parts (we measure camshaft,crank shaft etc) comes through a conveyor system and it stops on the measuring station a lifter is lift the part for measuring.the meadsuring system measure the diameter, height ..........,we use digital sensors and mini probe some times air gauge then the parts goes to the next measuring station like that the process going.
For this system how can i study GAGE R&R.
I would suggest to load the same part on the conveyor belt and measure it for a total of 30-50 times to get a good estimation of repeatability.
In this case case your repeatability is given by the ratio between 6 Stdev of the distribution that you will obtain and the tolerance soread (USL-LSL).
In this case, your variation would be given by your gauge and the "conveyor belt" which would present the part to the gauge in slightly different positions.
K Does company who manufacture but does not design or carry out clinical trials is responsible for CE marking for single use medical devices? ISO 13485:2016 - Medical Device Quality Management Systems 3
M Criteria and when to carry out Setup Approval Manufacturing and Related Processes 5
T Single or Multi site Internal Audits - Any difference in how to carry out? Internal Auditing 2
V How to carry out a Process Audit General Auditing Discussions 4
A PPAP for carry over (from an existing to a new model) components APQP and PPAP 4
P Who can carry out CQI-9 Assessments? CQI-9 Assessor Qualifications? IATF 16949 - Automotive Quality Systems Standard 2
K ISO 9001:2008 Project Start - How to carry out a Gap Analysis? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
P How to carry out Risk Analysis in a company with pastry products Food Safety - ISO 22000, HACCP (21 CFR 120) 1
somashekar The CE Certificate may no longer carry the CE Mark EU Medical Device Regulations 2
P Product Requalification Test - Auditor want us to carry out IATF 16949 - Automotive Quality Systems Standard 16
6 How to implement a functional system and carry out high quality internal Audit? Quality Manager and Management Related Issues 2
M TS Clause 7.6.3.2 - Can Non-Accreditated External Laboratory Carry out Calibration? IATF 16949 - Automotive Quality Systems Standard 14
Z How to Carry Out ?Customer Focus? on All Parts of Management System? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 35
A How to carry out 'Monitoring and measurement of processes' - Clause 8.2.3. Nonconformance and Corrective Action 12
A Action on Quality Records - Approve, Update and Carry Out Revision Control Records and Data - Quality, Legal and Other Evidence 10
L Is it necessary to carry out all the MSA studies? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
E APQP on Current Production and Carry Over Parts APQP and PPAP 3
M Can external quality consultant carry out internal audit? Internal Auditing 17
S Competence (4.4.2) Records - Contractors who carry out skilled maintenance tasks Miscellaneous Environmental Standards and EMS Related Discussions 8
L Special Characteristics in DFMEA (Design FMEA) - Carry over to PFMEA? FMEA and Control Plans 9
Sidney Vianna Should products carry the certification marks? Other ISO and International Standards and European Regulations 8
J Measurement Resolution - How far to carry the decimal place out Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 13
E Is it obligatory that only trained personel can carry out calibration? General Measurement Device and Calibration Topics 1
L Gage RandR on automated equipment. IATF 16949 - Automotive Quality Systems Standard 7
S Type 1 Gage R&R or something else? Reliability Analysis - Predictions, Testing and Standards 6
R Gage R&R Excel templates Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
K Gage R&R with more than 3 appraisers Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
M Definitive answer on Type 1 vs Type 2 vs Type 3 Gage Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
V Gage Management and Gage R&R Software General Measurement Device and Calibration Topics 1
D Gage R&R Study on Load Cells - Large chemical blending tanks IATF 16949 - Automotive Quality Systems Standard 1
S Gage R&R on alloy Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
