How to conduct a Gage R&R on DC Tools to Torque Bolts
dan_negrea
Hi to everybody.
I work in a company that does a lot of assembly and here we are using a lot of DC tools to torque bolts to a specific required value, which is displayed on a LED screen. Once the tool achieves the requiered value, the torquing operation stops and part moves to the next process.
These tools are calibrated on a regular basis, and the result of the torque is verified once a day using a regular dial torque wrench.
Our company wants to get certified for TS16949, and as you know, all measuring systems used have to be calibrated and statistical studies conducted on them.
I have two questions:
1. What kind of statistical study is more appropriate for this kind of tool? Gage R&R doesn't seem appropriate to me, torquing the same bolt over and over at the same required torque will always end up with the bolt in a different position.
2. Is a statistical study required?
Thank you for your help!
bpritts
Involved - Posts
We used to have this problem (we were TS certified at the time) and treated the torque guns as a manufacturing process (subject to statistical process control) and then considered the torque wrenches as measurement process. We built out the job that used the device, so I don't have to worry about it now.
I did give our machines quite a bit of study (to the point of being able to bore an innocent onlooker to tears) about just how the torque guns actually worked (ours measured the electrical load of the motor, and through software calculated a theoretical torque.) (ps. another TS item: ensuring that software involved in "measurement process" has been validated. Done by the torque wrench check.)
As a practical matter, what you want to do is to make sure you *really* understand what's going on, how it's really controlled, and what can go wrong. It sounds to me like you're on the right track... just do your homework. It's also important to avoid getting into circular discussions (e.g. we check the torque guns using a torque wrench, and then check the torque wrench using assemblies which we measured using the torque guns!)
good luck!
Brad
dan_negrea
Brad,
Thank you for your detailed answer, that's a good idea to go that path!
Cheers,
Daniel
dev1983
We have a similar process and are TS. We use a torque transducer to verify the read out on the LED screen and readout on the transducer during tightening process and do a comparison study.
F
fabricator
Hi to everybody.
1. GR&R will work and the data should prove capable as long as you use a calibrated transducer to verify the DC tool and DRO. My suggestion is to use a joint simulator as this is a hard joint and very repeatable. If you cant use a simulator then make sure you use distinct readings from, say, 30 individual parts. This is key because, as you noted, torquing a joint and then relaxing and then torquing it again will rarely give the same reading or angle.
2. If you have KPC joints, then capability of the tool is required. I'm not sure of the specifics of the TS standard, but showing that you performed the analysis on the tool would be a benefit nonetheless and show any auditor that you have confidence in the tooling system to perform as designed.
H How to conduct a Gage R&R (GR&R) on a Digital Multimeter? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
L Laser Trackers - How do we conduct a Gage R&R? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
A Procedure on how to conduct a Destructive MSA (Gage R&R) for Force Gages Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
F 1. Suggest a Gage for Checking Rounding of Gears 2. When to conduct Stability Study? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
S Requirement to Conduct New Shelf-life Testing? (re-do testing for design change) EU Medical Device Regulations 3
M Informational US FDA Draft Guidance – Patient Engagement in Design and Conduct of Medical Device Clinical Investigations Medical Device and FDA Regulations and Standards News 0
B Is it necessary to conduct product audit of entire product which is manufactured in the company as per IATF IATF 16949 - Automotive Quality Systems Standard 4
C How frequent to conduct Clinical / Performance Evaluation? CE Marking (Conformité Européene) / CB Scheme 4
S Script of R software to conduct Nested GRR for Destructive Testing Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
J ISO 9001:2008 - Can I still conduct Internal Audits in my company? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
J Can I conduct Internal Audit for combined ISO 9001, ISO 13485 and ISO 14001? Internal Auditing 37
R How do I conduct my API Q1, ISO compliant internal audits? Internal Auditing 1
P Can internal ISO 17025 Auditor conduct ISO 9001 Audit ISO 17025 related Discussions 7
S CMDCAS ISO13485 - Bilateral agreement with SAI global to conduct Certification Audits ISO 13485:2016 - Medical Device Quality Management Systems 7
S Conduct Customer Satisfaction Survey for every submitted Bid? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
T Conduct a fractional factorial 2^13-5 experiment with Minitab Using Minitab Software 4
M Help me understand how to conduct a Chi Square Test Statistical Analysis Tools, Techniques and SPC 3
N How do I conduct Management Review Meetings? Management Review Meetings and related Processes 34
R Can our Supplier's Quality Mgr. conduct Supplier Audit on behalf of manufacturer? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
F Tips, Guidelines and Checklist to conduct Audit of Supplier & Subcontractor Document Control Systems, Procedures, Forms and Templates 5
L How to conduct a Quality Audit based on ASME BPVC VIII-1 requirements Various Other Specifications, Standards, and related Requirements 4
Y FDA - Does anyone have conduct the validation on GR&R worksheet before? Qualification and Validation (including 21 CFR Part 11) 7
I Code of Ethics and Conduct wanted Document Control Systems, Procedures, Forms and Templates 3
C When is the Best Time to Conduct Internal Audits Internal Auditing 22
Q Tips on how to conduct a good Internal Audit Opening Meeting Internal Auditing 19
G How to conduct a Toy Recall (College Question) Customer and Company Specific Requirements 2
N How do I conduct Risk Management for my company? ISO 13485:2016 - Medical Device Quality Management Systems 7
K How to conduct a QCC project Misc. Quality Assurance and Business Systems Related Topics 2
N Tyvek Pouch Seal - Pressure needed to conduct Vacuum Seal Leak test? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
J How to Write the Planned Interval to Conduct Internal Audit, Management Review, etc.. ISO 13485:2016 - Medical Device Quality Management Systems 3
R How to conduct the Threshold Test of Mobile Equipment specified in 3rd edition? IEC 60601 - Medical Electrical Equipment Safety Standards Series 35
S How to conduct Capability Analysis for this data? Statistical Analysis Tools, Techniques and SPC 12
K Can auditors freely conduct confidential interviews, or consent is necessary? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 22
P How to conduct ILCP (inter-laboratory comparison programme) to get ISO 17025 ISO 17025 related Discussions 3
M Do we need to conduct Vendor (Supplier) Evaluation? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
K When, whom, how to conduct hazard analysis of PRP?s, OPRP?s and CCP?s? Food Safety - ISO 22000, HACCP (21 CFR 120) 1
S Can a suspended CB still conduct Surveillance Audits? Registrars and Notified Bodies 4
J My mentors insist I use hotel's employee manuals and codes of conduct for my... Service Industry Specific Topics 3
somashekar Sustainability audit per EICC Supplier Code of Conduct Sustainability, Green Initiatives and Ecology 14
Marc Apple Enforces "Supplier Code of Conduct" After Child Labor Discovery After Work and Weekend Discussion Topics 13
B How to Conduct a Review of Customer Order (Contract Review)? Contract Review Process 5
V How many years of experience is needed to conduct the internal audit in my company? General Auditing Discussions 4
Sidney Vianna Can CB's (certification bodies) conduct internal and 2nd party audits? Registrars and Notified Bodies 12
G How to conduct internal audits? Internal Auditing 52
M ISO 17025 Audit check list to conduct horizontal and vertical audits ISO 17025 related Discussions 10
D How to practically-conduct, post production phase ISO 13485:2016 - Medical Device Quality Management Systems 1
S Multilevel Design in Minitab to conduct a DOE - 4 factors and each has 5 levels Design and Development of Products and Processes 4
F How to conduct CMMI appraisal Class C Software Quality Assurance 4
P How to conduct MSA for Rotation Balancing Tester Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
H When to conduct a MSA (Measurement Systems Analysis) study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
